| Property | Description |
| address (IPv4/6) mandatory | Address of the RTR server |
| disabled(yes | no; Default: no) | Whether the item is ignored. |
| expire-interval (integer [600..172800]; Default: 7200) | Time interval [s] polled data is considered valid in the absence of a valid subsequent update from the validator. |
| group (string) mandatory | Name of the group a database is assigned to. |
| port (integer [0..65535]; Default: 323) | Connection port number |
| preference (integer [0..4294967295]; Default: 0) | If there are multiple RTR sources, the preference number indicates a more preferred one. A higher number is preferred. If preference is not configured then lowest remote IP within a group is preferred, if IPs are equal then lowest remote port is preferred. |
| refresh-interval (integer [1..86400]; Default: 3600) | Time interval [s] to poll the newest data from the validator. |
| retry-interval (integer [1..7200]; Default: 600) | Time Interval [s] to retry after the failed data poll from the validator. |
| vrf(name; Default: main) | Name of the VRF table used to bind the connection to. |
