This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
Introduction
Burst is a feature that allows satisfying queue requirements for additional bandwidth even if the required rate is bigger than MIR (max-limit) for a limited period of time.
Burst can occur only if average-rate of the queue for the last burst-time seconds is smaller than burst-threshold. Burst will stop if average-rate of the queue for the last burst-time seconds is bigger or equal to burst-threshold.
The burst mechanism is simple - if a burst is allowed max-limit value is replaced by the burst-limit value. When the burst is disallowed max-limit value remains unchanged.
  1. burst-limit (NUMBER) : maximal upload/download data rate which can be reached while the burst is allowed;
  2. burst-time (TIME) : period of time, in seconds, over which the average data rate is calculated. (This is NOT the time of actual burst);
  3. burst-threshold (NUMBER) : this is value of burst on/off switch;
  4. average-rate (read-only) : Every 1/16 part of the burst-time, the router calculates the average data rate of each class over the last burst-time seconds;
  5. actual-rate (read-only) : actual traffic transfer rate of the queue;
Example
Values: limit-at=1M , max-limit=2M , burst-threshold=1500k , burst-limit=4M
The client will try to download two 4MB (32Mb) blocks of data, the first download will start at zero seconds, and the second download will start at 17th second. Traffic was unused at the last minute.
Burst-time=16s
As we can see as soon as the client requested bandwidth it was able to get 4Mpbs burst for 6 seconds. This is longest possible burst with given values (longest-burst-time = burst-threshold * burst-time / burst-limit). As soon as the burst runs out rest of the data will be downloaded with 2Mbps. This way block of data was downloaded in 9 seconds - without burst, it would take 16 seconds. Burst has 7 seconds to recharge before the next download will start.
Note that burst is still disallowed when download started and it kicks in only afterward - in the middle of a download. So with this example, we proved that a burst may happen in the middle of a download. The burst was ~4 seconds long and the second block was downloaded 4 seconds faster than without burst.
The average rate is calculated every 1/16 of burst time so in this case 1s
Timeaverage-rateburstactual-rate
0(0+0+0+0+0+0+0+0+0+0+0+0+0+0+0+0)/16=0Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps
1(0+0+0+0+0+0+0+0+0+0+0+0+0+0+0+4)/16=250Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps
2(0+0+0+0+0+0+0+0+0+0+0+0+0+0+4+4)/16=500Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps
3(0+0+0+0+0+0+0+0+0+0+0+0+0+4+4+4)/16=750Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps
4(0+0+0+0+0+0+0+0+0+0+0+0+4+4+4+4)/16=1000Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps
5(0+0+0+0+0+0+0+0+0+0+0+4+4+4+4+4)/16=1250Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps
6(0+0+0+0+0+0+0+0+0+0+4+4+4+4+4+4)/16=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps
7(0+0+0+0+0+0+0+0+0+4+4+4+4+4+4+2)/16=1625Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps
8(0+0+0+0+0+0+0+0+4+4+4+4+4+4+2+2)/16=1750Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps
9(0+0+0+0+0+0+0+4+4+4+4+4+4+2+2+2)/16=1875Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps
10(0+0+0+0+0+0+4+4+4+4+4+4+2+2+2+2)/16=2Mbpsaverage-rate > burst-threshold → Burst not allowed0Mbps
11(0+0+0+0+0+4+4+4+4+4+4+2+2+2+2+0)/16=2Mbpsaverage-rate > burst-threshold → Burst not allowed0Mbps
12(0+0+0+0+4+4+4+4+4+4+2+2+2+2+0+0)/16=2Mbpsaverage-rate > burst-threshold → Burst not allowed0Mbps
13(0+0+0+4+4+4+4+4+4+2+2+2+2+0+0+0)/16=2Mbpsaverage-rate > burst-threshold → Burst not allowed0Mbps
14(0+0+4+4+4+4+4+4+2+2+2+2+0+0+0+0)/16=2Mbpsaverage-rate > burst-threshold → Burst not allowed0Mbps
15(0+4+4+4+4+4+4+2+2+2+2+0+0+0+0+0)/16=2Mbpsaverage-rate > burst-threshold → Burst not allowed0Mbps
16(4+4+4+4+4+4+2+2+2+2+0+0+0+0+0+0)/16=2Mbpsaverage-rate > burst-threshold → Burst not allowed0Mbps
