Introduction
MikroTik product naming can be confusing at first glance, but all the product codes have a logical explanation and follow a code.
RouterBOARD products naming details
RouterBOARD (short version RB)
<board name> <board features>-<built-in wireless> <wireless card features>-<connector type>-<enclosure type>
Board Name
Currently, there can be three types of board names:
  • 3-symbol name
    • 1st symbol stands for series (this can either be a number or a letter); New additions: D - Dakota; C - Cypress; S - Chateau; L - Maple;
    • 2nd digit for indicating the number of potential wired interfaces (Ethernet, SFP, SFP+)
    • 3rd digit for indicating the number of potential wireless interfaces (built-in and mPCI and mPCIe slots)
  • Word - currently used names are: OmniTIK, Groove, SXT, SEXTANT, Metal, LHG, DynaDish, cAP, wAP, LDF, DISC, mANTBox, QRT, DynaDish, cAP, hAP, hEX. If the board has fundamental changes in hardware (such as completely different CPU) revision version will be added at the end
  • Exceptional naming - 600, 800, 1000, 1100, 1200, 2011, 3011, 4011 boards are standalone representatives of the series or have more than 9 wired interfaces, so the name was simplified to full hundreds or development year.
Board Features
Board features follow immediately after board name section (no spaces or dashes), except when board name is a word, then board features are separated by space.
Currently used features (listed in the order they are used):
  • U - USB
  • P - power injection with a controller
  • i - single port power injector without a controller
  • A - more memory and (or) higher license level
  • H - more powerful CPU
  • G - Gigabit (may include "U","A","H", if not used with "L")
  • L - Lite edition
  • D - addition Disk for storage (SSD or M.2)
  • S - SFP port (legacy usage - SwitchOS devices)
  • e - PCIe interface extension card
  • x<N> - where N is number of CPU cores ( x2, x16, x36, etc)
  • R - MiniPCIe slot with both USB and PCIe lines
  • M - M.2 slot with both USB and PCIe lines
Built-in wireless details
If the board has built-in wireless, then all its features are represented in the following format:
<band><power_per_chain><protocol><number_of_chains>
  • band
    • 6 - 6Ghz
    • 5 - 5Ghz
    • 2 - 2.4Ghz
    • 52 - dual-band 5Ghz and 2.4Ghz
  • power per chain
    • (not used) - "Normal" - <23dBm at 6Mbps 802.11a; <24dBm at 6Mbps 802.11g
    • H - "High" - 23-24dBm at 6Mbps 802.11a; 24-27dBm at 6Mbps 802.11g
    • HP - "High Power" - 25-26dBm 6Mbps 802.11a; 28-29dBm at 6Mbps 802.11g
    • SHP - "Super High Power" - 27+dBm at 6Mbps 802.11a; 30+dBm at 6Mbps 802.11g
  • protocol
    • (not used) - for cards with only 802.11a/b/g support
    • n - for cards with 802.11n support
    • bn - for interfaces with 802.11bn support
    • ac - for cards with 802.11ac support
    • ax - for cards with 802.11ax support
  • number_of_chains
    • (not used) - single chain
    • D - dual chain
    • T - triple chain
  • connector type
    • (not used) - only one connector option on the model
    • MMCX - MMCX connector type
    • u.FL - u.FL connector type
Enclosure type
  • (not used) - the main type of enclosure for a product
  • BU - board unit (no enclosure) - for a situation when a board-only option is required, but the main product already comes in the case
  • RM - rack-mount enclosure
  • IN - indoor enclosure
  • EM - extended memory
  • LM - lite memory
  • BE - black edition case
  • TC - Tower (vertical) case
  • PC - PassiveCooling enclosure (for CCR)
  • TC - Tower (vertical) Case enclosure (for hEX, hAP and other home routers.)
