Summary
The Cloud Router Switch series are highly integrated switches with high-performance MIPS CPU and feature-rich packet processors. The CRS switches can be designed into various Ethernet applications including unmanaged switch, Layer 2 managed switch, carrier switch, and wireless/wired unified packet processing. See Cloud Router Switch configuration examples
This article applies to CRS1xx and CRS2xx series switches and not to CRS3xx series switches. For CRS3xx series devices, read the CRS3xx, CRS5xx series switches and CCR2116, CCR2216 routers manual.
Features | Description |
Forwarding |
Mirroring |
VLAN |
Port Isolation and Leakage |
Trunking |
Quality of Service (QoS) |
Shaping and Scheduling |
Access Control List |
Cloud Router Switch models
This table clarifies the main differences between Cloud Router Switch models.
Model | Switch Chip | CPU | Wireless | SFP+ port | Access Control List | Jumbo Frame (Bytes) |
CRS105-5S-FB | QCA-8511 | 400MHz | - | - | + | 9204 |
CRS106-1C-5S | QCA-8511 | 400MHz | - | - | + | 9204 |
CRS112-8G-4S | QCA-8511 | 400MHz | - | - | + | 9204 |
CRS210-8G-2S+ | QCA-8519 | 400MHz | - | + | + | 9204 |
CRS212-1G-10S-1S+ | QCA-8519 | 400MHz | - | + | + | 9204 |
CRS226-24G-2S+ | QCA-8519 | 400MHz | - | + | + | 9204 |
CRS125-24G-1S | QCA-8513L | 600MHz | - | - | - | 4064 |
CRS125-24G-1S-2HnD | QCA-8513L | 600MHz | + | - | - | 4064 |
CRS109-8G-1S-2HnD | QCA-8513L | 600MHz | + | - | - | 4064 |
Abbreviations and Explanations
CVID - Customer VLAN id: inner VLAN tag id of the IEEE 802.1ad frame
SVID - Service VLAN id: outer VLAN tag id of the IEEE 802.1ad frame
IVL - Independent VLAN learning - learning/lookup is based on both MAC addresses and VLAN IDs.
SVL - Shared VLAN learning - learning/lookup is based on MAC addresses - not on VLAN IDs.
TPID - Tag Protocol Identifier
PCP - Priority Code Point: a 3-bit field which refers to the IEEE 802.1p priority
DEI - Drop Eligible Indicator
DSCP - Differentiated services Code Point
Drop precedence - internal CRS switch QoS attribute used for packet enqueuing or dropping.
Port Switching
To set up port switching on CRS1xx/2xx series switches, check the Bridge Hardware Offloading page.
Dynamic reserved VLAN entries (VLAN4091; VLAN4090; VLAN4089; etc.) are created in the CRS switch when switched port groups are added when a hardware offloaded bridge is created. These VLANs are necessary for internal operation and have lower precedence than user-configured VLANs.
Multiple switch groups
The CRS1xx/2xx series switches allow you to use multiple bridges with hardware offloading, this allows you to easily isolate multiple switch groups. This can be done by simply creating multiple bridges and enabling hardware offloading.
Multiple hardware offloaded bridge configuration is designed as a fast and simple port isolation solution, but it limits a part of the VLAN functionality supported by the CRS switch chip. For advanced configurations use one bridge within the CRS switch chip for all ports, configure VLANs, and isolate port groups with port isolation profile configuration.
CRS1xx/2xx series switches can run multiple hardware offloaded bridges with (R)STP enabled, but it is not recommended since the device is not designed to run multiple (R)STP instances on a hardware level. To isolate multiple switch groups and have (R)STP enabled you should isolate port groups with port isolation profile configuration.
Global Settings
The CRS switch chip is configurable from the /interface ethernet switch
console menu.
Sub-menu: /interface ethernet switch
Property | Description |
name (string value; Default: switch1) | Name of the switch. |
bridge-type (customer-vid-used-as-lookup-vid | service-vid-used-as-lookup-vid; Default: customer-vid-used-as-lookup-vid) | The bridge type defines which VLAN tag is used as Lookup-VID. Lookup-VID serves as the VLAN key for all VLAN-based lookups. |
mac-level-isolation (yes | no; Default: yes) | Globally enables or disables MAC level isolation. Once enabled, the switch will check the source and destination MAC address entries and their isolation-profile from the unicast forwarding table. By default, the switch will learn MAC addresses and place them into a promiscuous isolation profile. Other isolation profiles can be used when creating static unicast entries. If the source or destination MAC address is located on a promiscuous isolation profile, the packet is forwarded. If both source and destination MAC addresses are located on the same community1 or community2 isolation profile, the packet is forwarded. The packet is dropped when the source and destination MAC address isolation profile is isolated , or when the source and destination MAC address isolation profiles are from different communities (e.g. source MAC address is community1 and destination MAC address is community2 ). When MAC level isolation is globally disabled, the isolation is bypassed. |
use-svid-in-one2one-vlan-lookup (yes | no; Default: no) | Whether to use service VLAN ID for 1:1 VLAN switching lookup. |
use-cvid-in-one2one-vlan-lookup (yes | no; Default: yes) | Whether to use customer VLAN ID for 1:1 VLAN switching lookup. |
multicast-lookup-mode (dst-ip-and-vid-for-ipv4 | dst-mac-and-vid-always; Default:dst-ip-and-vid-for-ipv4) | Lookup mode for IPv4 multicast bridging.
