These examples are meant for you to make your own Python3 based RouterOS API client, they are just templates, or starting points. Use them at your own risk.
Minimal example
Bare minimum, no SSL, no error handling, timeouts or graceful shutdowns.
python3 python_api_minimal.py 192.168.88.1 admin "" /system/resource/print
python3 python_api_minimal.py 10.0.0.1 admin secret /interface/print
#!/usr/bin/python3
Minimal MikroTik RouterOS API example.
Usage: python_api_minimal.py <ip> <user> <password> <command>
Example: python_api_minimal.py 192.168.88.1 admin "" /system/resource/print
import socket, hashlib, binascii, sys
def write_word(s, w):
data = w.encode('utf-8')
length = len(data)
if length < 0x80:
s.send(length.to_bytes(1, 'big'))
elif length < 0x4000:
s.send((length | 0x8000).to_bytes(2, 'big'))
elif length < 0x200000:
s.send((length | 0xC00000).to_bytes(3, 'big'))
elif length < 0x10000000:
s.send((length | 0xE0000000).to_bytes(4, 'big'))
else:
s.send(b'\xF0' + length.to_bytes(4, 'big'))
s.send(data)
def read_word(s):
c = s.recv(1)[0]
if (c & 0x80) == 0x00:
length = c
elif (c & 0xC0) == 0x80:
length = ((c & 0x3F) << 8) + s.recv(1)[0]
elif (c & 0xE0) == 0xC0:
length = ((c & 0x1F) << 16) + (s.recv(1)[0] << 8) + s.recv(1)[0]
elif (c & 0xF0) == 0xE0:
length = ((c & 0x0F) << 24) + (s.recv(1)[0] << 16) + (s.recv(1)[0] << 8) + s.recv(1)[0]
else:
length = (s.recv(1)[0] << 24) + (s.recv(1)[0] << 16) + (s.recv(1)[0] << 8) + s.recv(1)[0]
return s.recv(length).decode('utf-8') if length else ''
def send_sentence(s, words):
for w in words:
write_word(s, w)
write_word(s, '')
def read_sentence(s):
r = []
while True:
w = read_word(s)
if w == '':
return r
r.append(w)
def login(s, user, pwd):
send_sentence(s, ['/login', '=name=' + user, '=password=' + pwd])
response = read_sentence(s)
if response[0] == '!done' and len(response) > 1 and response[1].startswith('=ret='):
# Legacy auth (RouterOS < 6.43)
challenge = binascii.unhexlify(response[1][5:])
md = hashlib.md5()
md.update(b'\x00' + pwd.encode('utf-8') + challenge)
send_sentence(s, ['/login', '=name=' + user, '=response=00' + md.hexdigest()])
read_sentence(s)
if __name__ == '__main__':
ip, user, pwd, cmd = sys.argv[1], sys.argv[2], sys.argv[3], sys.argv[4]
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect((ip, 8728))
login(s, user, pwd)
send_sentence(s, [cmd])
while True:
sentence = read_sentence(s)
for word in sentence:
print(word)
if sentence[0] == '!done':
break
s.close()
Example with SSL and validation
MikroTik RouterOS API Client
Usage: python_api_fixed.py <ip-address> [username] [password] [secure] [port] [verify_ssl]
Arguments:
ip-address : Router IP address (required)
username : Login username (default: admin)
password : Login password (default: empty)
secure : Use SSL/TLS - true/false/1/0/yes/no (default: false)
port : API port (default: 8728 or 8729 for secure)
verify_ssl : Verify SSL certificate - true/false (default: false)
Examples:
python_api_fixed.py 10.0.0.1
python_api_fixed.py 10.0.0.1 admin MyPassword123
python_api_fixed.py 10.0.0.1 admin MyPassword123 true
python_api_fixed.py 10.0.0.1 admin MyPassword123 true 8729
python_api_fixed.py 10.0.0.1 admin MyPassword123 true 8729 true
After connecting, type API commands, pressing Enter after each word.
Press Enter twice (empty line) to send the command to the router.
