This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
/routing/bfd/configuration
PropertyDescription
address-listFirewall address list name. BFD configuration will apply if remote IP address is contained within specified list.
addressesThis config entry will only apply to BFD sessions established with these specific remote neighbors.
commentdescription string.
forbid-bfdBoolean yes / no parameter; if = yes : BFD sessions matching criteria will be prohibited.
interfaceslist if interfaces where BFD configuration should be active.
min-rxMinimum receive interval, that the local router requires between received BFD packets.
min-txDesired transmit interval, that the local router would like to use when sending BFD packets to the neighbor.
multiplierThis value is multiplied by the negotiated transmission interval to determine the Hold Time; If no packets within the Hold time are received - the neighbor is declared down. Hold Time = negotiated interval × multiplier
vrfThe Virtual Routing and Forwarding instance to which this configuration applies.
/routing/bfd/session
Read-only PropertyDescription
actual-tx-intervalreal-time frequency at which the device currently sends BFD control packets.
  • No labels
