Summary
Sub-menu: /ip kid-control
"Kid control" is a parental control feature to limit internet connectivity for LAN devices.
Property Description
In this menu, it is possible to create a profile for each Kid and restrict internet accessibility.
PropertyDescription
name (string)Name of the Kid's profile
mon,tue,wed,thu,fri,sat,sun (time)Each day of the week. Time of day, when internet access should be allowed
disabled (yes | no)Whether restrictions are enabled
rate-limit (string)The maximum available data rate for flow
tur-mon,tur-tue,tur-wed,tur-thu,tur-fri,tur-sat,tur-sun (time)Time unlimited rate. Time of day, when internet access should be unlimited
Time unlimited rate parameters have higher priority than rate-limit parameter.
Devices
Sub-menu: /ip kid-control device
This sub-menu contains information if there are multiple connected devices to the internet (phone, tablet, gaming console, tv etc.). The device is identified by the MAC address that is retrieved from the ARP table. The appropriate IP address is taken from there.
PropertyDescription
name (string)Name of the device
mac-address (string)Devices mac-address
user (string)To which profile append the device
reset-counters ([id, name])Reset bytes-up and bytes-down counters.
Application example
With the following example we will restrict access for Peter's mobile phone:
  • Disabled internet access on Monday, Wednesday and Friday
  • Allowed unlimited internet access on:
    • Tuesday
    • Thursday from 11:00-22:00
    • Sunday 15:00-22:00
  • Limited bandwidth to 3Mbps for Peter's mobile phone on Saturday from 18:30-21:00
[admin@MikroTik] > /ip kid-control add name=Peter mon="" tur-tue="00:00-24h" wed="" tur-thu="11:00-22:00" fri="" sat="18:30-22:00" tur-sun="15h-21h" rate-limit=3M
[admin@MikroTik] > /ip kid-control device add name=Mobile-phone user=Peter mac-address=FF:FF:FF:ED:83:63
Internet access limitation is implemented by adding dynamic firewall filter rules or simple queue rules. Here are example firewall filter rules:
[admin@MikroTik] > /ip firewall filter print
1  D ;;; Mobile-phone, kid-control
      chain=forward action=reject src-address=192.168.88.254
2  D ;;; Mobile-phone, kid-control
      chain=forward action=reject dst-address=192.168.88.254
Dynamically created simple queue:
[admin@MikroTik] > /queue simple print
      name="queue1" target=192.168.88.254/32 parent=none packet-marks="" priority=8/8 queue=default-small/default-small limit-at=3M/3M max-limit=3M/3M burst-limit=0/0
      burst-threshold=0/0 burst-time=0s/0s bucket-size=0.1/0.1
It is possible to monitor how much data is used by the specific device:
[admin@MikroTik] > /ip kid-control device print stats
Flags: X - disabled, D - dynamic, B - blocked, L - limited, I - inactive
 #    NAME        IDLE-TIME    RATE-DOWN   RATE-UP   BYTES-DOWN     BYTES-UP
 1 BI Mobile-phone        30s         0bps      0bps    3438.1KiB       8.9KiB
It is also possible to pause Internet access for the created kids, it will restrict all access until resume is used, which will continue with configured settings:
[admin@MikroTik] > /ip kid-control pause Peter
[admin@MikroTik] > /ip kid-control print
Flags: X - disabled, P - paused, B - blocked, L - rate-limited
 #   NAME        SUN      MON      TUE      WED      THU      FRI      SAT
 0 PB Peter        15h-21h                             11h-22h          18:30h-22h
  • No labels
