This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
Introduction
Matrix is a decentralized communication protocol. Each Matrix server has its own set of users and its own set of rules, you can host your own Matrix server on a RouterOS device using Containers. You can create federation between Matrix servers and communicate with users on different Matrix servers securely. You can also use Matrix bridges to relay messages from other chat platforms such as WhatsApp, Discord, Signal, Telegram and other platforms and only use a single App such as Element and be able to communicate with users on different platforms.
Configuration
To setup a Matrix server on your RouterOS device, follow the steps below.
Make sure you have created a Container network before proceeding.
  1. Create PostgreSQL Container environment variables:
    /container/envs/add name=postgres_synapse_envs key=POSTGRES_DB value="synapse"
    /container/envs/add name=postgres_synapse_envs key=POSTGRES_PASSWORD value="<POSTGRES_PASSWORD_HERE>"
    /container/envs/add name=postgres_synapse_envs key=POSTGRES_USER value="synapse_user"
    /container/envs/add name=postgres_synapse_envs key=PGDATA value="/var/lib/postgresql/data/pgdata"
    /container/envs/add name=postgres_synapse_envs key=POSTGRES_INITDB_ARGS value="--encoding='UTF8' --lc-collate='C' --lc-ctype='C'"
    /container/envs/add name=postgres_synapse_envs key=PGPORT value=5433
  2. Create PostgreSQL Container mounts:
    /container/mounts/add name=synapse_postgres_data src=disk1/synapse-postgres-data dst=/var/lib/postgresql/data
  3. Create a PostgreSQL Container:
    /container/add remote-image=postgres:17.2-alpine interface=veth1 root-dir=disk1/postgres-17.2-synapse mounts=synapse_postgres_data envlist=postgres_synapse_envs name=postgresql_synapse
  4. Create Synapse Container environment variables:
    /container/envs/add name=synapse_envs key=SYNAPSE_CONFIG_DIR value="/data"
    /container/envs/add name=synapse_envs key=SYNAPSE_CONFIG_PATH value="/data/homeserver.yaml"
    /container/envs/add name=synapse_envs key=SYNAPSE_SERVER_NAME value="test.mt.lv"
    /container/envs/add name=synapse_envs key=SYNAPSE_REPORT_STATS value="yes"
  5. Create Synapse Container mounts:
    /container/mounts/add name=synapse_data src=disk1/synapse-data dst=/data
  6. Create a Synapse Container for generating required data:
    /container/add remote-image=matrixdotorg/synapse:latest interface=veth1 cmd="generate" root-dir=disk1/synapse mounts=synapse_data envlist=synapse_envs name=synapse
  7. Start and stop the Synapse Container to allow it to generate required files:
    /container/start [find where name=synapse]
    /container/stop [find where name=synapse]
  8. Remove the cmd parameter from the Synapse Container:
    /container/set [find where name=synapse] cmd=""
  9. Connect to your RouterOS device using a SFTP client (for example, WinSCP if using Microsoft Windows) and adjust the disk1/synapse-data/homeserver.yaml file:
    database:
      args:
        user: synapse_user
        password: <POSTGRE_PASSWORD_HERE>
        dbname: synapse
        host: localhost
        port: 5433
        cp_min: 5
        cp_max: 10
        keepalives_idle: 10 #optional
        keepalives_interval: 10 #optional
        keepalives_count: 3 #optional
  10. Start the PostgreSQL Container:
    /container/start [find where name=postgresql_synapse]
  11. Start the Synapse Container:
  12. Enter the Synapse Container's shell and register a new user:
    register_new_matrix_user -c /data/homeserver.yaml
  13. You should now be able to access your Matrix server using your RouterOS device's address.
Make sure you check the official documentation for Synapse to get the latest configuration steps.
Discord bridge
The example below is for configuring a Discord bridge, but the procedure for other types of bridges is very similar. Check the official documentation of your desired bridge for more information.
  1. Create PostgreSQL Discord bridge Container environment variables:
    /container/envs/add name=postgres_discord_envs key=POSTGRES_DB value="synapse-discord"
    /container/envs/add name=postgres_discord_envs key=POSTGRES_PASSWORD value="<POSTGRE_BRIDGE_PASSWORD_HERE>"
    /container/envs/add name=postgres_discord_envs key=POSTGRES_USER value="synapse_discord"
    /container/envs/add name=postgres_discord_envs key=PGDATA value="/var/lib/postgresql/data/pgdata"
    /container/envs/add name=postgres_discord_envs key=POSTGRES_INITDB_ARGS value="--encoding='UTF8' --lc-collate='C' --lc-ctype='C'"
    /container/envs/add name=postgres_synapse_envs key=PGPORT value=5434
  2. Create PostgreSQL Discord bridge Container mounts:
    /container/mounts/add name=discord_postgres_data src=disk1/discord-postgres-data dst=/var/lib/postgresql/data
  3. Create a PostgreSQL Container for Discord bridge:
    /container/add remote-image=postgres:17.2-alpine interface=veth1 root-dir=disk1/postgres-17.2-discord mounts=discord_postgres_data envlist=postgres_discord_envs name=postgresql_discord
  4. Follow the guide for HAProxy Container and setup a reverse proxy for port 8080
  5. sdaCreate Discord bridge Container mount points:
    /container/mounts/add name=synapse_discord_data src=disk1/synapse-discord-data dst=/data
  6. Create a Discord Bridge Container:
    /container/add remote-image=litetex/mau.mautrix.discord:latest interface=veth1 root-dir=disk1/synapse-discord mounts=synapse_discord_data name=synapse_discord
  7. Start and stop the Discord bridge Container to generate files:
    /container/start [find where name=synapse_discord]
    /container/stop [find where name=synapse_discord]
  8. Connect to your RouterOS device using SFTP client (for example, WinSCP when using Microsoft Windows) and adjust the file disk1/dynapse-discord/config.yaml :
    homeserver
        address: http://localhost:8008
        domain: test.mt.lv
        software: standard
        async_media: true
    appservice
        address: leave default
        hostname: leave default
        port: leave default
        database:
            type: postgres
            uri: postgres://synapse_discord:<POSTGRE_DISCORD_PASSWORD_HERE>@172.17.0.2:5434/synapse-discord?sslmode=disable
    bridge:
        encryption:
            allow: true
        permissions:
            "*": relay
            "@your_admin_user1:test.mt.lv": admin
            "@your_admin_user2:test.mt.lv": admin
  9. Start and stop the Discord bridge Container again:
  10. Download the file disk1/synapse-discord/registration.yaml  and upload it as file disk1/synapse-data/mautrix-discord-registration.yaml
  11. Connect to your RouterOS device using a SFTP client (for example, WinSCP when using Microsoft Windows) and add the following lines to disk1/synapse-data/homeserver.yaml:
    app_service_config_files:
    - /data/mautrix-discord-registration.yaml
  12. Start and stop the Synapse and Discord bridge Containers:
  13. Your Matrix server should not have a new user called "Discord bridge bot". Follow the official documentation to create bridged rooms.
  • No labels
