Introduction
Network load balancing is the ability to balance traffic across two or more WAN links without using routing protocols like BGP.
Load Balancing's aim is to spread traffic across multiple links to get better link usage. This can be done on one per-packet or per-connection basis.
MethodPer-connectionPer-packet
With the Firewall features
Firewall markingYesYes
ECMP (Equal Cost Multi-Path)YesNo
PCC (Per Connection Classifier)YesNo
NthYesYes
BondingNoYes
OSPFYesNo
BGPYesNo
Route Failover
This example explains how to use multiple gateways with one taking over when first fails. It begins with adding the gateways. Configure larger distance value for the secondary one, and check-gateway for the first one:
/ip route add gateway=192.168.1.1 distance=1 check-gateway=ping
/ip route add gateway=192.168.2.1 distance=2
The first gateway will begin as its distance is smaller (default 1); the check-gateway will make sure it is up. When the ping will fail, it will disable the first gateway and the second will take over and when the first one comes up, it will return to its function.
  • No labels
