Internet Group Management Protocol (IGMP) proxy can implement multicast routing. It is forwarding IGMP frames and is commonly used when there is no need for a more advanced protocol like PIM.
IGMP proxy features:
On the other hand, IGMP proxy is not well suited for complicated multicast routing setups. Compared to PIM-based solutions, IGMP proxy does not support more than one upstream interface and routing loops are not detected or avoided.
By default, IGMP proxy upstream interface will send IGMPv3 membership reports and it will detect what IGMP version the upstream device (e.g. multicast router) is using based on received queries. In case IGMPv1/v2 queries are received, the upstream port will fall back to the lower IGMP version. It will convert back to IGMPv3 when IGMPv1/v2 querier present timer (400s) expires. Downstream interfaces of IGMP proxy will only send IGMPv2 queries.
RouterOS v7 has IGMP proxy configuration available in the main system package. Older RouterOS versions need an additional multicast package installed in order to use IGMP proxy. See more details about Packages.
General IGMP proxy configuration.
Sub-menu: /routing igmp-proxy
Property | Description |
query-interval (time: 1s..1h; Default: 2m5s) | How often to send out IGMP Query messages over downstream interfaces. |
query-response-interval (time: 1s..1h; Default: 10s) | How long to wait for responses to an IGMP Query message. |
quick-leave | Specifies action on IGMP Leave message. If quick-leave is on, then an IGMP Leave message is sent upstream as soon as a leave message is received from the first client on the downstream interface. Use yes only in case there is only one subscriber behind the proxy. |
Configure what interfaces will participate as IGMP proxy interfaces on the router. If an interface is not configured as an IGMP proxy interface, then all IGMP traffic received on it will be ignored.
Sub-menu: /routing igmp-proxy interface
alternative-subnets (IP/Mask; Default: ) | By default, only packets from directly attached subnets are accepted. This parameter can be used to specify a list of alternative valid packet source subnets, both for data or IGMP packets. Has an effect only on the upstream interface. Should be used when the source of multicast data often is in a different IP network. |
interface (name; Default: all) | Name of the interface. |
threshold (integer: 0..4294967295; Default: 1) | Minimal TTL. Packets received with a lower TTL value are ignored |
upstream (yes | no; Default: no) | The interface is called "upstream" if it's in the direction of the root of the multicast tree. An IGMP forwarding router must have exactly one upstream interface configured. The upstream interface is used to send out IGMP membership requests. |
It is possible to get detailed status information for each interface using the print
status
command.
[admin@MikroTik] /routing igmp-proxy interface print status Flags: X - disabled, I - inactive, D - dynamic; U - upstream 0 U interface=ether2 threshold=1 alternative-subnets="" upstream=yes source-ip-address=192.168.10.10 rx-bytes=3018487500 rx-packets=2012325 tx-bytes=0 tx-packets=0 1 interface=ether3 threshold=1 alternative-subnets="" upstream=no querier=yes source-ip-address=192.168.20.10 rx-bytes=0 rx-packets=0 tx-bytes=2973486000 tx-packets=1982324 2 interface=ether4 threshold=1 alternative-subnets="" upstream=no querier=yes source-ip-address=192.168.30.10 rx-bytes=0 rx-packets=0 tx-bytes=152019000 tx-packets=101346
querier (read-only; yes|no) | Whether the interface is acting as an IGMP querier. |
source-ip-address (read-only; IP address) | The detected source IP for the interface. |
rx-bytes (read-only; integer) | The total amount of received multicast traffic on the interface. |
rx-packet (read-only; integer) | The total amount of received multicast packets on the interface. |
tx-bytes (read-only; integer) | The total amount of transmitted multicast traffic on the interface. |
tx-packet (read-only; integer) | The total amount of transmitted multicast packets on the interface. |
Multicast forwarding cache (MFC) status.
Sub-menu: /routing igmp-proxy mfc
active-downstream-interfaces (read-only: name) | The packet stream is going out of the router through this interface. |
bytes (read-only: integer) | The total amount of received multicast traffic. |
group (read-only: IP address) | IGMP group address. |
packets (read-only: integer) | The total amount of received multicast packets. |
source (read-only: IP address) | The multicast data originator address. |
upstream-interface (read-only: name) | The packet stream is coming into the router through this interface. |
wrong-packets (read-only: integer) | The total amount of received multicast packets that arrived on a wrong interface, for example, a multicast stream that is received on a downstream interface instead of an upstream interface. |
RouterOS support static multicast forwarding rules for IGMP proxy. If a static rule is added, all dynamic rules for that group will be ignored. These rules will take effect only if IGMP-proxy interfaces are configured (upstream and downstream interfaces should be set) or these rules won't be active.
downstream-interfaces (name; Default: ) | The received stream will be sent out to the listed interfaces only. |
group (read-only: IP address) | The multicast group address this rule applies. |
upstream-interface (read-only: name) | The interface that is receiving stream data. |
To forward all multicast data coming from the ether2 interface to the downstream bridge interface, where subscribers are connected, use the configuration below. Both interfaces should have an IP address.
/routing igmp-proxy interface add interface=ether2 upstream=yes add interface=bridge1 [admin@MikroTik] /routing igmp-proxy interface print Flags: U - UPSTREAM Columns: INTERFACE, THRESHOLD # INTERFACE THRESHOLD 0 U ether2 1 1 bridge1 1
You may also need to configure alternative-subnets
on the upstream interface in case the multicast sender address is in an IP subnet that is not directly reachable from the local router:
/routing igmp-proxy interface set [find upstream=yes] alternative-subnets=192.168.50.0/24,192.168.60.0/24
To enable quick-leave
, use the setting below:
/routing igmp-proxy set quick-leave=yes
