The device-mode is a feature which sets specific limitations on a device, or limits access to specific configuration options. Such feature is required in order to protect your router and network from attackers who might in some way gain access to your router and use it as a gateway for attacks to other networks. By protecting your device in such a way, even if an attacker manages to gain access to your unprotected device, he will not be able to use it in order to abuse your or any other network.
There are three available modes: advanced, home and basic. Device modes are factory pre-installed to routers, if the router is manufactured and shipped with MikroTik RouterOS v7.17 or later. Advanced (previously called enterprise) mode is assigned to CCR and 1100 series devices, home mode is assigned to home routers and basic mode to any other type of device. For devices running versions prior to RouterOS version 7.17, all devices use the advanced/enterprise mode.
[admin@MikroTik] > system/device-mode/print mode: advanced allowed-versions: 7.13+,6.49.8+ flagged: no flagging-enabled: yes scheduler: yes socks: yes fetch: yes pptp: yes l2tp: yes bandwidth-test: yes traffic-gen: no sniffer: yes ipsec: yes romon: yes proxy: yes hotspot: yes smb: yes email: yes zerotier: yes container: no install-any-version: no partitions: no routerboard: yes attempt-count: 0
The device-mode can be changed by the user, but remote access to the device is not enough to change it. After changing the device-mode, you need to confirm it, by pressing a button on the device itself, or perform a "cold reboot" - that is, unplug the power. When the change is confirmed, regardless of confirmation mode, the device will be rebooted!
[admin@MikroTik] > system/device-mode/update mode=home update: please activate by turning power off or pressing reset or mode button in 5m00s -- [Q quit|D dump|C-z pause]
If no power off or button press is performed within the specified time, the mode change is canceled. If another update command is run in parallel, both will be canceled.
There are several EOL products which do not "confirm" mode changes with a reset button press. These routers can confirm mode change only with a power cycle.
In order to protect your device against attacker who might silently gain access to your router, abuse it with some scripts and simply try to wait until you will reboot your router and not even know that at that time you are accepting changes requested by some intruder, you can "update" mode only three times. There is a counter which will count how many update attempts are made and will not allow any more updates. This counter can be reset only when administrator does power-cycle the router or press a button when seeing such a warning on mode settings update attempt (same as with accepting any updates).
[admin@MikroTik] > system/device-mode/update container=yes update: too many unsuccessful attempts, turn off power or reboot by pressing reset or mode button in 4m55s to reset attempt-count
The following commands are available in the /system/device-mode menu:
Property | Description |
get | Returns value that you can assign to variable or print on the screen. |
Shows the active mode and its properties. | |
update | Applies changes to the specified properties, see below. |
Available device-mode modes
There are three device modes available for configuration (mode=advanced is default one), each mode has a subset of features that are not allowed when it is used. Note that there is no mode, which has all features enabled. Certain features need to be enabled even if you have "advanced" mode enabled. See section "Feature clarification" for more details about what each option means. So, as per the below table it can be seen that "traffic-gen, container, partitions, routerboard" features are always disabled, unless specifically enabled by the admin user.
Mode | Description of disabled features |
advanced (default) | traffic-gen, container, install-any-version, partitions, routerboard |
basic | socks, bandwidth-test, traffic-gen, proxy, hotspot, zerotier, container, install-any-version, partitions, routerboard |
home | scheduler, socks, fetch, bandwidth-test, traffic-gen, sniffer, romon, proxy, hotspot, email, zerotier, container, install-any-version, partitions, routerboard |
List of available properties
scheduler, socks, fetch, pptp, l2tp, bandwidth-test, traffic-gen, sniffer, ipsec, romon, proxy, hotspot, smb, email, zerotier, container, install-any-version, partitions, routerboard (yes | no) | The list of available features, which can be controlled with the device-mode option. See section "Feature clarification" for more details about what each option means. |
activation-timeout (default: 5m); | The reset button or power off activation timeout can be set in range 00:00:10 .. 1d00:00:00. If the reset button is not pressed (or cold reboot is not performed) during this interval, the update will be canceled. |
flagging-enabled (yes | no; Default: yes) | Device will perform configuration analysis and if traces of suspicious code are found, flagged mode will be triggered, setting flagged=yes, enabling restrictions described in the flagged=yes. See the See the "Flagged status" paragraph. |
flagged (yes | no; Default: no) | RouterOS employs various mechanisms to detect tampering with it's system files. If the system has detected unauthorized access to RouterOS, the status "flagged" is set to yes. If "flagged" is set to yes, for your safety, certain limitations are put in place. See below chapter for more information. |
mode: (basic, home, advanced; default: advanced); | Allows choosing from available modes that will limit device functionality. By default, advanced mode allows options except traffic-gen, container, partitions, install-any-version, routerboard. So to use these features, you will need to turn it on by performing a device-mode update. By default, home mode disables the following features: scheduler, socks, fetch, bandwidth-test, traffic-gen, sniffer, romon, proxy, hotspot, email, zerotier, container, install-any-version, partitions, routerboard. |
More specific control over the available features is possible. Each of the features controlled by device-mode can be specifically turned on or off.
For instance scheduler won't allow to perform any action at system scheduler. Used device-mode disables all listed features, for instance mode=home is used, but zerotier is required for your setup, device-mode update /system device-mode update zerotier=yes will be required with the physical access to device to push the button or cut the power.
