This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
PropertyDescription
check-gateway-ping-count (integer [0..65535], Default: 2)
check-gateway-ping-interval (time [100ms..10m], Default: 10s)
check-gateway-ping-timeout (time [1ms..1s], Default: 1s)
connected-in-chain (name)
dynamic-in-chain (name)
policy-rules (mangle | vrf-lookup | vrf-unreach | local | user | main | ...)Defines order of routing decision rules. By default "user" is the chain where user defined /routing/rule is added. It is possible to add custom chains anywhere in the list.
single-process (yes | no, Default: no)
When enabled all routing related processes are combined into single routing process to decrease RAM usage. When disabled all routing related processes are processed separately, which can improve performance and stability in certain setups.
By default, single-process is enabled only for devices with 64 MB of RAM.
A reboot is required for this change to take effect.
  • No labels