unicast-fdb-timeout (time interval; Default: 5m) | Timeout for Unicast FDB entries. |
override-existing-when-ufdb-full (yes | no; Default: no) | Enable or disable to override existing entry which has the lowest aging value when UFDB is full. |
drop-if-no-vlan-assignment-on-ports (ports; Default: none) | Ports which drop frames if no MAC-based, Protocol-based VLAN assignment or Ingress VLAN Translation is applied. |
drop-if-invalid-or-src-port- -not-member-of-vlan-on-ports (ports; Default: none) | Ports that drop invalid and other port VLAN ID frames. |
unknown-vlan-lookup-mode (ivl | svl; Default: svl) | Lookup and learning mode for packets with invalid VLAN. |
forward-unknown-vlan (yes | no; Default: yes) | Whether to allow forwarding VLANs that are not members of the VLAN table. |
bypass-vlan-ingress-filter-for (protocols; Default: none) | Protocols that are excluded from Ingress VLAN filtering. These protocols are not dropped if they have invalid VLAN. (arp, dhcpv4, dhcpv6, eapol, igmp, mld, nd, pppoe-discovery, ripv1) |
bypass-ingress-port-policing-for (protocols; Default: none) | Protocols that are excluded from Ingress Port Policing. (arp, dhcpv4, dhcpv6, eapol, igmp, mld, nd, pppoe-discovery, ripv1) |
bypass-l2-security-check-filter-for (protocols; Default: none) | Protocols that are excluded from Policy rule security check. (arp, dhcpv4, dhcpv6, eapol, igmp, mld, nd, pppoe-discovery, ripv1) |
ingress-mirror0 (port | trunk,format; Default: none,modified) | The first ingress mirroring analyzer port or trunk and mirroring format:
ingress-mirror1 (port | trunk,format; Default: none,modified) | The second ingress mirroring analyzer port or trunk and mirroring format:
ingress-mirror-ratio (1/32768..1/1; Default: 1/1) | The proportion of ingress mirrored packets compared to all packets. |
egress-mirror0 (port | trunk,format; Default: none,modified) | The first egress mirroring analyzer port or trunk and mirroring format:
egress-mirror1 (port | trunk,format; Default: none,modified) | The second egress mirroring analyzer port or trunk and mirroring format:
egress-mirror-ratio (1/32768..1/1; Default: 1/1) | Proportion of egress mirrored packets compared to all packets. |
mirror-egress-if-ingress-mirrored (yes | no; Default: no) | When a packet is applied to both ingress and egress mirroring, only ingress mirroring is performed on the packet, if this setting is disabled. If this setting is enabled both mirroring types are applied. |
mirror-tx-on-mirror-port (yes | no; Default: no) | |
mirrored-packet-qos-priority (0..7; Default: 0) | Remarked priority in mirrored packets. |
mirrored-packet-drop-precedence (drop | green | red | yellow; Default: green) | Remarked drop precedence in mirrored packets. This QoS attribute is used for mirrored packet enqueuing or dropping. |
fdb-uses (mirror0 | mirror1; Default: mirror0) | Analyzer port used for FDB-based mirroring. |
vlan-uses (mirror0 | mirror1; Default: mirror0) | Analyzer port used for VLAN-based mirroring. |
Port Settings
Sub-menu: /interface ethernet switch port
vlan-type (edge-port | network-port; Default: network-port) | Port VLAN type specifies whether VLAN ID is used in UFDB learning. The network port learns VLAN ID in UFDB, edge port does not - VLAN 0. It can be observed only in IVL learning mode. |
isolation-leakage-profile-override (yes | no; Default: !isolation-leakage-profile-override) isolation-leakage-profile (0..31;) | Custom port profile for port isolation/leakage configurations.
learn-override (yes | no; Default: !learn-override) learn-limit (1..1023; Default: !learn-limit) | Enable or disable MAC address learning and set the MAC limit on the port. MAC learning limit is disabled by default when !learn-override and !learn-limit are set. Property learn-override is replaced with learn under /interface bridge port menu since RouterOS v6.42. |
drop-when-ufdb-entry-src-drop (yes | no; Default: yes) | Enable or disable to drop packets when UFDB entry has action src-drop. |
allow-unicast-loopback (yes | no; Default: no) | Unicast loopback on port. When enabled, it permits sending back when the source port and destination port are the same for known unicast packets. |
allow-multicast-loopback (yes | no; Default: no) | Multicast loopback on port. When enabled, it permits sending back when the source port and destination port are the same for registered multicast or broadcast packets. |
action-on-static-station-move (copy-to-cpu | drop | forward | redirect-to-cpu; Default: forward) | Action for packets when UFDB already contains a static entry with such MAC but with a different port. |
drop-dynamic-mac-move (yes | no; Default: no) | Prevents MAC relearning until UFDB timeout if MAC is already learned on another port. |
allow-fdb-based-vlan-translate (yes | no; Default: no) | Enable or disable MAC-based VLAN translation on the port. |
allow-mac-based-service-vlan-assignment-for (all-frames | none | tagged-frame-only | untagged-and-priority-tagged-frame-only; Default: none) | Frame type for which applies MAC-based service VLAN translation. |
allow-mac-based-customer-vlan-assignment-for (all-frames | none | tagged-frame-only | untagged-and-priority-tagged-frame-only; Default: none) | Frame type for which applies MAC-based customer VLAN translation. |
default-customer-pcp (0..7; Default: 0) | Default customer PCP of the port. |
default-service-pcp (0..7; Default: 0) | Default service PCP of the port. |
pcp-propagation-for-initial-pcp (yes | no; Default: no) | Enables or disables PCP propagation for initial PCP assignment on ingress.
