2.3.1
- Improved device performance.
2.3.0
- Upgraded Bluetooth stack version.
2.2.0
- Added support for non-standard advertising intervals.
2.1.0
- Fixed timing inconsistencies after wake-up from the factory sleep mode.
- Improved LED behavior before the device enters the configuration mode.
2.0.0
- Restriction to set the wake-up threshold to 0g.
- Added Write Protection feature.
- Increase the minimal valid value of the wake-up threshold.
1.6.0
- Improved Data Log stability.
Added an option to allow users to manually calibrate the sensor's temperature (offset).
1.5.0
- Added a new trigger Impact.
- Added Data Logs.
1.4.0
- Added an option to reset the device back into the advertising mode.
- Added an option to clear saved log messages.
- Added a Unix Time parameter.