#!/usr/bin/python3
# -*- coding: utf-8 -*-
import sys
import binascii
import socket
import select
import ssl
import hashlib
import re
SENSITIVE_PATTERNS = re.compile(r'(=password=|=response=)(.+)', re.IGNORECASE)
def mask_sensitive(word):
"""Mask sensitive data in API words for logging"""
return SENSITIVE_PATTERNS.sub(r'\1***', word)
class ApiRos:
"""RouterOS API client"""
def __init__(self, sk):
self.sk = sk
def login(self, username, pwd):
for repl, attrs in self.talk(["/login", "=name=" + username, "=password=" + pwd]):
if repl == '!trap':
return False
elif '=ret' in attrs:
# Legacy authentication (RouterOS < 6.43)
chal = binascii.unhexlify((attrs['=ret']).encode('utf-8'))
md = hashlib.md5()
md.update(b'\x00')
md.update(pwd.encode('utf-8'))
md.update(chal)
for repl2, attrs2 in self.talk(["/login", "=name=" + username, "=response=00"
+ binascii.hexlify(md.digest()).decode('utf-8')]):
if repl2 == '!trap':
return False
return True
def talk(self, words):
if self.writeSentence(words) == 0:
return []
r = []
while True:
i = self.readSentence()
if len(i) == 0:
continue
reply = i[0]
attrs = {}
for w in i[1:]:
j = w.find('=', 1)
if j == -1:
attrs[w] = ''
else:
attrs[w[:j]] = w[j+1:]
r.append((reply, attrs))
if reply == '!done':
return r
def writeSentence(self, words):
ret = 0
for w in words:
self.writeWord(w)
ret += 1
self.writeWord('')
return ret
def readSentence(self):
r = []
while True:
w = self.readWord()
if w == '':
return r
r.append(w)
def writeWord(self, w):
print("<<< " + mask_sensitive(w))
self.writeLen(len(data))
self.writeBytes(data)
def readWord(self):
ret = self.readStr(self.readLen())
print(">>> " + mask_sensitive(ret))
return ret
def writeLen(self, l):
if l < 0x80:
self.writeBytes(l.to_bytes(1, 'big'))
elif l < 0x4000:
self.writeBytes((l | 0x8000).to_bytes(2, 'big'))
elif l < 0x200000:
self.writeBytes((l | 0xC00000).to_bytes(3, 'big'))
elif l < 0x10000000:
self.writeBytes((l | 0xE0000000).to_bytes(4, 'big'))
else:
self.writeBytes(b'\xF0' + l.to_bytes(4, 'big'))
def readLen(self):
c = ord(self.readBytes(1))
pass
c &= ~0xC0
c <<= 8
c += ord(self.readBytes(1))
c &= ~0xE0
c <<= 8
c <<= 8
c &= ~0xF0
c <<= 8
c <<= 8
c <<= 8
elif (c & 0xF8) == 0xF0:
c <<= 8
c <<= 8
c <<= 8
return c
def writeBytes(self, data):
"""Write raw bytes to socket"""
n = 0
while n < len(data):
r = self.sk.send(data[n:])
if r == 0:
raise RuntimeError("connection closed by remote end")
n += r
def readBytes(self, length):
"""Read exact number of bytes from socket"""
ret = b''
while len(ret) < length:
s = self.sk.recv(length - len(ret))
if s == b'':
ret += s
return ret
def readStr(self, length):
"""Read string of specified length from socket"""
data = self.readBytes(length)
return data.decode('utf-8', errors='replace')
def parse_bool(value):
"""Parse string to boolean"""
return value.lower() in ('true', '1', 'yes', 'on')
def parse_port(value):
"""Parse and validate port number"""
try:
port = int(value)
except ValueError:
raise ValueError(f"Invalid port number: {value}")
if not 1 <= port <= 65535:
raise ValueError(f"Port must be between 1 and 65535, got {port}")
return port
def open_socket(dst, port, secure=False, verify_ssl=False):
"""Open socket connection to RouterOS device"""
res = socket.getaddrinfo(dst, port, socket.AF_UNSPEC, socket.SOCK_STREAM)
af, socktype, proto, canonname, sockaddr = res[0]
s = socket.socket(af, socktype, proto)
try:
if secure:
context = ssl.SSLContext(ssl.PROTOCOL_TLS_CLIENT)
context.minimum_version = ssl.TLSVersion.TLSv1_2
if verify_ssl:
context.verify_mode = ssl.CERT_REQUIRED
context.load_default_certs()
else:
context.check_hostname = False
context.verify_mode = ssl.CERT_NONE
s = context.wrap_socket(s, server_hostname=dst)
s.connect(sockaddr)
return s
except:
s.close()
raise
def main():
if len(sys.argv) < 2:
print(__doc__)
sys.exit(1)
dst = sys.argv[1]
user = "admin"
passw = ""
secure = False
port = 0
verify_ssl = False
arg_nr = len(sys.argv)
if arg_nr > 2:
user = sys.argv[2]
if arg_nr > 3:
passw = sys.argv[3]
if arg_nr > 4:
secure = parse_bool(sys.argv[4])
if arg_nr > 5:
try:
port = parse_port(sys.argv[5])
except ValueError as e:
print(f"Error: {e}")
sys.exit(1)
if arg_nr > 6:
verify_ssl = parse_bool(sys.argv[6])
if port == 0:
port = 8729 if secure else 8728
try:
s = open_socket(dst, port, secure, verify_ssl)
except socket.gaierror as e:
print(f"Error: Could not resolve hostname '{dst}': {e}")
sys.exit(1)
except socket.error as e:
print(f"Error: Could not connect to {dst}:{port}: {e}")
sys.exit(1)
except ssl.SSLError as e:
print(f"Error: SSL connection failed: {e}")
sys.exit(1)
apiros = ApiRos(s)
if not apiros.login(user, passw):
print("Error: Login failed")
s.close()
sys.exit(1)
print(f"Connected to {dst}:{port} as {user}")
print("Enter API commands (empty line to send, Ctrl+C to exit)")
inputsentence = []
try:
while True:
r = select.select([s, sys.stdin], [], [], None)
if s in r[0]:
apiros.readSentence()
if sys.stdin in r[0]:
# Read line from input and strip newline
l = sys.stdin.readline()
if l == '':
# EOF reached
break
l = l.rstrip('\n\r')
# Empty line sends the sentence
if l == '':
if inputsentence:
apiros.writeSentence(inputsentence)
inputsentence = []
else:
inputsentence.append(l)
except KeyboardInterrupt:
print("\nDisconnecting...")
finally:
s.close()
main()
