Overview
The Serial Console and Terminal are tools, used to communicate with devices and other systems that are interconnected via the serial port. The serial terminal may be used to monitor and configure many devices - including modems, network devices (including MikroTik routers), and any device that can be connected to a serial (asynchronous) port.
The Serial Console feature is for configuring direct-access configuration facilities (monitor/keyboard and serial port) that are mostly used for initial or recovery configuration. A special null-modem cable is needed to connect two hosts (like two PCs, or two routers; not modems). Note that a terminal emulation program (e.g., HyperTerminal on Windows or minicom on Linux) is required to access the serial console from another computer. Default settings of the router's serial port are 115200 bits/s (for x86 default is 9600 bits/s), 8 data bits, 1 stop bit, no parity, hardware (RTS/CTS) flow control.
Several customers have described situations where the Serial Terminal (managing side) feature would be useful:
  • on a mountaintop, where a MikroTik wireless installation sits next to equipment (including switches and Cisco routers) that can not be managed in-band (by telnet through an IP network)
  • monitoring weather-reporting equipment through a serial port
  • connection to a high-speed microwave modem that needed to be monitored and managed by a serial connection
With the serial-terminal feature of the MikroTik, up to 132 (and, maybe, even more) devices can be monitored and controlled.
Serial Console Connections
Serial communications between devices are done with RS232, it is one of the oldest and most widely spread communication methods in the computer world. It was used for communication with the modems or other peripheral devices DTE/DCE. In the modern world, the main use of serial communication is DTE/DTE communication (Data Terminal Equipment) e.g. using a null-modem cable. There are several types of null modem cables and some of them may not work with RouterBoards at all.
Null Modem Without Handshake
This cable does not utilize handshake pins at all:
Side1 (DB9f)Side2 (DB9f)Function
23
Rx ← Tx
32Tx → Rx
55GND
It allows data-only traffic on the cross-connected Rx/Tx lines. Hardware flow control is not possible with this type of cable. The only way to perform flow control is with software flow control using the XOFF and XON characters.
Null Modem With LoopBack Handshake
The problem with the first cable is when connected to a device on which hardware flow control is enabled software may hang when checking modem signal lines.
Null modem cable with loop back handshake fixes the problem, its main purpose is to fool well-defined software into thinking there is handshaking available:
23
Rx ← Tx
32Tx → Rx
55
GND
1+4+6-DTR → CD + DSR
-1+4+6DTR → CD + DSR
7+8-RTS → CTS
-7+8RTS → CTS
Hardware flow control is not possible with this cable. Also if remote software does not send its own ready signal to DTR output communication will hang.
Null Modem With Partial Handshake
This cable can be used when flow control enabled without being incompatible with the original way flow control was used with DTE/DCE communication.
This type of cable is not recommended for use with RouterOS.
17+8
RTS2 → CTS2 + CD1
23Rx ← Tx
32
Tx → Rx
46DTR → DSR
55GND
64DSR ← DTR
7+81RTS1 → CTS1 + CD2
Null Modem With Full Handshake
Used with special software and should not be used with RouterOS.
23Rx ← Tx
32
Tx → Rx
46DTR → DSR
55GND
64DSR ← DTR
78RTS → CTS
87CTS ← RTS
Null Modem Compatibility
Summary tables below will allow you to choose the proper cable for your application.
No handshake
Loopback
handshake
Partial
handshake
Full
handshake
RouterBoards
with limited port functionality
YYN*N
RouterBoards
with full functionality
YYYN
* - may work only when hardware flow control is disabled
No handshake
Loopback
handshake
Partial
handshake
Full
handshake
Software flow
control only
YY*Y**Y**
Low-speed DTE/DCE compatible
NYY*N
High-speed DTE/DCE compatible
NYY**N
High speed
communication
using special software
NNY*Y
* - will work as an alternative
** - will work but not recommended
RJ45 Type Serial Port
This type of port is used on RouterBOARD 2011, 3011, 4011, CCR1072, CCR1036 r2, CCR2xxx and CRS series devices, sometimes called "Cisco style" serial port.
RJ45 to DB9 Cable Pinout:
SignalConsole Port (DTE)
RJ-45
RJ-45 Rolled Cable
RJ-45 Pin
Adapter DB-9 PinAdapter DB-25 PinSignal
RTS1885CTS
DTR2766DSR
TxD3623RxD
Ground4557Ground
Ground5457Ground
RxD6332TxD
DSR72420DTR
CTS8174RTS
RB M33G Additional Serial Header
For RBM33G additional serial header can be attached on GPIO pins U3_RXD, GND, U3_TXD, and 3V3
RouterOS 6.45.1+ and firmware are required!
