Summary
Sub-menu: /system routerboard usb
Package: system (v6, v7)
This article describes RouterBoard device supported USB features.
USB Power Reset
USB power reset turns off USB port power for a specified time. It is useful when 3G/LTE modem needs to be restarted but there is no physical access to it.
Available properties:
- duration (time; Default: "3s") - Time interval of how long power is turned off.
For example, turn off USB port power for 10 seconds:
/system routerboard usb power-reset duration=10s
RouterBoards with multiple USB buses also require a bus specified in order to do a USB power reset.
- bus (integer; Default: 1) - USB bus where power reset is applied.
RB953GS: The miniPCIe slot closer to Ethernet ports on the RB953GS board is the one which is shared with USB port and has configurable USB port type, its USB bus number is 1. Depending on USB port type the power reset is done on USB port or miniPCIe slot. The other miniPCIe slot closer to SFP slots has independent bus - 2.
RB922UAG: The USB port has an independent bus - 1. The miniPCIe slot has an independent bus - 2.
CCR1072-1G-8S+: The micro USB port has independent bus - 0. The USB Type-A port has independent bus - 1.
USB Port Type
RB912UAG and RB953GS have partially shared USB port and miniPCIe slot. Due to hardware restrictions it is possible to use only one at the time for 3G/LTE modem.
[admin@MikroTik] > /system routerboard usb set type= USB-type-A mini-PCIe
- type (USB-type-A | mini-PCIe; Default: "USB-type-A") - Type of enabled port.
USB Port Mode
RB2011 series, CRS1xx series, and mAP have micro USB port which operates in host mode when USB device is attached through USB OTG cable. Some vendor cables require forced host mode to recognize connected device.
- usb-mode (automatic | force-host; Default: "automatic") - Defines USB port mode.
Warning
On RB2011 and CRS1xx series boards USB devices may not work first time they are plugged in. In such cases power cycle (not reboot) is required.
RouterBoard USB Port Limitations
Some RouterBoard devices have notable USB port limitations.
* RB mAP 2n - does not support USB Power Reset
* RB750UP - does not support USB Power Reset
* RB751U-2HnD - does not support USB Power Reset
* RB751G-2HnD - does not support USB Power Reset
* RB411U - does not support USB Power Reset
* RB411UAHR - does not support USB Power Reset and USB Powering (USB power injector is required)
* RB433UAH - does not support USB Power Reset
* RB435G - does not support USB Power Reset
* RB493G - does not support USB Power Reset and USB Powering (USB power injector is required)
RouterOS does not support memory slot from USB modems.
