This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
Introduction
Elasticsearch is a popular NoSQL database that can be used to store a wide range of data, including Syslog data. Alongside with Kibana you can create a powerful tool to analyze Syslog data from your RouterOS devices. This guide will rely on Elasticsearch integrations and for it to work you need to have a working Elasticsearch setup. This guide will not cover setup instructions for Elasticsearch and Kibana, but will cover the relevant steps to setup Syslog data collection and analysis.
There are many possible configurations that can be made with Elasticsearch, but for the sake of this guide we will use the following principle:
  • A RouterOS (10.0.0.1) device sends out Syslog data to a server (10.0.0.2) running Custom UDP logs
  • The server (10.0.0.2) running Custom UDP logs integration ingests Syslog data, processes the data and sends it to a Fleet Server (10.0.0.3)
  • A Fleet Server (10.0.0.3) stores the data in Elasticsearch (10.0.0.4)
  • Kibana (10.0.0.5) retrieves data from Elasticsearch (10.0.0.4), analyzes it and allows you to search the data
This guide will not use Logstash as a part of analyzing Syslog data, it has been replaced by a Fleet Server.
It is possible to install Elasticsearch, Kibana, Fleet Server and Custom UDP logs integration on the same device.
Prerequisites
  • Setup Elasticsearch
    Elasticsearch is widely supported on many platforms. It is recommended to setup a cluster of Elasticsearch nodes.
  • Setup kibana
    Kibana can be installed on the same device on which you installed Elasticsearch, but it can also be installed on a separate device for performance reasons. While it is possible to analyze Syslog data without Kibana, it requires writing your own API requests, Kibana is very easy to use and has a wide range of features.
  • Setup Fleet Server
    It is possible to setup Fleet Server on the same device on which you installed Elasticsearch and/or Kibana. It is recommended to install Fleet Server on a different device. Refer to Elasticsearch manual for recommendations on hardware and topology requirements.
Setup
The setup instructions are divided into two parts: Elastic (configuration regarding Elasticsearch, Kibana and Fleet Server) and RouterOS (configuration that is relevant to your RouterOS device).
Elastic
Some steps might change over time, refer to Elastic's manual to find the most up-to-date steps.
  1. Log into your Kibana
  2. Open the Fleet section under the main menu
  3. Open the "Agent policies" section
  4. Press "Create agent policy" button to create a new Agent Policy
  5. Give the policy a name, for example, "Syslog policy", adjust advance settings if required, create the policy. Or you can use the API request below:
    sads
    POST kbn:/api/fleet/agent_policies
      "name": "Syslog policy",
      "description": "",
      "namespace": "default",
      "monitoring_enabled": [
        "logs",
        "metrics"
      "inactivity_timeout": 1209600,
      "is_protected": false
  6. Open your newly created policy by clicking on it's name
  7. Press "Add integration"
  8. Search for "Custom UDP logs" and press "Add Custom UDP logs"
  9. Adjust configuration, make sure:
    - Specify "Listen Address" to the IP address of your server that is going to run the Custom UDP logs integration , in this example the address should be "10.0.0.2"
    - Set "Listen Port" to "5514"
    - Set" Dataset name" to "routeros"
    - Set "Ingest Pipeline" to "logs-routeros@custom"
    - Set "Syslog Parsing" to "Yes"
  10. Save the integration
  11. Press the "Add Elastic Agent to your host" button
  12. Follow the instructions on how to add Elastic Agent to your host
    Official Elastic's manual recommends installing the Elastic Agent as Fleet-managed. Consider following the recommendation since managing the agents is easier when they are Fleet-managed.
