R11e-LTE-US is a Cat-4 modem. It can be integrated into any MikroTik product that has a miniPCI-e slot.
R11e-LTE-US
R11e-LTE
R11e-4G
R11e-LTE6
Specifications
  • Interface – Mini-PCIe;
  • Temperature Operating -30°C .. +70°C
  • LTE Channel Bandwidth: 1.4/3/5/10/15/20 MHz
  • LTE Category: 4 (150Mbps Downlink, 50Mbps Uplink)
  • 3G Category: R7 (Cat14 - 21.1Mbps Downlink)
  • LTE (FDD) bands: 2/4/5/12 (1900/1700/850/700)
  • 3G bands: 2/5 (1900/850)
Installing the module in your device
R11e-TE-US for professional use. Each of the cards comes in ESD protective packaging. When handling electrical equipment please observe the following safety precautions:
  • Use a wrist grounding strap when unpacking and working with electrical components to avoid electrical discharge (ESD) damage;
  • After unpacking please place the card on the anti-static mat;
  • When installing make sure there are no objects that can damage or touch the PCB plate;
  • The card can be installed in your desired device using the factory provided screw holes in a PCB plate;
  • Locate miniPCIe slot on your device;
  • Unscrew two factory attached screws;
  • Optionally you can use the thermal pad by placing it under the card, the thermal pad is not included in the package;
  • Install the module to the miniPCIe slot and secure it with previously removed screws. Tightening torque 0,3 Nm;
  • Attach antenna cables to the connectors on the module:
When installing outdoors please ensure that the device case is waterproof and is designed for outdoor use.
Mounting and configuration of this device should be done by a qualified person.
Configuration
The device will be automatically recognized when used in a  MikroTik RouterOS powered device. Configuration can be set in the “Wireless” menu. More information about the configuration of LTE can be found in our documentation: https://wiki.mikrotik.com/wiki/Manual:Interface/LTE
The device is tested with RouterOS v6 and above. It might be compatible with other operating systems, but drivers are not included with the card.
Operating system support
The module supports RouterOS. Other operating systems have not been tested.
Federal Communication Commission Interference Statement
ModelFCC ID
R11e-LTE-USTV7R11ELTE
R11e-LTENone
R11e-4GTV7R11E4G
R11e-LTE6TV7R11ELTE6
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation.
This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the equipment and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the dealer or an experienced radio/TV technician for help.
FCC Caution: Any changes or modifications not expressly approved by the party responsible for compliance could void the user's authority to operate this equipment.
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
This device and its antenna must not be co-located or operation in conjunction with any other antenna or transmitter.
IMPORTANT: Exposure to Radio Frequency Radiation.
0,29m minimum distance has to be maintained between the antenna and the occupational user and 0,64m to the general public. Under such configuration, the FCC radiation exposure limits set forth for a population/uncontrolled environment can be satisfied.
Antenna Installation WARNING
It is the installer's responsibility to ensure that when using the authorized antennas in the United States (or where FCC rules apply); only those antennas certified with the product are used. The use of any antenna other than those certified with the product is expressly forbidden in accordance with FCC rules CFR47 part 15.204. The installer should configure the output power level of antennas, according to country regulations and per antenna type.
Innovation, Science and Economic Development Canada
ModelFCC ID
R11e-LTE-US7442A-R11ELTE
R11e-LTENone
R11e-4G7442A-R11E4G
R11e-LTE67442A-R11ELTE6
This device complies with Industry Canada's license-exempt RSS standard(s). Operation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of the device.
Le présent appareil est conforme aux CNR d'Industrie Canada applicables aux appareils radio exempts de licence. L'exploitation est autorisée aux deux conditions suivantes : (1) l'appareil ne doit pas produire de brouillage, et (2) l'utilisateur de l'appareil doit accepter tout brouillage radioélectrique subi, mźme si le brouillage est susceptible d'en compromettre le fonctionnement.
This Class B digital apparatus complies with Canadian ICES-003.
Cet appareil numérique de la classe [B] est conforme à la norme NMB-003 du Canada.
CAN ICES-003 (B) / NMB-003 (B)
Important Notice to OEM integrators
1. This module is limited to OEM installation ONLY.
2. This module is limited to installation in mobile or fixed applications, according to Part 2.1091(b).
3. The separate approval is required for all other operating configurations, including portable configurations with respect to Part 2.1093 and different antenna configurations
UKCA marking
Norma Oficial Mexicana
EFICIENCIA ENERGETICA CUMPLE CON LA NOM-029-ENER-2017.
La operacion de este equipo esta sujeta a las siguientes dos condiciones:
  • Es posible que este equipo o dispositivo no cause interferencia perjudicial y.
  • Este equipo debe aceptar cualquier interferencia, incluyendo la que pueda causar su operacion no deseada.
Fabricante: Mikrotikls SIA, Brivibas gatve 214i, Riga, LV-1039, Latvia.
País De Origen: Letonia; Lituania; China (Republica Popular); Estados Unidos De America; Mexico.
Por favor contacte a su distribuidor local para preguntas regionales específicas. La lista de importadores se puede encontrar en nuestra página de inicio – https://mikrotik.com/buy/latinamerica/mexico.
CE Declaration of Conformity
Manufacturer: Mikrotikls SIA, Brivibas gatve 214i Riga, Latvia, LV1039.
Hereby, Mikrotīkls SIA declares that the radio equipment type RouterBOARD is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://mikrotik.com/products
Operating Frequency / Maximum output power
Betriebsfrequenz / maximale Ausgangsleistung
Fréquence de fonctionnement / puissance de sortie maximale
Frequenza operativa / massima potenza di uscita
Frecuencia de funcionamiento / potencia de salida máxima
Рабочая частота / максимальная выходная мощность
E-GSM-900900 MHz / 33dB
DCS-18001800 MHz / 30dB
WCDMA Band I1922.4 MHz / 24dB ± 2.7 dB
WCDMA Band VIII882.4 MHz / 24dB ± 2.7 dB
LTE Band 12100 MHz / 23dB ± 2.7 dB
LTE Band 31700 MHz / 23dB ± 2.7 dB
LTE Band 72600 MHz / 23dB ± 2.7 dB
LTE Band 8900 MHz / 23dB ± 2.7 dB
LTE Band 20800 MHz / 23dB ± 2.7 dB
LTE Band 382600 MHz / 23dB ± 2.7 dB
LTE Band 402300 MHz / 23dB ± 2.7 dB
This MikroTik device meets Maximum LTE transmit power limits per ETSI regulations. For more detailed information see Declaration of Conformity above / Dieses MikroTik-Gerät erfüllt die maximalen LTE-Sendeleistung Grenzwerte gemäß ETSI-Bestimmungen. Weitere Informationen finden Sie oben unter Konformitätserklärung / Cet appareil MikroTik respecte les limites maximales de puissance de transmission LTE conformément aux réglementations ETSI. Pour plus d'informations, voir la déclaration de conformité ci-dessus / Questo dispositivo MikroTik è conforme ai limiti massimi di potenza di trasmissione LTE in conformità con le normative ETSI. Per ulteriori informazioni, consultare la dichiarazione di conformità sopra / Este dispositivo MikroTik cumple con los límites máximos de potencia de transmisión LTE de acuerdo con las regulaciones ETSI. Para obtener más información, consulte la declaración de conformidad anterior / Это устройство MikroTik соответствует максимальным пределам мощности передачи LTE в соответствии с правилами ETSI. Для получения дополнительной информации см. Декларацию соответствия выше.
