This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
Summary
IP Scan tool allows a user to scan networks based on some network prefix or by setting an interface to listen to. Either way, the tool collects certain data from the network:
  • address - IP address of network device;
  • mac-address - MAC address of network device;
  • time - response time of seen network device when found;
  • DNS - DNS name of a network device;
  • SNMP - SNMP name of the device;
  • NET-BIOS  - NET-BIOS name of device if advertised by the device;
When using IP scan tool user must choose what they want to scan for:
  • certain IPv4 prefix - the tool will attempt to scan all the IP addresses or addresses set;
  • the interface of the router - the tool will attempt to listen to packets that are "passing by" and attempt to compile results when something is found;
There is a possibility to set both but then results may be inconclusive!
Quick Example
In the following example, we will scan the devices on 10.155.126.0/24 network:
[admin@MikroTik] > /tool ip-scan address-range=10.155.126.1-10.155.126.255
Columns: ADDRESS, MAC-ADDRESS, TIMe, SNMP
  ADDRESS         MAC-ADDRESS        TIM  SNMP
  10.155.126.1    E4:8D:8C:1C:D3:18  2ms  CCR1036-8G-2S+
  10.155.126.251                     2ms
  10.155.126.151  E4:8D:8C:49:49:DB  1ms
  10.155.126.153  6C:3B:6B:48:0E:8B  1ms  750Gr3
  10.155.126.249  CC:2D:E0:8D:01:88  0ms  CRS328-24P-4S+
  10.155.126.250  B8:69:F4:B3:1B:D2  0ms
  10.155.126.252  6C:3B:6B:ED:83:69  0ms
  10.155.126.253  6C:3B:6B:ED:81:83  0ms
  • No labels