[admin@MikroTik] > system/device-mode/update mode=home email=yes [admin@MikroTik] > system/device-mode/update mode=advanced zerotier=no
If the update command specifies any of the mode parameters, this update replaces the entire device-mode configuration. In this case, all "per-feature" settings will be lost, except those specified with this command. For instance:
[admin@MikroTik] > system/device-mode/update mode=home email=yes fetch=yes [admin@MikroTik] > system/device-mode/print config mode: home fetch: yes email: yes [admin@MikroTik] > system/device-mode/update mode=advanced sniffer=no -- reboot -- [admin@MikroTik] > system/device-mode/print config mode: advanced sniffer: no
We see that fetch = yes and email = yes is missing, as they were overriden with the mode change. However, specifying only "per-feature" settings will change only those:
[admin@MikroTik] > system/device-mode/update hotspot=no -- reboot -- [admin@MikroTik] > system/device-mode/print config mode: advanced sniffer: no hotspot: no
If the feature is disabled, an error message is displayed for interactive commands:
[admin@MikroTik] > system/device-mode/print config mode: advanced sniffer: no hotspot: no [admin@MikroTik] > tool/sniffer/quick failure: not allowed by device-mode
However, it is possible to add the configuration to a disabled feature, but there will be a comment showing the disabled feature in the device-mode:
[admin@MikroTik] > ip hotspot/add interface=ether1 [admin@MikroTik] > ip hotspot/print Flags: X, S - HTTPS Columns: NAME, INTERFACE, PROFILE, IDLE-TIMEOUT # NAME INTERFACE PROFILE IDLE-TIMEOUT ;;; inactivated, not allowed by device-mode 0 X hotspot1 ether1 default 5m
Feature | Clarification of which menus become unavailable to change |
bandwidth-test | /tool bandwidth-test /tool speed-test |
routerboard | /system routerboard settings (except auto-upgrade option) |
container | all container functionality |
install-any-version | RouterOS will no longer allow for you to install RouterOS version below versions listed under "allowed-versions" attribute. |
/tool e-mail | |
fetch | /tool fetch |
hotspot | /ip hotspot |
ipsec | /ip ipsec |
l2tp | /interface l2tp-server /interface l2tp-client |
partitions | /partitions does not allow to change count of partitions. If your router is unable to boot, it will still be able to boot into your other partitions. No restriction for crash recovery. |
pptp | /interface pptp-server /interface pptp-client |
proxy | /ip proxy |
romon | /tool romon |
scheduler | /system scheduler |
smb | /ip smb |
sniffer | /tool sniffer |
socks | /ip socks |
traffic-gen | /tool traffic-generator /tool flood-ping /tool ping-speed |
zerotier | /zerotier |
Allowed versions
Device mode lists in its parameters an argument called "allowed-versions". This is a list of versions which MikroTik considers as secure and which ones do not include any serious vulnerabilities which could be used by an attacker. This list can be updated to versions which includes some major changes in RouterOS below which downgrade should not be allowed.
This setting does not depend on the installed RouterOS version and works as a separate mechanism, in order to disallow attacker to downgrade version step-by-step in order to reach some vulnerable RouterOS release. This means that if you upgrade RouterOS to a release where a newer "allowed-versions" list is available, oldest list will be overwritten. If you downgrade RouterOS, "allowed-versions" list will not change and will remain updated to the latest list.
This list is ignored, if device-mode "install-any-version" is enabled.
Flagged status
Along with the device-mode feature, RouterOS now can analyze the whole configuration at system startup, to determine if there are any signs of unauthorized access to your router. If suspicious configuration is detected, the suspicious configuration will be disabled and the flagged parameter will be set to "yes". The device has now a Flagged state and enforces certain limitations.
[admin@MikroTik] > system/device-mode/print mode: advanced flagged: yes sniffer: no hotspot: no
If the system has this flagged status, the current configuration works, but it is not possible to perform the following actions:
bandwidth-test, traffic-generator, sniffer, as well as configuration actions that enable or create new configuration entries (it will still be possible to disable or delete them) for the following programs: system scheduler, SOCKS proxy, pptp, l2tp, ipsec, proxy, smb.
When performing the aforementioned actions while the router has the flagged state, you will receive an error message:
[admin@MikroTik] > /tool sniffer/quick failure: configuration flagged, check all router configuration for unauthorized changes and update device-mode [admin@MikroTik] > /int l2tp-client/add connect-to=1.1.1.1 user=user failure: configuration flagged, check all router configuration for unauthorized changes and update device-mode
To exit the flagged state, you must perform the command "/system/device-mode/update flagged=no". The system will ask to either press a button, or issue a hard reboot (cut power physically or do a hard reboot of the virtual machine).
Important! Although the system has disabled any malicious looking rules, which triggered the flagged state, it is crucial to inspect all of your configuration for other unknown things, before exiting the flagged state. If your system has been flagged, assume that your system has been compromised and do a full audit of all settings before re-enabling the system for use. After completing the audit, change all the system passwords and upgrade to the latest RouterOS version.
Starting from RouterOS version 7.17 device-mode restricts SwOS/RouterOS transition for dual-boot; in order to enable: system/device-mode/update routerboard=yes
