This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
Feature Status
N/A - Feature not yet available
OK - Initial tests successful
NOK - initial tests not successful
Highlight Colors:
  • Yellow - partially working
  • Green - Working
  • Red - Not working at the moment
Feature
v7.6v7.10v7.12v7.14
v7.15
v7.17
v7.18
v7.20
v7.21
v7.23
Winbox
BGP support
OSPF support
RIP support
Router ID support
Routing filter support
Generic
/31 address support
Convert route rules after upgrade from v6.x
Static IPv6 upgrade from ROS v6
IPv4 Route Rules
IPv6 Route Rules
ECMP flags
dst@table
gateway@table
gateway%interface
recursive route over ipv6 LL address
3 level recursive gateway with ECMP
IPV6 ECMP
IPv6 connected ECMP
Addresses from same subnet to multiple interfaces
Show time when route was last updated
Check GatewayBFD not ready
Scope and target scope
IPv4 Mangle routing-mark
IPv6 Mangle routing-mark
Packet SRC addressDoes not work correctly with /32 addresses
Routing-table parameter for ping and telnet
Show if route is hardware acceleratedShows if route is candidate for HW acceleration
Custom route selection policy
IPv4 with IPv6 nexthops for RFC5549
Routing id
VRF
Management services support for VRFs telnet, ssh, api, www services can be set to listen on specific VRF
Dynamically import/export routes from one vrf to another within the same router
BFD
Initial support
OSPF
Convert OSPF config from v6 to v7 after upgrade
Known conversion problems:
  • NBMA neighbors place in backbone
  • ospf-v2 networks + interface may have issues
  • dynamic interfaces may have issues
  • MPLS PE CE features are not converted
OSPF neighbors in NSSA Area
OSPF in broadcast network
OSPF with routing filters
OSPF Virtual Link
OPSF input filtering
HMAC-SHA auth RFC5709Initial support
OSPF SNMP monitoring
BGP SNMP monitoring
For ipv4 sessions
IS-IS
IPv4
Initial support
IPv6
Traffic Engineering
BGP
Convert BGP config from v6 to v7 after upgrade
BGP Templates and dynamic peers
BGP connect listen on a network
BGP guess remote.as
Show from which peer route received
BGP Address Families
BGP input.accept-*
eBGP nexthop self
Input Filter
Output Filter
BGP Local address auto selection
BGP route reflect
BGP route server
BGP Roles
https://datatracker.ietf.org/doc/draft-ietf-idr-bgp-open-policy/?include_text=1
rfc roles not fully implemented
BGP session uptime in "established" state
BGP session last established time
BGP Flow SpecFlow spec attributes are forwarded
BGP Selection
BGP Multipath and Addpath
BGP Confederation
BGP Aggregation
BGP ORF
Discard prefix RTBH  RFC 6666
AS-wide Unique BGP Identifier RFC 6286
Exported PDU PCAP saver
Exported PDU PCAP loader
BGP Advertisement monitoringAdvertisements rework
BGP Prefix limit
BGP advertise IPv4 prefix with IPv6 nexthop (RFC5549, RFC8950)
AFI/SAFI 1/1
BGP VPNv6 support
Prerequisites are made, need to add actual BGP Afi
BGP Instance config
EVPN
Initial support
MPLS
Static label mapping
Static mapping upgrade from v6
LDP IPv4 mapping
LDP IPv6 mapping
LDP signaled VPLS
LDP config upgrade from v6
LDP Dual Stack
TE
TE Config upgrade from v6
VPLS Encap to TE
BGP signaled VPLS
VPLS config upgrade from v6
RSVP Fast reroute
FRR/RI-RSVP (RFC 8370)
MPLS ECMP
One label per VRF
Ability to use MPLS EXP-bit in Queues
MPLS Fast-Path
RPKI session
RPKI possibility to view received info of specific prefix
RPKI show connection status
Filters
Convert routing filters after upgrade from v6.x
Syntax completion
Routing filter chain drop by default without rules
Routing filter prefix match
Routing filter protocol match
Routing filter append communities
Routing filter append large community
Routing filter set weight
Routing filter set local pref
Routing filter set MED
Routing filter set origin
Routing filter set igp metric from OSPF cost
Routing filter match prefix with address list
Routing filter match community/large community lists
Routing filter add a prefix to address list
Routing filter validate prefix with RPKI
Multicast
IGMP-Proxy
PIM-SM
Performance Status
Used hardware:
  • CCR1036, 16GB RAM (tile)
  • CCR2004(arm64)
  • CCR1100AHx4(arm)
  • Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz 32GB RAM (as a host for CHRs)
The simulated upstream peer is a CHR router running ROSv6 with a copy of the global IPv4 routing table (585K routes loaded from MRT dump).