  13. Go to "Stack Management" on the main menu, then open "Ingest Pipelines"
  14. Create a new Ingest Pipeline by pressing "Create pipeline" then "New pipeline"
  15. Set "Name" to "logs-routeros@custom"
  16. Press "Import processors" and paste the following processors:
    	"processors": [
    			"grok": {
    			"field": "message",
    			"patterns": [
    				"^first L2TP UDP packet received from %{IP:source.ip}$",
    				"^login failure for user %{USERNAME:user.name} from %{IP:source.ip} via %{DATA:service.name}$",
    				"^%{USERNAME:user.name} logged in, %{IP:client.ip} from %{IP:source.ip}$",
    				"^dhcp alert on %{DATA}: discovered unknown dhcp server, mac %{MAC:source.mac}, ip %{IP:source.ip}$",
    				"in:%{DATA} out:%{DATA}, ?(connection-state:%{DATA},|)?(src-mac %{MAC:source.mac},|) proto %{DATA:network.transport} \\(%{DATA}\\), %{IP:source.ip}:?(%{INT:source.port}|)->%{IP:destination.ip}:?(%{INT:destination.port}|), len %{INT:network.bytes}$",
    				"in:%{DATA} out:%{DATA}, ?(connection-state:%{DATA},|)?(src-mac %{MAC:source.mac},|) proto %{DATA:network.transport}, %{IP:source.ip}:?(%{INT:source.port}|)->%{IP:destination.ip}:?(%{INT:destination.port}|), len %{INT:network.bytes}$",
    				"^%{DATA:network.name} (deassigned|assigned) %{IP:client.ip} for %{MAC:client.mac} %{DATA}$",
    				"^%{DATA:user.name} logged out, %{INT:event.duration} %{INT} %{INT} %{INT} %{INT} from %{IP:client.ip}$",
    				"^user %{DATA:user.name} logged out from %{IP:source.ip} via %{DATA:service.name}$",
    				"^user %{DATA:user.name} logged in from %{IP:source.ip} via %{DATA:service.name}$",
    				"^%{DATA:network.name} client %{MAC:client.mac} declines IP address %{IP:client.ip}$",
    				"^%{DATA:network.name} link up \\(speed %{DATA}\\)$",
    				"^%{DATA:network.name} link down$",
    				"^user %{DATA:user.name} authentication failed$",
    				"^%{DATA:network.name} fcs error on link$",
    				"^phase1 negotiation failed due to time up %{IP:source.ip}\\[%{INT:source.port}\\]<=>%{IP:destination.ip}\\[%{INT:destination.port}\\] %{DATA}:%{DATA}$",
    				"^%{DATA:network.name} (learning|forwarding)$",
    				"^user %{DATA:user.name} is already active$",
    				"^%{GREEDYDATA}$"
    			"lowercase": {
    			"field": "network.transport",
    			"ignore_missing": true
    			"append": {
    			"ignore_failure": true,
    			"field": "event.category",
    			"description": "Enrich logon events",
    			"allow_duplicates": false,
    			"value": [
    				"authentication"
    			"if": "ctx.message =~ /(login failure for user|logged in from|logged in,)/"
    			"append": {
    			"field": "event.outcome",
    			"description": "Enrich successful login events",
    			"value": [
    				"success"
    			"if": "ctx.message =~ /(logged in from|logged in,)/"
    			"append": {
    			"description": "Enrich failed login events",
    			"value": [
    				"failure"
    			"if": "ctx.message =~ /(login failure for user)/"
    			"append": {
    			"description": "Enrich network events",
    			"value": [
    				"network"
    			"if": "ctx.message =~ /( fcs error on link| link down| link up)/"
    			"append": {
    			"description": "Enrich network failures",
    			"value": [
    				"failure"
    			"if": "ctx.message =~ /( fcs error on link)/"
    			"append": {
    			"value": [
    				"session"
    			"if": "ctx.message =~ /(logged out)/"
    			"append": {
    			"value": [
    				"threat"
    			"if": "ctx.message =~ /(from address that has not seen before)/"
    			"append": {
    			"field": "service.name",
    			"value": [
    				"l2tp"
    			"if": "ctx.message =~ /(^L2TP\\/IPsec VPN)/"
    			"geoip": {
    			"ignore_missing": true,
    			"field": "source.ip",
    			"target_field": "source.geo"
    			"geoip": {
    			"field": "destination.ip",
    			"target_field": "destination.geo"
    			"geoip": {
    			"field": "client.ip",
    			"target_field": "client.geo"
  17. Press "Save pipeline"
  18. Go to "Stack Management" on the main menu, then select "Index Management" and then select "Component templates"
  19. Create a new template by pressing "Create component template".
  20. Set the "Name" to "logs-routeros@custom"
  21. Under "Index settings" section, paste the following:
      "index": {
        "lifecycle": {
          "name": "logs"
        "default_pipeline": "logs-routeros@custom"
    Change the ILM policy to your required policy name. The "logs" is the default policy that might be in use for other logs.
