This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
You are viewing an old version of this page. View the current version.
Compare with Current View Page History
« Previous Version 2 Next »
RouterOS is a stand-alone operating system based on Linux kernel. It powers MikroTik hardware devices, but is also available for virtual machines.
The following list shows features found in the latest RouterOS release:
Hardware Support
  • i386 compatible architecture
  • SMP – multi-core and multi-CPU compatible
  • Minimum 32MB of RAM (maximum supported 2GB, except on Cloud Core devices and CHR installations, where there is no maximum)
  • IDE, SATA, USB and flash storage medium with minimum of 64MB space
  • Network cards supported by linux v3.3.5 kernel (PCI, PCI-X)
  • Partial hardware compatibility list (user maintained)
  • Switch chip configuration support
Note: NVMe storage is supported only for CHR, x86, Tile and MMIPS architecture. For specific information, please look at each product brochure or block diagram.
Installation
  • Manual:Netinstall: Full network based installation from PXE or EtherBoot enabled network card
  • Manual:CHR: RouterOS version intended for running as a virtual machine
  • Netinstall: Installation to a secondary drive mounted in Windows
  • CD based installation
Configuration
  • MAC based access for initial configuration
  • WinBox – standalone Windows GUI configuration tool
  • M:Webfig - advanced web based configuration interface
  • MikroTik - Android and iOS based configuration tool
  • Powerful command-line configuration interface with integrated scripting capabilities, accessible via local terminal, serial console, telnet and ssh
  • API - the way to create your own configuration and monitoring applications
Backup/Restore
Firewall
  • Statefull filtering
  • Source and destination NAT
  • NAT helpers (h323, pptp, quake3, sip, ftp, irc, tftp)
  • Internal connection, routing and packet marks
  • Filtering by IP address and address range, port and port range, IP protocol, DSCP and many more
  • Address lists
  • Custom Layer7 matcher
  • IPv6 support
  • PCC - per connection classifier, used in load balancing configurations
  • RAW filtering to bypass connection tracking.
Routing
MPLS
VPN
  • IPSec – tunnel and transport mode, certificate or PSK, AH and ESP security protocols. Hardware encryption support on RouterBOARD 1000.
  • IKEv2 support
  • AES-NI hardware acceleration support for IPSec
  • Point to point tunneling ( OpenVPN, PPTP, PPPoE, L2TP, SSTP)
  • Advanced PPP features (MLPPP, BCP)
  • Simple tunnels ( IPIP, EoIP) IPv4 andIPv6 support
  • 6to4 tunnel support (IPv6 over IPv4 network)
  • VLAN – IEEE802.1q Virtual LAN support, Q-in-Q support
  • MPLS based VPNs
Wireless
  • IEEE802.11a/b/g wireless client and access point
  • Full IEEE802.11n support
  • Nstreme and Nstreme2 proprietary protocols
  • NV2 protocol
  • Wireless Distribution System (WDS)
  • Virtual AP
  • WEP, WPA, WPA2
  • Access control list
  • Wireless client roaming
  • WMM
  • HWMP+ Wireless MESH protocol
  • MME wireless routing protocol
DHCP
  • Per interface DHCP server
  • DHCP client and relay
  • Static and dynamic DHCP leases
  • RADIUS support
  • Custom DHCP options
  • DHCPv6 Prefix Delegation (DHCPv6-PD)
  • DHCPv6 Client
Hotspot
  • Plug-n-Play access to the Network
  • Authentication of local Network Clients
  • Users Accounting
  • RADIUS support for Authentication and Accounting
QoS
  • Hierarchical Token Bucket ( HTB) QoS system with CIR, MIR, burst and priority support
  • Simple and fast solution for basic QoS implementation - Simple queues
  • Dynamic client rate equalization ( PCQ)
Proxy
  • HTTP caching proxy server
  • Transparent HTTP proxy
  • SOCKS protocol support
  • DNS static entries
  • Support for caching on a separate drive
  • Parent proxy support
  • Caching list
Tools
  • Ping, traceroute
  • Bandwidth test, ping flood
  • Packet sniffer, torch
  • Telnet, ssh
  • E-mail and SMS send tools
  • Automated script execution tools
  • CALEA
  • File Fetch tool
  • Advanced traffic generator
Other features
  • Samba support
  • OpenFlow support
  • Bridging – spanning tree protocol (STP, RSTP), bridge firewall and MAC natting.
  • Dynamic DNS update tool
  • NTP client/server and synchronization with GPS system
  • VRRP v2 and v3 support
  • SNMP
  • M3P - MikroTik Packet packer protocol for wireless links and ethernet
  • MNDP - MikroTik neighbor discovery protocol, supports CDP (Cisco discovery protocol)
  • RADIUS authentication and accounting
  • TFTP server
  • Synchronous interface support (Farsync cards only) (Removed in v5.x)
  • Asynchronous – serial PPP dial-in/dial-out, dial on demand
  • ISDN – dial-in/dial-out, 128K bundle support, Cisco HDLC, x75i, x75ui, x75bui line protocols, dial on demand
  • No labels