filter-untagged-frame (yes | no; Default: no) | Whether to filter untagged frames on the port. |
filter-priority-tagged-frame (yes | no; Default: no) | Whether to filter tagged frames with priority on the port. |
filter-tagged-frame (yes | no; Default: no) | Whether to filter tagged frames on the port. |
egress-vlan-tag-table-lookup-key (according-to-bridge-type | egress-vid; Default: egress-vid) | Egress VLAN table (VLAN Tagging) lookup:
egress-vlan-mode (tagged | unmodified | untagged; Default: unmodified) | Egress VLAN tagging action on the port. |
egress-pcp-propagation (yes | no; Default: no) | Enables or disables egress PCP propagation.
ingress-mirror-to (mirror0 | mirror1 | none; Default: none) | Analyzer port for port-based ingress mirroring. |
ingress-mirroring-according-to-vlan (yes | no; Default: no) | |
egress-mirror-to (mirror0 | mirror1 | none; Default: none) | Analyzer port for port-based egress mirroring. |
qos-scheme-precedence (da-based | dscp-based | ingress-acl-based | pcp-based | protocol-based | sa-based | vlan-based; Default: pcp-based, sa-based, da-based, dscp-based, protocol-based, vlan-based) | Specifies applied QoS assignment schemes on the ingress of the port.
pcp-or-dscp-based-qos-change-dei (yes | no; Default: no) | Enable or disable PCP or DSCP based DEI change on port. |
pcp-or-dscp-based-qos-change-pcp (yes | no; Default: no) | Enable or disable PCP or DSCP based PCP change on port. |
pcp-or-dscp-based-qos-change-dscp (yes | no; Default: no) | Enable or disable PCP or DSCP based DSCP change on port. |
dscp-based-qos-dscp-to-dscp-mapping (yes | no; Default: yes) | Enable or disable DSCP to internal DSCP mapping on port. |
pcp-based-qos-drop-precedence-mapping (PCP/DEI-range:drop-precedence; Default: 0-15:green) | The new value of drop precedence for the PCP/DEI to drop precedence (drop | green | red | yellow) mapping. Multiple mappings are allowed separated by a comma e.g. "0-7:yellow,8-15:red". |
pcp-based-qos-dscp-mapping (PCP/DEI-range:DEI; Default: 0-15:0) | The new value of DSCP for the PCP/DEI to DSCP (0..63) mapping. Multiple mappings are allowed separated by a comma e.g. "0-7:25,8-15:50". |
pcp-based-qos-dei-mapping (PCP/DEI-range:DEI; Default: 0-15:0) | The new value of DEI for the PCP/DEI to DEI (0..1) mapping. Multiple mappings are allowed separated by a comma e.g. "0-7:0,8-15:1". |
pcp-based-qos-pcp-mapping (PCP/DEI-range:DEI; Default: 0-15:0) | The new value of PCP for the PCP/DEI to PCP (0..7) mapping. Multiple mappings are allowed separated by a comma e.g. "0-7:3,8-15:4". |
pcp-based-qos-priority-mapping (PCP/DEI-range:DEI; Default: 0-15:0) | The new value of internal priority for the PCP/DEI to priority (0..15) mapping. Multiple mappings are allowed separated by a comma e.g. "0-7:5,8-15:15". |
priority-to-queue (priority-range:queue; Default: 0-15:0,1:1,2:2,3:3) | Internal priority (0..15) mapping to queue (0..7) per port. |
per-queue-scheduling (Scheduling-type:Weight; Default: wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32, wrr-group0:64,wrr-group0:128) | Set port to use either strict or weighted round robin policy for traffic shaping for each queue group, each queue is separated by a comma. |
ingress-customer-tpid-override (yes | no; Default:!ingress-customer-tpid-override) ingress-customer-tpid (0..10000; Default: 0x8100) | Ingress customer TPID override allows accepting specific frames with a custom customer tag TPID. The default value is for the tag of 802.1Q frames. |
egress-customer-tpid-override (yes | no; Default: !egress-customer-tpid-override) | Egress customer TPID override allows custom identification for egress frames with a customer tag. The default value is for the tag of 802.1Q frames. |
ingress-service-tpid-override (yes | no; Default: !ingress-service-tpid-override) ingress-service-tpid (0..10000; Default: 0x88A8) | Ingress service TPID override allows accepting specific frames with a custom service tag TPID. The default value is for the service tag of 802.1AD frames. |
egress-service-tpid-override (yes | no; Default: !egress-service-tpid-override) | Egress service TPID override allows custom identification for egress frames with a service tag. The default value is for the service tag of 802.1AD frames. |
custom-drop-counter-includes (counters; Default: none) | Custom include to count dropped packets for switch port custom-drop-packet counter.
