Overview
The IS-IS (Intermediate System - Intermediate System) protocol is an Interior Gateway Protocol (IGP) used to distribute IP routing information throughout a single Autonomous System.
It was originally developed as a routing protocol for CLNP but later extended to include IP routing when IP became popular. An extended version is sometimes referred to as Integrated IS-IS.
IS-IS belongs to the link-state protocol family, which exchanges topology information between nearest neighbors and floods it throughout the AS. The main advantage is that complete knowledge of the network topology allows one to choose the best path to the destination. It can also be useful for traffic engineering purposes.
Neighbours periodically exchange Hello packets, forms adjacency and selects designated IS based on the negotiation. Hello packets are sent individually for Level-1 and Level-2.
Standards and Technologies:
- RFC 1195 Use of OSI IS-IS for Routing in TCP/IP and Dual Environments
- RFC 5302 Domain-Wide Prefix Distribution with Two-Level IS-IS
- RFC 5303 Three-Way Handshake for IS-IS Point-to-Point Adjacencies
- RFC 5305 IS-IS Extensions for Traffic Engineering (only wide metric support)
- RFC 5308 Routing IPv6 with IS-IS
IS-IS Terminology
- IS - Intermediate System is a router capable of forwarding traffic between distantly located hosts.
- LSP - Link State PDU contains information on the router's local state (usable interfaces, reachable neighbours, and the cost of the interfaces)
- SPF - Shortest-path-first algorithm
- DIS - designated intermediate system. DIS ensures that all routes in the network maintain synchronised database. Separate DISs are elected for L1 and L2 routing. Election of the DIS is based on the highest interface priority.
- Level-1 (L1) routing - Controls distribution of routing information within an IS-IS area. L1 routing is based on system ID.
- Level-2 (L2) routing - Controls distribution of routing information between IS-IS areas. L2 routing is based on area ID.
- IS-IS Adjacency - link between IS-IS neighbours. The type of adjacency formed depends on the parameters exchanged in the IS-IS Hello packets. Each of the the adjacent routers runs the DIS election process to determine whether it is eligible to be an L1 or L2 DIS on the broadcast network.
Basic Configuration Example
Basic IS-IS setup between three routers.
R1:
/routing isis instance add afi=ip areas=49.2222 disabled=no name=isis-instance-1 system-id=90ab.cdef.0001 /routing isis interface-template add instance=isis-instance-1 interfaces=ether1 levels=l1,l2 [] /routing/isis/neighbor> print 0 instance=isis-instance-1 interface=ether1 level-type=l2 snpa=08:00:27:22:B4:A2 srcid="1111.2222.aded" state=up 1 instance=isis-instance-1 interface=ether1 level-type=l2 snpa=D4:CA:6D:78:2F:2E srcid="1111.2222.cded" state=up 2 instance=isis-instance-1 interface=ether1 level-type=l1 snpa=08:00:27:22:B4:A2 srcid="1111.2222.aded" state=up 3 instance=isis-instance-1 interface=ether1 level-type=l1 snpa=D4:CA:6D:78:2F:2E srcid="1111.2222.cded" state=up [] /routing/route> print where is-is Flags: A - ACTIVE; i - IS-IS Columns: DST-ADDRESS, GATEWAY, AFI, DISTANCE, SCOPE, TARGET-SCOPE, IMMEDIATE-GW DST-ADDRESS GATEWAY AFI DISTANCE SCOPE TARGET-SCOPE IMMEDIATE-GW i 0.0.0.0/0 10.155.101.214%ether1 ip4 115 20 10 10.155.101.214%ether1 i 10.155.101.0/24 10.155.101.216%ether1 ip4 115 20 10 10.155.101.216%ether1 Ai 10.255.255.162/32 10.155.101.216%ether1 ip4 115 20 10 10.155.101.216%ether1
R2:
/routing isis instance add afi=ip areas=49.2222 disabled=no l1.originate-default=always l2.originate-default=always name=isis-instance-1 \ system-id=1111.2222.cded /routing isis interface-template add instance=isis-instance-1 interfaces=sfp12 levels=l1,l2 add instance=isis-instance-1 interfaces=lo levels=l2 [] /routing/isis/neighbor> print 0 instance=isis-instance-1 interface=sfp12 level-type=l1 snpa=08:00:27:22:B4:A2 srcid="1111.2222.aded" state=up 1 instance=isis-instance-1 interface=sfp12 level-type=l1 snpa=C4:AD:34:43:EA:5C srcid="90ab.cdef.0001" state=up 2 instance=isis-instance-1 interface=sfp12 level-type=l2 snpa=08:00:27:22:B4:A2 srcid="1111.2222.aded" state=up 3 instance=isis-instance-1 interface=sfp12 level-type=l2 snpa=C4:AD:34:43:EA:5C srcid="90ab.cdef.0001" state=up
R3 Cisco:
interface Loopback0 ip address 10.255.255.162 255.255.255.255 ip router isis ! interface GigabitEthernet1 ip address dhcp ip router isis negotiation auto ! router isis net 49.2222.1111.2222.aded.00 ! # show isis neighbors Tag null: System Id Type Interface IP Address State Holdtime Circuit Id 90AB.CDEF.0001 L1 Gi1 10.155.101.183 UP 27 1111.2222.CDED.01 90AB.CDEF.0001 L2 Gi1 10.155.101.183 UP 27 1111.2222.CDED.01 1111.2222.CDED L1 Gi1 10.155.101.214 UP 9 1111.2222.CDED.01 1111.2222.CDED L2 Gi1 10.155.101.214 UP 9 1111.2222.CDED.01 # show ip route i*L1 0.0.0.0/0 [115/11] via 10.155.101.214, 4w5d, GigabitEthernet1 10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks C 10.155.101.0/24 is directly connected, GigabitEthernet1 L 10.155.101.216/32 is directly connected, GigabitEthernet1 i L2 10.155.255.214/32 [115/10] via 10.155.101.183, 2w3d, GigabitEthernet1