One Peer Receive Only
DUT establishes a connection to simulated upstream peers, receives routes, and installs them in FIB.
v6.44v7.1beta3v7.1rc7v7.15.3 (1008427 routes)v7.16 (1008427 routes)
CCR0:40 - 2:120:46
RB1100x4 1.4GHz0:32-0:380:23
CCR20040:320:18
x86 (CHR)0:20
RB450G (in/out affinity=alone)after trying for 9min - ran out of memory at 558K routes2:02 (121MB free)
RB450G (in/out affinity=main)-1:54
RB450G (affinity in=alone out=input)-2:12
CCR2116
0:360:34
CCR2216
0:390:34
CCR2216 (150 regexp as-path rules)
2:09
Two Peers Receive Only
DUT establishes a connection to two simulated upstream peers, receives routes, picks the best route, and installs in FIB. On ROSv7 affinity settings are set to "alone".
v6.44FRRv7.1beta3v7.1rc7 (846k routes per peer)
CCR1:01 - 2:45
1:11
RB1100x4 1.4GHz0:51
0:30
CCR20040:51
0:290:33
router x
0:40
x86 (CHR)0:25
x86 (virtual)
0:26(4cores)
0:46(2cores)
0:30(2cores no LDP)
Multi-homing Sim
Two DUT devices establish eBGP sessions to simulated x86 upstream routers. Both DUTs are interconnected with the iBGP session. Each DUT receives routes from upstream and readvertises routes over iBGP. On ROSv7 affinity, settings are set to "alone" and early-cut disabled.
  • Route Provider: CHR (ROSv6 585K routes)
  • DUT_1: CCR1036
  • DUT_2: CCR1036
v7.1beta31:11
v7.1beta21:29
v6.xx1:02 - 8:30
  • DUT_1: CCR2004
  • DUT_2: RB1100AHx2
v7.1beta30:36
v6.xx0:59
  • Route Provider: CCR2216 (ROSv7.16 1008427 routes)
  • DUT_1: CCR2216
  • DUT_2: CCR2116
TimeMem
v7.15.30:59285MB
v7.160:48297MB
Route Server
TimeMem
v7.15.3--MB
v7.16-
-MB
Memory Usage:
Columns: TASKS, PRIVATE-MEM-BLOCKS, SHARED-MEM-BLOCKS, PSS, RSS, VMS, RETIRED, ID, PID, RPID, PROCESS-TIME, KERNEL-TIME, CUR-BUSY, MAX-BU>
   #  TASKS                         PRIVATE-M  SHARED-M  P  R  V  RE  ID       PID  R  PROCESS-  KERNEL-  CUR  MAX-BUS  CUR  MAX-CALC
   0  routing tables                12.0MiB    30.2MiB   0  0  0  12  main     111  0  8s980ms   2s60ms   0ms  1s320ms  0ms  10s700ms
      rib
      connected networks
   1  fib                           2816.0KiB  0         0  0  0      fib      130  1  3s        4s660ms       7s220ms       7s220ms
   2  ospf                          512.0KiB   256.0KiB  0  0  0      ospf     137  1  1s220ms   130ms         980ms         1s40ms
      connected networks
   3  fantasy                       256.0KiB   0         0  0  0      fantasy  138  1  60ms      80ms          40ms          40ms
   4  configuration and reporting   3840.0KiB  512.0KiB  0  0  0      static   139  1  1s270ms   110ms         260ms         260ms
   5  rip                           512.0KiB   0         0  0  0      rip      136  1  120ms     70ms          60ms          120ms
      connected networks
   6  routing policy configuration  768.0KiB   768.0KiB  0  0  0      policy   133  1  2s290ms   3s170ms       80ms          80ms
   7  BGP service                   768.0KiB   0         0  0  0      bgp      134  1  2s760ms   5s480ms       20ms          60ms
      connected networks
   8  BFD service                   512.0KiB   0         0  0  0      12       135  1  100ms     90ms          40ms          120ms
      connected networks
   9  BGP Input 10.155.101.186      3072.0KiB  6.2MiB    0  0  0      20       183  1  1s350ms   1s190ms       20ms          20ms
  10  BGP Output 10.155.101.186     5.5MiB     0         0  0  0      21       184  1  5s400ms   500ms         3s880ms       3s880ms
  11  BGP Input 10.155.101.232      3072.0KiB  6.2MiB    0  0  0      22       187  1  970ms     740ms         20ms          20ms
  12  BGP Output 10.155.101.232     8.2MiB     0         0  0  0      23       188  1  10s830ms  960ms         7s            7s
  13  Global memory                            256.0KiB               global     0  0