queue-custom-drop-counter0-includes (counters; Default: none) | Custom include to count dropped packets for switch port tx-queue-custom0-drop-packet and bytes for tx-queue-custom0-drop-byte counters.
queue-custom-drop-counter1-includes (counters; Default: none) | Custom include to count dropped packets for switch port tx-queue-custom1-drop-packet and bytes for tx-queue-custom1-drop-byte counters.
policy-drop-counter-includes (counters; Default: none) | Custom include to count dropped packets for switch port policy-drop-packet counter.
Forwarding Databases
Unicast FDB
The unicast forwarding database supports up to 16318 MAC entries.
Sub-menu: /interface ethernet switch unicast-fdb
action (action; Default: forward) | Action for UFDB entry:
disabled (yes | no; Default: no) | Enables or disables Unicast FDB entry. |
isolation-profile (community1 | community2 | isolated | promiscuous; Default: promiscuous) | MAC level isolation profile. |
mac-address (MAC address) | The action command applies to the packet when the destination MAC or source MAC matches the entry. |
mirror (yes | no; Default: no) | Enables or disables mirroring based on source MAC or destination MAC. |
port (port) | Matching port for the Unicast FDB entry. |
qos-group (none; Default: none) | Defined QoS group from QoS group menu. |
svl (yes | no; Default: no) | Unicast FDB learning mode:
vlan-id (0..4095) | Unicast FDB lookup/learning VLAN id. |
Multicast FDB
CRS125 switch-chip supports up to 1024 entries in MFDB for multicast forwarding. For each multicast packet, destination MAC or destination IP lookup is performed in MFDB. MFDB entries are not automatically learned and can only be configured.
Sub-menu: /interface ethernet switch multicast-fdb
address (X.X.X.X | XX:XX:XX:XX:XX:XX) | Matching IP address or MAC address for multicast packets. |
bypass-vlan-filter (yes | no; Default: no) | Allow to bypass VLAN filtering for matching multicast packets. |
disabled (yes | no; Default: no) | Enables or disables Multicast FDB entry. |
ports (ports) | Member ports for multicast traffic. |
svl (yes | no; Default: no) | Multicast FDB learning mode:
vlan-id (0..4095; Default: 0) | Multicast FDB lookup VLAN ID. If the VLAN learning mode is IVL, VLAN id is lookup id, otherwise VLAN id = 0. |
Reserved FDB
Cloud Router Switch supports 256 RFDB entries. Each RFDB entry can store either Layer2 unicast or multicast MAC address with specific commands.
Sub-menu: /interface ethernet switch reserved-fdb
action (copy-to-cpu | drop | forward | redirect-to-cpu; Default: forward) | Action for RFDB entry:
bypass-ingress-port-policing (yes | no; Default: no) | Allow to bypass Ingress Port Policer for matching packets. |
bypass-ingress-vlan-filter (yes | no; Default: no) | Allow to bypass VLAN filtering for matching packets. |
disabled (yes | no; Default: no) | Enables or disables Reserved FDB entry. |
mac-address (MAC address; Default: 00:00:00:00:00:00) | Matching MAC address for Reserved FDB entry. |
VLAN
VLAN Table
The VLAN table supports 4096 VLAN entries for storing VLAN member information as well as other VLAN information such as QoS, isolation, forced VLAN, learning, and mirroring.
Sub-menu: /interface ethernet switch vlan
disabled (yes | no; Default: no) | Indicate whether the VLAN entry is disabled. Only enabled entry is applied to the lookup process and forwarding decision. |
flood (yes | no; Default: no) | Enables or disables forced VLAN flooding per VLAN. If the feature is enabled, the result of the destination MAC lookup in the UFDB or MFDB is ignored, and the packet is forced to flood in the VLAN. |
ingress-mirror (yes | no; Default: no) | Enable the ingress mirror per VLAN to support the VLAN-based mirror function. |
learn (yes | no; Default: yes) | Enables or disables source MAC learning for VLAN. |
ports (ports) | Member ports of the VLAN. |
svl (yes | no; Default: no) | FDB lookup mode for lookup in UFDB and MFDB.
vlan-id (0..4095) | VLAN ID of the VLAN member entry. |
Egress VLAN Tag
Egress packets can be assigned different VLAN tag formats. The VLAN tags can be removed, added, or remained as is when the packet is sent to the egress port (destination port). Each port has dedicated control of the egress VLAN tag format. The tag formats include:
- Untagged
- Tagged
- Unmodified
The Egress VLAN Tag table includes 4096 entries for VLAN tagging selection.
