This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
Introduction
Sub-menu: /tool wol
The Wake on LAN tool can send a UDP Magic Packet to the Broadcast address with a selected MAC address embedded in it.
If the target device supports Wake on LAN (a target computer has specific hardware and software requirements for the Wake on LAN feature to work), it should wake up from sleep or shutdown state.
Currently, secure WoL is not supported.
Property Description
PropertyDescription
interface (string; Default: )
Interface through which the Magic Packet will be sent
mac (MAC; Default: )MAC address of a target computer
Application Example
The command requires a MAC address parameter and interface.
If an interface is not specified, A Magic Packet will be sent as an IP broadcast from a default gateway interface.
/tool wol mac=FE:4B:71:05:EA:8B interface=ether1
  • No labels
