This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
/routing/ospf/instance
PropertyDescription
domain-id (Hex | Address)MPLS-related parameter. Identifies the OSPF domain of the instance. This value is attached to OSPF routes redistributed in BGP as VPNv4 routes as BGP extended community attribute and used when BGP VPNv4 routes are redistributed back to OSPF to determine whether to generate inter-area or AS-external LSA for that route. By default Null domain-id is used, as described in RFC 4577.
domain-tag (integer [0..4294967295])if set, then used in route redistribution (as route-tag in all external LSAs generated by this router), and in route calculation (all external LSAs having this route tag are ignored). Needed for interoperability with older Cisco systems. By default not set.
in-filter (string)name of the routing filter chain used for incoming prefixes
mpls-te-address (string)the area used for MPLS traffic engineering. TE Opaque LSAs are generated in this area. No more than one OSPF instance can have mpls-te-area configured.
mpls-te-area (string)the area used for MPLS traffic engineering. TE Opaque LSAs are generated in this area. No more than one OSPF instance can have mpls-te-area configured.
originate-default (always | if-installed | never; )Specifies default route (0.0.0.0/0) distribution method.
out-filter-chain (name)name of the routing filter chain used for outgoing prefixes filtering. Output operates only with "external" routes.
out-filter-select (name)name of the routing filter select chain, used for output selection. Output operates only with "external" routes.
redistribute (bgp,connected,copy,dhcp,fantasy,modem,ospf,rip,static,vpn; )Enable redistribution of specific route types.
router-id (IP | name; Default: main)OSPF Router ID. Can be set explicitly as an IP address, or as the name of the router-id instance.
version (2 | 3; Default: 2)OSPF version this instance will be running (v2 for IPv4, v3 for IPv6).
vrf (name of a routing table; Default: main)the VRF table this OSPF instance operates on
use-dn (yes | no)Forces to use or ignore DN bit. Useful in some CE PE scenarios to inject intra-area routes into VRF. If a parameter is unset then the DN bit is used according to RFC. Available since v6rc12.
/routing/ospf/area
PropertyDescription
area-id (IP address; Default: 0.0.0.0)OSPF area identifier. If the router has networks in more than one area, then an area with area-id=0.0.0.0 (the backbone) must always be present. The backbone always contains all area border routers. The backbone is responsible for distributing routing information between non-backbone areas. The backbone must be contiguous, i.e. there must be no disconnected segments. However, area border routers do not need to be physically connected to the backbone - connection to it may be simulated using a virtual link.
default-cost (integer; unset)Default cost of injected LSAs into the area. If the value is not set, then stub area type-3 default LSA will not be originated.
instance (name; mandatory)Name of the OSPF instance this area belongs to.
no-summaries ()Flag parameter, if set then the area will not flood summary LSAs in the stub area.
name (string)the name of the area
nssa-translate (yes | no | candidate)The parameter indicates which ABR will be used as a translator from type7 to type5 LSA. Applicable only if area type is NSSA
  • yes - the router will be always used as a translator
  • no - the router will never be used as a translator
  • candidate - OSPF elects one of the candidate routers to be a translator
type (default | nssa | stub; Default: default)The area type. Read more on the area types in the OSPF case studies.
/routing/ospf/area/range
PropertyDescription
advertise (yes | no; Default: yes)Whether to create a summary LSA and advertise it to the adjacent areas.
area (name; mandatory)the OSPF area associated with this range
cost (integer [0..4294967295])the cost of the summary LSA this range will create
default - use the largest cost of all routes used (i.e. routes that fall within this range)
prefix (IP prefix; mandatory)the network prefix of this range
/routing/ospf/interface
Read-only matched interface menu
/routing/ospf/interface-template
The interface template defines common network and interface matches and what parameters to assign to a matched interface.
Matchers
PropertyDescription
interfaces (name)
Interfaces to match. Accepts specific interface names or the name of the interface list.
network (IP prefix)the network prefix associated with the area. OSPF will be enabled on all interfaces that have at least one address falling within this range. Note that the network prefix of the address is used for this check (i.e. not the local address). For point-to-point interfaces, this means the address of the remote endpoint.
Assigned Parameters
PropertyDescription
area (name; mandatory)The OSPF area to which the matching interface will be associated.
auth (simple | md5 | sha1 | sha256 | sha384 | sha512)Specifies authentication method for OSPF protocol messages.
  • simple - plain text authentication
  • md5 - keyed Message Digest 5 authentication
  • sha - HMAC-SHA authentication RFC5709
If the parameter is unset, then authentication is not used.
auth-id (integer)The key id is used to calculate message digest (used when MD5 or SHA authentication is enabled). The value should match all OSPF routers from the same region.
authentication-key (string) sensitiveThe authentication key to be used, should match on all the neighbors of the network segment.
comment(string)
cost(integer [0..65535])Interface cost expressed as link state metric.
dead-interval (time; Default: 40s)Specifies the interval after which a neighbor is declared dead. This interval is advertised in hello packets. This value must be the same for all routers on a specific network, otherwise, adjacency between them will not form
disabled(yes | no)
hello-interval (time; Default: 10s)The interval between HELLO packets that the router sends out this interface. The smaller this interval is, the faster topological changes will be detected, the tradeoff is more OSPF protocol traffic. This value must be the same for all the routers on a specific network, otherwise, adjacency between them will not form.
instance-id (integer [0..255]; Default: 0)
passive ()If enabled, then do not send or receive OSPF traffic on the matching interfaces
prefix-list (name)Name of the address list containing networks that should be advertised to the v3 interface.
priority (integer: 0..255; Default: 128)
Router's priority. Used to determine the designated router in a broadcast network. The router with the highest priority value takes precedence. Priority value 0 means the router is not eligible to become a designated or backup designated router at all.