Sub-menu: /interface ethernet switch egress-vlan-tag
disabled (yes | no; Default: no) | Enables or disables Egress VLAN Tag table entry. |
tagged-ports (ports) | Ports that are tagged in egress. |
vlan-id (0..4095) | VLAN ID which is tagged in egress. |
Ingress/Egress VLAN Translation
The Ingress VLAN Translation table allows for up to 15 entries for each port. One or multiple fields can be selected from the packet header for lookup in the Ingress VLAN Translation table. The S-VLAN or C-VLAN or both configured in the first matched entry are assigned to the packet.
Sub-menu: /interface ethernet switch ingress-vlan-translation
Sub-menu: /interface ethernet switch egress-vlan-translation
customer-dei (0..1; Default: none) | Matching DEI of the customer tag. |
customer-pcp (0..7; Default: none) | Matching PCP of the customer tag. |
customer-vid (0..4095; Default: none) | Matching the VLAN ID of the customer tag. |
customer-vlan-format (any | priority-tagged-or-tagged | tagged | untagged-or-tagged; Default:any) | Type of frames with customer tag for which VLAN translation rule is valid. |
disabled (yes | no; Default: no) | Enables or disables VLAN translation entry. |
new-customer-vid (0..4095; Default: none) | The new customer VLAN ID replaces the matching customer VLAN ID. If set to 4095 and ingress VLAN translation is used, then traffic is dropped. |
new-service-vid (0..4095; Default: none) | The new service VLAN ID replaces the matching service VLAN ID. |
pcp-propagation (yes | no; Default: no) | Enables or disables PCP propagation.
ports (ports) | Matching switch ports for VLAN translation rule. |
protocol (protocols; Default: none) | Matching Ethernet protocol. (only for Ingress VLAN Translation) |
sa-learning (yes | no; Default: no) | Enables or disables source MAC learning after VLAN translation. (only for Ingress VLAN Translation) |
service-dei (0..1; Default: none) | Matching DEI of the service tag. |
service-pcp (0..7; Default: none) | Matching PCP of the service tag. |
service-vid (0..4095; Default: none) | Matching VLAN ID of the service tag. |
service-vlan-format (any | priority-tagged-or-tagged | tagged | untagged-or-tagged; Default:any) | Type of frames with service tag for which VLAN translation rule is valid. |
Below is a table of traffic that triggers a rule that has a certain VLAN format set, note that traffic that is tagged with VLAN ID 0 is a special case that is also taken into account.
any | Accepts:
priority-tagged-or-tagged | Accepts:
tagged | Accepts:
untagged-or-tagged | Accepts:
If VLAN-format
is set to any
, then customer-vid
service-vid
set to 0
will trigger the switch rule with VLAN 0 traffic. In this case, the switch rule will be looking for untagged traffic or traffic with a VLAN 0 tag, and only untagged-or-tagged
will filter out VLAN 0 traffic in this case.
Protocol Based VLAN
Protocol Based VLAN table is used to assign VID and QoS attributes to related protocol packets per port.
Sub-menu: /interface ethernet switch protocol-based-vlan
disabled (yes | no; Default: no) | Enables or disables Protocol Based VLAN entry. |
frame-type (ethernet | llc | rfc-1042; Default: ethernet) | Encapsulation type of the matching frames. |
new-customer-vid (0..4095; Default: 0) | The new customer VLAN ID replaces the original customer VLAN ID for the specified protocol. If set to 4095, then traffic is dropped. |
new-service-vid (0..4095; Default: 0) | The new service VLAN ID replaces the original service VLAN ID for the specified protocol. |
ports (ports) | Matching switch ports for Protocol-based VLAN rule. |
protocol (protocol; Default: 0) | Matching protocol for Protocol-based VLAN rule. |
set-customer-vid-for (all | none | tagged | untagged-or-priority-tagged; Default: all) | Customer VLAN ID assignment command for different packet types. |
set-qos-for (all | none | tagged | untagged-or-priority-tagged; Default: none) | Frame type for which QoS assignment command applies. |
set-service-vid-for (all | none | tagged | untagged-or-priority-tagged; Default: all) | Service VLAN ID assignment command for different packet types. |
MAC Based VLAN
MAC Based VLAN table is used to assign VLAN based on the source MAC.
Sub-menu: /interface ethernet switch mac-based-vlan
disabled (yes | no; Default: no) | Enables or disables MAC Based VLAN entry. |
new-customer-vid (0..4095; Default: 0) | The new customer VLAN ID replaces the original service VLAN ID for matched packets. If set to 4095, then traffic is dropped. |
new-service-vid (0..4095; Default: 0) | The new service VLAN ID replaces the original service VLAN ID for matched packets. |
src-mac-address (MAC address) | Matching source MAC address for MAC based VLAN rule. |
All CRS1xx/2xx series switches support up to 1024 MAC Based VLAN table entries.
1:1 VLAN Switching
1:1 VLAN switching can be used to replace the regular L2 bridging for matched packets. When a packet hits a 1:1 VLAN switching table entry, the destination port information in the entry is assigned to the packet. The matched destination information in the UFDB and MFDB entry no longer applies to the packet.