CCR Serial Header
The Cloud Core Router series devices have a serial header on the PCB board, called J402 or 100
Here is the pin-out of that connector:
Serial Terminal Usage
RouterOS allows to communicate with devices and other systems that are connected to the router via the serial port using a /system serial-terminal  command. All keyboard input will be forwarded to the serial port and all data from the port is output to the connected device.
First, you have to have a free serial port, if the device has only one serial port (like all RouterBoards, WRAP/ALIX boards, etc.) you will have to disable the system console on this serial port to be able to use it as Serial Terminal for connection to other equipment (switches, modems, etc):
/system console disable 0
Be sure to just disable the console rather than removing it, as RouterOS will recreate the console after the next reboot when you really remove it.
Note that there are some caveats you should be aware of! Take your time understanding those limits to avoid strange things to happen when connecting a device to a serial port on a RouterBoard:
  • By re-configuring port Serial0 on a RouterBoard as seen above, you will lose your serial console access to RouterOS. This means, that if you cannot access your RouterBoard over the network anymore, you might even have to reset the whole configuration of it to gain access again.
  • When rebooting a RouterBoard the boot loader (RouterBOOT) will always use the serial console (Serial0 on RouterBoards) to send out some startup messages and offer access to the RouterBOOT menu.
    Having text coming out of the serial port to the connected device might confuse your attached device. Furthermore, in the standard config, you can enter the RouterBOOT menu by pressing ANY key. So if your serial device sends any character to the serial port of your RouterBoard during boot time, the RouterBoard will enter the RouterBOOT menu and will NOT boot RouterOS unless you manually intervene!
    You can reconfigure RouterBOOT to enter the RouterBOOT menu only when a DEL character is received - use this to reduce the chance to get a router that's stuck when rebooting!
    Or if newer versions are used "Silent boot" feature can be used to suppress any output on the serial interface, including removal of booting sounds.
Next, you will have to configure your serial port according to the serial port settings of the connected device. Using the following command you will set your serial port to 19200 Baud 8N1. What settings you need to use depends on the device you connect:
/port set serial0 baud-rate=19200 data-bits=8 parity=none stop-bits=1
You can also try to let RouterOS guess the needed baud rate by setting
/port set serial0 baud-rate=auto
Now's the time to connect your device if not already done. Usually, you will have to use a null modem cable (the same thing as a cross-over-cable for Ethernet). Now we're ready to go:
/system serial-terminal serial0
This will give you access to the device you connected to port Serial0. Ctrl-A is the prefix key, which means that you will enter a small "menu". If you need to send the Ctrl-A character to a remote device, press Ctrl-A twice.
If you want to exit the connection to the serial device type Ctrl-A, then Q. This will return you to your RouterOS console.
Do not connect to devices at an incorrect speed and avoid dumping binary data.
Special Login
Special login can be used to access another device (like a switch, for example) that is connected through a serial cable by opening a telnet/ssh session that will get you directly on this device (without having to login to RouterOS first).
For demonstration we will use two RouterBoards and one PC.
Routers R1 and R2 are connected with serial cable and PC is connected to R1 via ethernet. Lets say we want to access router R2 via serial cable from our PC. To do this you have to set up serial interface proxy on R1. It can be done by feature called special-login.
By default console is bound to serial port.
First task is to unbind console from serial simply by disabling entry in /system console menu:
[admin@MikroTik] /system console> print
Flags: X - disabled, U - used, F - free
 #   PORT        TERM
 0 X serial0        vt102
Next step is to add new user, in this case serial, and bind it to the serial port
[admin@MikroTik] > /user add name=serial group=full
[admin@MikroTik] > /special-login add user=serial port=serial0 disabled=no
[admin@MikroTik] > /special-login print
Flags: X - disabled
 #   USER        PORT
 0   serial        serial0
Now we are ready to access R2 from our PC.
maris@bumba:/$ ssh serial@10.1.101.146
[Ctrl-A is the prefix key]
R2 4.0beta4
R2 Login:
[admin@R2] >
To exit special login mode press Ctrl+A and Q
[admin@MikroTik] >
[Q - quit connection]      [B - send break]
[A - send Ctrl-A prefix]   [R - autoconfigure rate]
Connection to 10.1.101.146 closed.
After router reboot and serial cable attached router may stuck at Bootloader main menu
To fix this problem you need to allow access bootloader main menu from <any> key to <delete>:
  • enter bootloader menu
  • press 'k' for boot key options
  • press '2' to change key to <delete>
What do you want to configure?
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
u - cpu mode
f - cpu frequency
r - reset booter configuration
e - format nand
g - upgrade firmware
i - board info
p - boot protocol
b - booter options
t - call debug code
l - erase license
x - exit setup
your choice: k - boot key
Select key which will enter setup on boot:
 * 1 - any key
   2 - <Delete> key only
your chaoice: 2
  • No labels
