This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
/routing/rip/instance
PropertyDescription
name name of the instance
vrf ( Default: main)which VRF to use
afi (ipv4 | ipv6; Default: )specifies which afi to use.
in-filter-chain (Default: )input filter chain
out-filter-chain (Default: )output filter chain
out-filter-select (Default: )output filter select rule chain
redistribute (bgp, bgp-mpls-vpn, connected, dhcp, fantasy, modem, ospf, rip, static, vpn; Default: )which routes to redistribute
originate-default ( Default:)whether to originate default route
routing-table ( Default: main)in which routing table the routes will be added
route-timeout (Default: )route timeout
route-gc-timeout  (Default: )
update-interval (time; Default: )specifies time interval after which the route is considered invalid
Note: The maximum metric of RIP route is 15. Metric higher than 15 is considered 'infinity' and routes with such metric are considered unreachable. Thus RIP cannot be used on networks with more than 15 hops between any two routers, and using redistribute metrics larger that 1 further reduces this maximum hop count.
/routing/rip/interface-template
PropertyDescription
instancewhich VRF to use
interfaces specifies which afi to use.
source-addresses input filter chain
cost (Default: )output filter chain
split-horizon (no| yes )
poison-reverse (no| yes )
mode (passive| strict)
key-chain (name)Name of key-chain which contains MD5 key. Should be set only when MD5 authentication is needed.
password sensitivePassword for plain text authentication. Should be set only when plain-text authentication is needed.
Read-only PropertyDescription
address (address)IP address.
instance (name)Name of the instance.
interface (name)Name of the interface.
/routing/rip/neighbor
This submenu is used to define a neighboring routers to exchange routing information with. Normally there is no need to add the neighbors, if multicasting is working properly within the network. If there are problems with exchanging routing information, neighbor routers can be added to the list. It will force the router to exchange the routing information with the neighbor using regular unicast packets.
address (IP address)IP address of neighboring router
routesamount of routes
packets-totalamount of all packets
packets-badamount of bad packets
entries-badamount of bad entries
last-update (time)time from last update
/routing/rip/static-neighbor
PropertyDescription
instance (name)name of used instance
/routing/rip/keys
MD5 authentication key chains.
PropertyDescription
chain (string; Default: "")chain name to place this key in.
key (string; Default: "")authentication key. Maximal length 16 characters
key-id (integer:0..255; Default: )key identifier. This number is included in MD5 authenticated RIP messages, and determines witch key to use to check authentication for a specific message.
valid-from (date and time; Default: today's date and time: 00:00:00)key is valid from this date and time
valid-till (date and time; Default: today's date and time: 00:00:00)key is valid until this date and time
  • No labels