Sub-menu: /interface ethernet switch one2one-vlan-switching
customer-vid (0..4095; Default: 0) | Matching customer VLAN id for 1:1 VLAN switching. |
disabled (yes | no; Default: no) | Enables or disables 1:1 VLAN switching table entry. |
dst-port (port) | Destination port for matched 1:1 VLAN switching packets. |
service-vid (0..4095; Default: 0) | Matching customer VLAN id for 1:1 VLAN switching. |
Port Isolation/Leakage
The CRS switches support flexible multi-level isolation features, which can be used for user access control, traffic engineering and advanced security and network management. The isolation features provide an organized fabric structure allowing user to easily program and control the access by port, MAC address, VLAN, protocol, flow, and frame type. The following isolation and leakage features are supported:
- Port-level isolation
- MAC-level isolation
- VLAN-level isolation
- Protocol-level isolation
- Flow-level isolation
- Free combination of the above
Port-level isolation supports different control schemes on the source port and destination port. Each entry can be programmed with access control for either the source port or the destination port.
- When the entry is programmed with source port access control, the entry is
applied to the ingress packets.
- When the entry is programmed with destination port access control, the entry
is applied to the egress packets.
Port leakage allows bypassing egress VLAN filtering on the port. A leaky port is allowed to access other ports for various applications such as security, network control, and management. Note: When both isolation and leakage are applied to the same port, the port is isolated.
Sub-menu: /interface ethernet switch port-isolation
Sub-menu: /interface ethernet switch port-leakage
disabled (yes | no; Default: no) | Enables or disables port isolation/leakage entry. |
flow-id (0..63; Default: none) | |
forwarding-type (bridged; routed; Default: bridged,routed) | Matching traffic forwarding type on Cloud Router Switch. |
mac-profile (community1 | community2 | isolated | promiscuous; Default: none) | Matching MAC isolation/leakage profile. |
port-profile (0..31; Default: none) | Matching Port isolation/leakage profile. |
ports (ports; Default: none) | Isolated/leaked ports. |
protocol-type (arp; nd; dhcpv4; dhcpv6; ripv1; Default: arp,nd,dhcpv4,dhcpv6,ripv1) | Included protocols for isolation/leakage. |
registration-status (known; unknown; Default: known,unknown) | Registration status for matching packets. Known are present in UFDB and MFDB, and unknown are not. |
traffic-type (unicast; multicast; broadcast; Default: unicast,multicast,broadcast) | Matching traffic type. |
type (dst | src; Default: src) | Lookup type of the isolation/leakage entry:
vlan-profile (community1 | community2 | isolated | promiscuous; Default: none) | Matching VLAN isolation/leakage profile. |
Trunking
The Trunking in the Cloud Router Switches provides static link aggregation groups with hardware automatic failover and load balancing. IEEE802.3ad and IEEE802.1ax compatible Link Aggregation Control Protocol is not supported. Up to 8 Trunk groups are supported with up to 8 Trunk member ports per Trunk group. CRS Port Trunking calculates transmit-hash based on all following parameters: L2 src-dst MAC + L3 src-dst IP + L4 src-dst Port.
Sub-menu: /interface ethernet switch trunk
disabled (yes | no; Default: no) | Enables or disables port trunking entry. |
member-ports (ports) | Member ports of the Trunk group. |
name (string value; Default: trunkX) | Name of the Trunk group. |
Quality of Service
Shaper
Traffic shaping restricts the rate and burst size of the flow which is transmitted out from the interface. The shaper is implemented by a token bucket. If the packet exceeds the maximum rate or the burst size, which means not enough token for the packet, the packet is stored to buffer until there is enough token to transmit it.
Sub-menu: /interface ethernet switch shaper
burst (integer; Default: 100k) | Maximum data rate which can be transmitted while the burst is allowed. |
disabled (yes | no; Default: no) | Enables or disables traffic shaper entry. |
meter-unit (bit | packet; Default: bit) | Measuring units for traffic shaper rate. |
port (port) | Physical port for traffic shaper. |
rate (integer; Default: 1M) | Maximum data rate limit. |
target (port | queueX | wrr-groupX; Default: port) | Three levels of shapers are supported on each port (including CPU port):
Sub-menu: /interface ethernet switch ingress-port-policer
disabled (yes | no; Default: no) | Enables or disables ingress port policer entry. |
meter-len (layer-1 | layer-2 | layer-3; Default: layer-1) | Packet classification which sets the packet byte length for metering.
meter-unit (bit | packet; Default: bit) | Measuring units for traffic ingress port policer rate. |
new-dei-for-yellow (0..1 | remap; Default: none) | Remarked DEI for exceeded traffic if yellow-action is remark. |
new-dscp-for-yellow (0..63 | remap; Default: none) | Remarked DSCP for exceeded traffic if yellow-action is remark. |
new-pcp-for-yellow (0..7 | remap; Default: none) | Remarked PCP for exceeded traffic if yellow-action is remark. |
packet-types (packet-types; Default: all types from description) | Matching packet types for which ingress port policer entry is valid. |
port (port) | Physical port or trunk for ingress port policer entry. |
rate (integer) | Maximum data rate limit. |
yellow-action (drop | forward | remark; Default: drop) | Performed action for exceeded traffic. |
QoS Group
The global QoS group table is used for VLAN-based, Protocol-based, and MAC-based QoS group assignment configuration.