ROS v7 default value is 128 (defined in RFC), and the default value in ROS v6 was 1, keep this in mind when if you had strict priorities set for DR/BDR election.
retransmit-interval (time; Default: 5s)Time interval the lost link state advertisement will be resent. When a router sends a link state advertisement (LSA) to its neighbor, the LSA is kept until the acknowledgment is received. If the acknowledgment was not received in time (see transmit-delay), the router will try to retransmit the LSA.
transmit-delay (time; Default: 1s)Link-state transmit delay is the estimated time it takes to transmit a link-state update packet on the interface.
type (broadcast | nbma | ptp | ptmp | ptp-unnumbered | virtual-link; Default: broadcast)the OSPF network type on this interface. Note that if interface configuration does not exist, the default network type is 'point-to-point' on PtP interfaces and 'broadcast' on all other interfaces.
  • broadcast - network type suitable for Ethernet and other multicast capable link layers. Elects designated router
  • nbma - Non-Broadcast Multiple Access. Protocol packets are sent to each neighbor's unicast address. Requires manual configuration of neighbors. Elects designated router
  • ptp - suitable for networks that consist only of two nodes. Do not elect designated router
  • ptmp - Point-to-Multipoint. Easier to configure than NBMA because it requires no manual configuration of a neighbor. Do not elect a designated router. This is the most robust network type and as such suitable for wireless networks, if 'broadcast' mode does not work well enough for them
  • ptp-unnumbered - works the same as ptp, except that the remote neighbor does not have an associated IP address to a specific PTP interface. For example, in case an IP unnumbered is used on Cisco devices.
  • virtual-link - for virtual link setups.
vlink-neighbor-id (IP)Specifies the router-id of the neighbor which should be connected over the virtual link.
vlink-transit-area (name)A non-backbone area the two routers have in common over which the virtual link will be established. Virtual links can not be established through stub areas.
/routing/ospf/lsa
List of all the LSAs currently in the LSA database.
Read-only PropertyDescription
age (integer)How long ago (in seconds) the last update occurred
area (string)The area this LSA belongs to.
body (string)
checksum (string)LSA checksum
dynamic (yes | no)
flushing (yes | no)
id (IP)LSA record ID
instance (string)The instance name this LSA belongs to.
link (string)
link-instance-id (IP)
originator (IP)An originator of the LSA record.
self-originated (yes | no)Whether LSA originated from the router itself.
sequence (string)A number of times the LSA for a link has been updated.
type (string)
wraparound (string)
/routing/ospf/neighbor
List of currently active OSPF neighbors.
address (IP)An IP address of the OSPF neighbor router
adjacency (time)Elapsed time since adjacency was formed
area (string)
bdr (string)An IP address of the Backup Designated Router
comment (string)
db-summaries (integer)
dr (IP)An IP address of the Designated Router
dynamic (yes | no)
inactive (yes | no)
instance (string)
ls-requests (integer)
ls-retransmits (integer)
priority (integer)Priority configured on the neighbor
router-id (IP)neighbor router's RouterID
state (down | attempt | init | 2-way | ExStart | Exchange | Loading | full)
  • Down - No Hello packets have been received from a neighbor.
  • Attempt - Applies only to NBMA clouds. The state indicates that no recent information was received from a neighbor.
  • Init - Hello packet received from the neighbor, but bidirectional communication is not established (Its own RouterID is not listed in the Hello packet).
  • 2-way - This state indicates that bi-directional communication is established. DR and BDR elections occur during this state, routers build adjacencies based on whether the router is DR or BDR, and the link is point-to-point or a virtual link.
  • ExStart - Routers try to establish the initial sequence number that is used for the packet information exchange. The router with a higher ID becomes the master and starts the exchange.
  • Exchange - Routers exchange database description (DD) packets.
  • Loading - In this state actual link state information is exchanged. Link State Request packets are sent to neighbors to request any new LSAs that were found during the Exchange state.
  • Full - Adjacency is complete, and neighbor routers are fully adjacent. LSA information is synchronized between adjacent routers. Routers achieve the full state with their DR and BDR only, an exception is P2P links.
state-changes (integer)Total count of OSPF state changes since neighbor identification
/routing/ospf/static-neighbor
Static configuration of the OSPF neighbors. Required for non-broadcast multi-access networks.
address (IP%iface; mandatory )The unicast IP address and an interface, that can be used to reach the IP of the neighbor. For example, address=1.2.3.4%ether1 indicates that a neighbor with IP 1.2.3.4 is reachable on the ether1 interface.
area (name; mandatory )Name of the area the neighbor belongs to.
comment (string)
disabled (yes | no)
poll-interval (time; Default: 2m)How often to send hello messages to the neighbors which are in a "down" state (i.e. there is no traffic from them)
  • No labels