17(4+4+4+4+4+2+2+2+2+0+0+0+0+0+0+0)/16=1750Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps
18(4+4+4+4+2+2+2+2+0+0+0+0+0+0+0+2)/16=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps
19(4+4+4+2+2+2+2+0+0+0+0+0+0+0+2+2)/16=1375Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps
20(4+4+2+2+2+2+0+0+0+0+0+0+0+2+2+4)/16=1375Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps
21(4+2+2+2+2+0+0+0+0+0+0+0+2+2+4+4)/16=1375Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps
22(2+2+2+2+0+0+0+0+0+0+0+2+2+4+4+4)/16=1375Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps
23(2+2+2+0+0+0+0+0+0+0+2+2+4+4+4+4)/16=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps
24(2+2+0+0+0+0+0+0+0+2+2+4+4+4+4+2)/16=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps
25(2+0+0+0+0+0+0+0+2+2+4+4+4+4+2+2)/16=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps
26(0+0+0+0+0+0+0+2+2+4+4+4+4+2+2+2)/16=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps
27(0+0+0+0+0+0+2+2+4+4+4+4+2+2+2+2)/16=1625Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps
28(0+0+0+0+0+2+2+4+4+4+4+2+2+2+2+2)/16=1750Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps
29(0+0+0+0+2+2+4+4+4+4+2+2+2+2+2+2)/16=1875Kbpsaverage-rate > burst-threshold → Burst not allowed0Mbps
30(0+0+0+2+2+4+4+4+4+2+2+2+2+2+2+0)/16=1875Kbpsaverage-rate > burst-threshold → Burst not allowed0Mbps
31(0+0+2+2+4+4+4+4+2+2+2+2+2+2+0+0)/16=1875Kbpsaverage-rate > burst-threshold → Burst not allowed0Mbps
Burst-time=8s
If we decrease burst-time to 8 seconds - we are able to see that in this case, bursts are only at the beginning of downloads The average rate is calculated every 1/16th of burst time, so in this case every 0.5 seconds.
0.0(0+0+0+0+0+0+0+0+0+0+0+0+0+0+0+0)/8=0Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps (2Mb per 0,5sek)
0.5(0+0+0+0+0+0+0+0+0+0+0+0+0+0+0+2)/8=250Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps (2Mb per 0,5sek)
1.0(0+0+0+0+0+0+0+0+0+0+0+0+0+0+2+2)/8=500Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps (2Mb per 0,5sek)
1.5(0+0+0+0+0+0+0+0+0+0+0+0+0+2+2+2)/8=750Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps (2Mb per 0,5sek)
2.0(0+0+0+0+0+0+0+0+0+0+0+0+2+2+2+2)/8=1000Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps (2Mb per 0,5sek)
2.5(0+0+0+0+0+0+0+0+0+0+0+2+2+2+2+2)/8=1250Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps (2Mb per 0,5sek)
3.0(0+0+0+0+0+0+0+0+0+0+2+2+2+2+2+2)/8=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
3.5(0+0+0+0+0+0+0+0+0+2+2+2+2+2+2+1)/8=1625Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
4.0(0+0+0+0+0+0+0+0+2+2+2+2+2+2+1+1)/8=1750Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
4.5(0+0+0+0+0+0+0+2+2+2+2+2+2+1+1+1)/8=1875Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
5.0(0+0+0+0+0+0+2+2+2+2+2+2+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
5.5(0+0+0+0+0+2+2+2+2+2+2+1+1+1+1+1)/8=2125Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
6.0(0+0+0+0+2+2+2+2+2+2+1+1+1+1+1+1)/8=2250Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
6.5(0+0+0+2+2+2+2+2+2+1+1+1+1+1+1+1)/8=2375Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
7.0(0+0+2+2+2+2+2+2+1+1+1+1+1+1+1+1)/8=2500Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
7.5(0+2+2+2+2+2+2+1+1+1+1+1+1+1+1+1)/8=2625Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
8.0(2+2+2+2+2+2+1+1+1+1+1+1+1+1+1+1)/8=2750Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
8.5(2+2+2+2+2+1+1+1+1+1+1+1+1+1+1+1)/8=2625Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
9.0(2+2+2+2+1+1+1+1+1+1+1+1+1+1+1+1)/8=2500Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
9.5(2+2+2+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2375Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
10.0(2+2+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2250Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
10.5(2+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2125Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