  • OUT - outdoor enclosure
More Specific types OUT enclosures are:
  • SA - sector antenna enclosure (for SXT)
  • HG - high gain antenna enclosure (for SXT)
  • BB - Basebox enclosure (for RB911)
  • NB - NetBox enclosure (for RB911)
  • NM - NetMetal enclosure (for RB911)
  • QRT - QRT enclosure (for RB911)
  • SX - Sextant enclosure (for RB911,RB711)
  • SXTsq - SXTsq enclosure
  • PB - PowerBOX enclosure (for RB750P, RB950P)
  • XL - extra large enclosure (bigger size LHG for example)
  • LTm - LtAP mini case,
  • LT - LtAP case
  • KN - KNOT case
Example
#1 decode RB912UAG-5HPnD naming:
  • RB (RouterBOARD)
  • 912 - 9th series board with 1 wired (ethernet) interface and two wireless interfaces (built-in and mini PCIe)
  • UAG - has a USB port, more memory, and gigabit ethernet port
  • 5HPnD - has built-in 5GHz high power dual chain wireless card with 802.11n support.
#2 decode RBD52G-5HacD2HnD-TC naming:
  • RouterBOARD (deprecated in new)
  • D - Dakota series CPU
  • 5 - wired interfaces
  • 2 - wireless interfaces
  • G - gigabit
  • 5HacD - has built-in 5GHz high power dual chain wireless card with 802.11ac support.
  • 2HnD  - has built-in 2.4GHz high power dual chain wireless card with 802.11n support.
  • TC - tower case
#3 decode C52iG-5HaxD2HaxD-TC naming:
  • C - Cypress series CPU
  • i - single port power injector without controller
  • G - gigabit
  • 5HaxD - has built-in 5GHz high power dual chain wireless card with 802.11ax support.
  • 2HaxD - has built-in 2.4GHz high power dual chain wireless card with 802.11ax support.
  • TC - tower case
CloudCoreRouter naming details
CloudCoreRouter (short version CCR) naming consists of:
<4 digit number>-<list of ports>-<enclosure type>
  • 4 digit number
    • 1st digit stands for series
    • 2nd (reserved)
    • 3rd-4th digit indicates the number of total CPU cores on the device
  • list of ports
    • -<n>G number of 1G Ethernet ports
    • -<n>P number of 1G Ethernet ports with PoE-out
    • -<n>C number of combo 1G Ethernet/SFP ports
    • -<n>S number of 1G SFP ports
    • -<n>G+ number of 2.5G Ethernet ports
    • -<n>P+ number of 2.5G Ethernet ports with PoE-out
    • -<n>C+ number of combo 10G Ethernet/SFP+ ports
    • -<n>S+ number of 10G SFP+ ports
    • -<n>XG number of 5G/10G Ethernet ports
    • -<n>XP number of 5G/10G Ethernet ports with PoE-out
    • -<n>XC number of combo 10G/25G SFP+ ports
    • -<n>XS number of 25G SFP+ ports
    • -<n>Q+ number of 40G QSFP+ ports
    • -<n>XQ number of 100G QSFP+ ports
    • -<n>DQ  number of 200G QSFP56 ports
    • -<n>DDQ number of 400G QSFP-DD ports
  • enclosure type - same as for RouterBOARD products.
CloudRouterSwitch and CloudSmartSwitch naming details
CloudRouterSwitch (short version CRS, RouterOS device) CloudSmartSwitch (short version CSS, SwOS device) naming consists of:
<3 digit number>-<list of ports>-<built-in wireless card>-<enclosure type>
  • 3 digit number
    • 2nd-3rd digit - total number of wired interfaces (Ethernet, SFP, SFP+)
  • list of ports
    • -<n>F number of 100M Ethernet ports
    • -<n>Fi number of 100M Ethernet ports with PoE-out injector
    • -<n>Fp number of 100M Ethernet ports with controlled PoE-out
    • -<n>Fr number of 100M Ethernet ports with Reverse PoE (PoE-in)
    • -<n>C+ number of combo 10G Ethernet/SFP ports
    • <n>DQ  number of 200G QSFP56 ports
  • built-in wireless card - same as for RouterBOARD products.
  • No labels