Sub-menu: /interface ethernet switch qos-group
dei (0..1; Default: none) | The new value of DEI for the QoS group. |
disabled (yes | no; Default: no) | Enables or disables protocol QoS group entry. |
drop-precedence (drop | green | red | yellow; Default: green) | Drop precedence is an internal QoS attribute used for packet enqueuing or dropping. |
dscp (0..63; Default: none) | The new value of DSCP for the QoS group. |
name (string value; Default: groupX) | Name of the QoS group. |
pcp (0..7; Default: none) | The new value of PCP for the QoS group. |
priority (0..15; Default: 0) | Internal priority is a local significance of priority for classifying traffic to different egress queues on a port. (1 is highest, 15 is lowest) |
DSCP QoS Map
The global DSCP to QOS mapping table is used for mapping from the DSCP of the packet to new QoS attributes configured in the table.
Sub-menu: /interface ethernet switch dscp-qos-map
dei (0..1) | The new value of DEI for the DSCP to QOS mapping entry. |
drop-precedence (drop | green | red | yellow) | The new value of Drop precedence for the DSCP to QOS mapping entry. |
pcp (0..7) | The new value of PCP for the DSCP to QOS mapping entry. |
priority (0..15) | The new value of internal priority for the DSCP to QOS mapping entry. |
DSCP To DSCP Map
The global DSCP to DSCP mapping table is used for mapping from the packet's original DSCP to the new DSCP value configured in the table.
Sub-menu: /interface ethernet switch dscp-to-dscp
new-dscp (0..63) | The new value of DSCP for the DSCP to DSCP mapping entry. |
Policer QoS Map
Sub-menu: /interface ethernet switch policer-qos-map
dei-for-red (0..1; Default: 0) | Policer DEI remapping value for red packets. |
dei-for-yellow (0..1; Default: 0) | Policer DEI remapping value for yellow packets. |
dscp-for-red (0..63; Default: 0) | Policer DSCP remapping value for red packets. |
dscp-for-yellow (0..63; Default: 0) | Policer DSCP remapping value for yellow packets. |
pcp-for-red (0..7; Default: 0) | Policer PCP remapping value for red packets. |
pcp-for-yellow (0..7; Default: 0) | Policer PCP remapping value for yellow packets. |
Access Control List
Access Control List contains of ingress policy and egress policy engines and allows configuration of up to 128 policy rules (limited by RouterOS). It is an advanced tool for wire-speed packet filtering, forwarding, shaping, and modifying based on Layer2, Layer3, and Layer4 protocol header field conditions.
See the Summary section for Access Control List supported Cloud Router Switch devices.
Due to hardware limitations, it is not possible to match broadcast/multicast traffic on specific ports. You should use port isolation, drop traffic on ingress ports, or use VLAN filtering to prevent certain broadcast/multicast traffic from being forwarded.
Sub-menu: /interface ethernet switch acl
ACL condition part for MAC-related fields of packets.
disabled (yes | no; Default: no) | Enables or disables ACL entry. |
table (egress | ingress; Default: ingress) | Selects the policy table for incoming or outgoing packets. |
invert-match (yes | no; Default: no) | Inverts the whole ACL rule matching. |
src-ports (ports,trunks) | Matching physical source ports or trunks. |
dst-ports (ports,trunks) | Matching physical destination ports or trunks. It is not possible to match broadcast/multicast traffic on the egress port due to a hardware limitation. |
mac-src-address (MAC address/Mask) | Source MAC address and mask. |
mac-dst-address (MAC address/Mask) | Destination MAC address and mask. |
dst-addr-registered (yes | no) | Defines whether to match packets with registered state - packets whose destination MAC address is in UFDB/MFDB/RFDB. Valid only in the egress table. |
mac-protocol (802.2 | arp | homeplug-av | ip | ip-or-ipv6 | ipv6 | ipx | lldp | loop-protect | mpls-multicast | mpls-unicast | mvrp | non-ip | packing-compr | packing-simple | pppoe | pppoe-discovery | rarp | service-vlan | vlan or integer: 0..65535 decimal format or 0x0000-0xffff hex format) | Ethernet payload type (MAC-level protocol)
drop-precedence (drop | green | red | yellow) | Matching internal drop precedence. Valid only in the egress table. |
custom-fields |
ACL condition part for VLAN-related fields of packets.
lookup-vid (0..4095) | VLAN id used in lookup. It can be changed before reaching the egress table. |
service-vid (0-4095) | Matching service VLAN id. |
service-pcp (0..7) | Matching service PCP. |
service-dei (0..1) | Matching service DEI. |
service-tag (priority-tagged | tagged | tagged-or-priority-tagged | untagged) | Format of the service tag. |
customer-vid (0-4095) | Matching customer VLAN ID. |
customer-pcp (0..7) | Matching customer PCP. |
customer-dei (0..1) | Matching customer DEI. |
customer-tag (priority-tagged | tagged | tagged-or-priority-tagged | untagged) | Format of the customer tag. |
priority (0..15) | Matching internal priority. Valid only in the egress table. |
ACL condition part for IPv4 and IPv6 related fields of packets.