11.0(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
11.5(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
12.0(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
12.5(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
13.0(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed0Mbps (0Mb per 0,5sek)
13.5(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+0)/8=1875Kbpsaverage-rate > burst-threshold → Burst not allowed0Mbps (0Mb per 0,5sek)
14.0(1+1+1+1+1+1+1+1+1+1+1+1+1+1+0+0)/8=1750Kbpsaverage-rate > burst-threshold → Burst not allowed0Mbps (0Mb per 0,5sek)
14.5(1+1+1+1+1+1+1+1+1+1+1+1+1+0+0+0)/8=1625Kbpsaverage-rate > burst-threshold → Burst not allowed0Mbps (0Mb per 0,5sek)
15.0(1+1+1+1+1+1+1+1+1+1+1+1+0+0+0+0)/8=1500Kbpsaverage-rate > burst-threshold → Burst not allowed0Mbps (0Mb per 0,5sek)
15.5(1+1+1+1+1+1+1+1+1+1+1+0+0+0+0+0)/8=1375Kbpsaverage-rate < burst-threshold → Burst is allowed0Mbps (0Mb per 0,5sek)
16.0(1+1+1+1+1+1+1+1+1+1+0+0+0+0+0+0)/8=1250Kbpsaverage-rate < burst-threshold → Burst is allowed0Mbps (0Mb per 0,5sek)
16.5(1+1+1+1+1+1+1+1+1+0+0+0+0+0+0+0)/8=1125Kbpsaverage-rate < burst-threshold → Burst is allowed0Mbps (0Mb per 0,5sek)
17.0(1+1+1+1+1+1+1+1+0+0+0+0+0+0+0+0)/8=1000Kbpsaverage-rate < burst-threshold → Burst is allowed2Mbps (1Mb per 0,5sek)
17.5(1+1+1+1+1+1+1+0+0+0+0+0+0+0+0+1)/8=1000Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps (2Mb per 0,5sek)
18.0(1+1+1+1+1+1+0+0+0+0+0+0+0+0+1+2)/8=1125Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps (2Mb per 0,5sek)
18.5(1+1+1+1+1+0+0+0+0+0+0+0+0+1+2+2)/8=1250Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps (2Mb per 0,5sek)
19.0(1+1+1+1+0+0+0+0+0+0+0+0+1+2+2+2)/8=1375Kbpsaverage-rate < burst-threshold → Burst is allowed4Mbps (2Mb per 0,5sek)
19.5(1+1+1+0+0+0+0+0+0+0+0+1+2+2+2+2)/8=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
20.0(1+1+0+0+0+0+0+0+0+0+1+2+2+2+2+1)/8=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
20.5(1+0+0+0+0+0+0+0+0+1+2+2+2+2+1+1)/8=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
21.0(0+0+0+0+0+0+0+0+1+2+2+2+2+1+1+1)/8=1500Kbpsaverage-rate = burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
21.5(0+0+0+0+0+0+0+1+2+2+2+2+1+1+1+1)/8=1625Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
22.0(0+0+0+0+0+0+1+2+2+2+2+1+1+1+1+1)/8=1750Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
22.5(0+0+0+0+0+1+2+2+2+2+1+1+1+1+1+1)/8=1875Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
23.0(0+0+0+0+1+2+2+2+2+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
23.5(0+0+0+1+2+2+2+2+1+1+1+1+1+1+1+1)/8=2125Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
24.0(0+0+1+2+2+2+2+1+1+1+1+1+1+1+1+1)/8=2250Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
24.5(0+1+2+2+2+2+1+1+1+1+1+1+1+1+1+1)/8=2375Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
25.0(1+2+2+2+2+1+1+1+1+1+1+1+1+1+1+1)/8=2500Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
25.5(2+2+2+2+1+1+1+1+1+1+1+1+1+1+1+1)/8=2500Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
26.0(2+2+2+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2375Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
26.5(2+2+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2250Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
27.0(2+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2125Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
27.5(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
28.0(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
28.5(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
29.0(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
29.5(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
30.0(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed2Mbps (1Mb per 0,5sek)
30.5(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+1)/8=2000Kbpsaverage-rate > burst-threshold → Burst not allowed0Mbps (0Mb per 0,5sek)
31.0(1+1+1+1+1+1+1+1+1+1+1+1+1+1+1+0)/8=1875Kbpsaverage-rate > burst-threshold → Burst not allowed0Mbps (0Mb per 0,5sek)
  • No labels