  22. Under "Mappings" section, press "Load JSON" and paste the following:
      "dynamic_templates": [],
      "properties": {
        "service": {
          "type": "object",
          "properties": {
            "name": {
              "type": "keyword"
        "destination": {
          "type": "object",
          "properties": {
            "port": {
              "type": "long"
            "ip": {
              "type": "ip"
        "host": {
          "type": "object",
          "properties": {
            "ip": {
              "type": "ip"
        "client": {
          "type": "object",
          "properties": {
            "ip": {
              "type": "ip"
            "mac": {
              "type": "keyword"
        "source": {
          "type": "object",
          "properties": {
            "geo": {
              "type": "object",
              "properties": {
                "continent_name": {
                  "ignore_above": 1024,
                  "type": "keyword"
                "region_iso_code": {
                  "type": "keyword"
                "city_name": {
                  "type": "keyword"
                "country_iso_code": {
                  "type": "keyword"
                "country_name": {
                  "type": "keyword"
                "location": {
                  "type": "geo_point"
                "region_name": {
                  "type": "keyword"
            "as": {
              "type": "object",
              "properties": {
                "number": {
                  "type": "long"
                "organization": {
                  "type": "object",
                  "properties": {
                    "name": {
                      "type": "keyword",
                      "fields": {
                        "text": {
                          "type": "match_only_text"
            "address": {
              "type": "keyword"
            "port": {
              "type": "long"
            "domain": {
              "type": "keyword"
            "ip": {
              "type": "ip"
            "mac": {
              "type": "keyword"
        "event": {
          "type": "object",
          "properties": {
            "duration": {
              "type": "long"
            "category": {
              "type": "keyword"
            "outcome": {
              "type": "keyword"
        "message": {
        "user": {
          "type": "object",
          "properties": {
            "name": {
              "type": "keyword"
        "network": {
          "type": "object",
          "properties": {
            "bytes": {
              "type": "long"
            "name": {
              "type": "keyword"
            "transport": {
              "type": "keyword"
        "tags": {
          "type": "keyword"
  23. Press "Next" and then press "Save component template"
    If a component template exists with such a name, then edit the existing one instead.
  24. Go to "Stack Management" on the main menu, then select "Index Management" and then select "Index templates"
  25. Create a new template by pressing "Create template"
  26. Set the "Name" to "logs-routeros"
  27. Set "Index patterns" to "logs-routeros-*"
  28. Under "Component templates" section add the following templates to your new Index template:
    logs@settings
    ecs@mappings
  29. Press "Next" and then "Save template"
  30. Make sure you have opened the 5514/UDP port on your host and elsewhere in the path from your RouterOS device (10.0.0.1).
  31. Your Elastic Agent is now ready to receive Syslog data!
RouterOS
  1. Configure Logging action settings on your RouterOS Device (10.0.0.1):
    /system logging action
    set [find where name="remote"] bsd-syslog=yes remote=10.0.0.2 remote-port=5514 syslog-facility=syslog
  2. Add Topics that you wish to receive from RouterOS device (10.0.0.1), for example:
    /system logging
    add action=remote topics=info
    add action=remote topics=error
    add action=remote topics=critical
    add action=remote topics=warning
    add action=remote topics=bridge,stp
  3. You should now start to see Syslog data being ingested!
  4. Continue the guide to start using Kibana
Using Kibana
Kibana allows you to search the ingested Syslog data, to see ingested logs do the following:
  2. Open "Discover" from the main menu
  3. Add a filter, use the following parameters:
    Select a field: data_stream.dataset
    Select operator: IS
    Select a value: routeros
  4. For simplicity we recommend searching for fields in the  Discover menu and searching for "message", then adding the field to the view
  5. We also recommend searching for "log.syslog.hostname" field and adding to the view as well.
  6. Consider saving the search for easier access later
  7. Done!
While searching for logs can be useful, you are more likely looking for a way to create alerts for certain activities and create connectors to send alerts e-mail, webhooks, chats and other options. Consider enabling the Spike in failed logon events rule to alert for excessive failed login attempts. You can also create a threshold rule and set it to alert after fixed amount of failed logins.
  • No labels
