This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
Summary
This example demonstrates how to set up PPPoE server and client to use IPv6 Prefix Delegation.
IPv6 Prefixes can be delegated over PPP interfaces. When client connects, PPP will automatically add dynamic DHCPv6-PD server. This allows to run DHCPv6 client on PPP interfaces.
Configuration
Server
dhcpv6-pd-pool parameter under PPP Profiles is used to enable PPP-PD. PPP will use specified IPv6 pool to create a dynamic DHCP server.
So first step is to add IPv6 pool:
/ipv6 pool
add name=myPool prefix=2001:db8:7501:ff00::/60 prefix-length=62
Now we can configure PPP profile and add PPPoE server
/ppp profile set default dhcpv6-pd-pool=myPool
/interface pppoe-server server
add service-name=test interface=ether1
Client
On client side we need to set up PPPoE client interface and run DHCP client on it.
/interface pppoe-client
add name=client-test interface=ether1 user=a1 service-name=test
/ipv6 dhcp-client
add interface=client-test pool-name=ppp-test pool-prefix-length=64
Testing status
On server side check if dynamic DHCP server is added and prefix is bound to specific client:
[admin@RB1100] /ipv6 dhcp-server> print
Flags: D - dynamic, X - disabled, I - invalid
 #    NAME              INTERFACE            ADDRESS-POOL            LEASE-TIME
 0 D  <pppoe-a1>        <pppoe-a1>           myPool                  3d
[admin@RB1100] /ipv6 dhcp-server binding> print
Flags: X - disabled, D - dynamic
 #   ADDRESS                                        DU       IAID SER.. STATUS
 1 D 2001:db8:7501:ff04::/62                                  247 <pp.. bound
On client side, check if DHCP client is bound and pool is added:
[admin@x86-test] /ipv6 dhcp-client> print
 #    INTERFACE           STATUS        PREFIX                            EXPIRES-AFTER
0    client-test          bound         2001:db8:7501:ff04::/62           2d23h18m17s
[admin@x86-test] /ipv6 pool> print
Flags: D - dynamic
 #   NAME                        PREFIX                                   PREFIX-LENGTH
 0 D ppp-test                    2001:db8:7501:ff04::/62                             64
  • No labels