ip-src (IPv4/0..32) | Matching source IPv4 address. |
ip-dst (IPv4/0..32) | Matching destination IPv4 address. |
ip-protocol (tcp | udp | udp-lite | other) | IP protocol type. |
src-l3-port (0-65535) | Matching Layer3 source port. |
dst-l3-port (0-65535) | Matching Layer3 destination port. |
ttl (0 | 1 | max | other) | Matching TTL field of the packet. |
dscp (0..63) | Matching DSCP field of the packet. |
ecn (0..3) | Matching ECN field of the packet. |
fragmented (yes | no) | Whether to match fragmented packets. |
first-fragment (yes | no) | YES matches not fragmented and the first fragments, NO matches other fragments. |
ipv6-src (IPv6/0..128) | Matching source IPv6 address. |
ipv6-dst (IPv6/0..128) | Matching destination IPv6 address. |
mac-isolation-profile (community1 | community2 | isolated | promiscuous) | Matches isolation profile based on UFDB. Valid only in the egress policy table. |
src-mac-addr-state (dynamic-station-move | sa-found | sa-not-found | static-station-move) | Defines whether to match packets with registered state - packets whose destination MAC address is in UFDB/MFDB/RFDB. Valid only in the egress policy table. |
flow-id (0..63) |
ACL rule action part.
action (copy-to-cpu | drop | forward | redirect-to-cpu | send-to-new-dst-ports; Default: forward) |
new-dst-ports (ports,trunks) | If the action is "send-to-new-dst-ports", then this property sets which ports/trunks are the new destinations. |
mirror-to (mirror0 | mirror1) | Mirroring destination for ACL packets. |
policer (policer) | Applied ACL Policer for ACL packets. |
src-mac-learn (yes | no) | Whether to learn the source MAC of the matched ACL packets. Valid only in the ingress policy table. |
new-service-vid (0..4095) | New service VLAN ID for ACL packets. |
new-service-pcp (0..7) | New service PCP for ACL packets. |
new-service-dei (0..1) | New service DEI for ACL packets. |
new-customer-vid (0..4095) | New customer VLAN ID for ACL packets. If set to 4095, then traffic is dropped. |
new-customer-pcp (0..7) | New customer PCP for ACL packets. |
new-customer-dei (0..1) | New customer DEI for ACL packets. |
new-dscp (0..63) | New DSCP for ACL packets. |
new-priority (0..15) | New internal priority for ACL packets. |
new-drop-precedence (drop | green | red | yellow) | New internal drop precedence for ACL packets. |
new-registered-state (yes | no) | Whether to modify packet status. YES sets packet status to registered, NO - unregistered. Valid only in the ingress policy table. |
new-flow-id (0..63) |
Filter bypassing part for ACL packets.
attack-filter-bypass (yes | no; Default: no) | |
ingress-vlan-filter-bypass (yes | no; Default: no) | Allows bypassing ingress VLAN filtering in the VLAN table for matching packets. This applies only to the ingress policy table. |
egress-vlan-filter-bypass (yes | no; Default: no) | Allows bypassing egress VLAN filtering in the VLAN table for matching packets. This applies only to the ingress policy table. |
isolation-filter-bypass (yes | no; Default: no) | Allows bypassing the Isolation table for matching packets. This applies only to the ingress policy table. |
egress-vlan-translate-bypass (yes | no; Default: no) | Allows bypassing egress VLAN translation table for matching packets. |
ACL Policer
Sub-menu: /interface ethernet switch acl policer
name (string; Default: policerX) | Name of the Policer used in ACL. |
yellow-rate (integer) | Maximum data rate limit for packets with yellow drop precedence. |
yellow-burst (integer; Default: 0) | Maximum data rate which can be transmitted while the burst is allowed for packets with yellow drop precedence. |
red-rate (integer); Default: 0) | Maximum data rate limit for packets with red drop precedence. |
red-burst (integer; Default: 0) | Maximum data rate which can be transmitted while the burst is allowed for packets with red drop precedence. |
meter-unit (bit | packet; Default: bit) | Measuring units for ACL traffic rate. |
color-awareness (yes | no; Default: no) | YES makes the policer to take into account pre-colored drop precedence, NO - ignores drop precedence. |
bucket-coupling (yes | no; Default: no) | |
yellow-action (drop | forward | remark; Default: drop) | Performed action for exceeded traffic with yellow drop precedence. |
new-dei-for-yellow (0..1 | remap) | New DEI for yellow drop precedence packets. |
new-pcp-for-yellow (0..7 | remap) | New PCP for yellow drop precedence packets. |
new-dscp-for-yellow (0..63 | remap) | New DSCP for yellow drop precedence packets. |
red-action (drop | forward | remark; Default: drop) | Performed action for exceeded traffic with red drop precedence. |
new-dei-for-red (0..1 | remap) | New DEI for red drop precedence packets. |
new-pcp-for-red (0..7 | remap) | New PCP for red drop precedence packets. |
new-dscp-for-red (0..63 | remap) | New DSCP for red drop precedence packets. |
