Page tree
Feature Status
N/A - Feature not yet available
OK - Initial tests successful
NOK - initial tests not successful
Highlight Colors:
  • Yellow - partially working
  • Green - Working
  • Red - Not working at the moment
Feature
v7.0Beta7
v7.1Beta1v7.1Beta2v7.1Beta3v7.1Beta4v7.1Beta7
Winbox
BGP support
OSPF support
RIP support
Router ID support
Routing filter support
Generic
/31 address supportN/A
Convert route rules after upgrade from v6.xN/A
OK
Static IPv6 upgrade from ROS v6
NOKOK
IPv4 Route RulesOK
IPv6 Route RulesNOKOK
ECMP flagsOK
dst@tableOK
gateway@tableOK
gateway%interfaceOK
recursive route over ipv6 LL addressOK
3 level recursive gateway with ECMP OK
IPV6 ECMPOK
IPv6 connected ECMP
N/A
OK
Addresses from same subnet to multiple interfacesNOK
Show time when route was last updatedN/A
Check GatewayPing OK, ARP NOK (works as ping), BFD NOK (not implemented)
Scope and target scopeOK
IPv4 Mangle routing-markOK
IPv6 Mangle routing-markNOK (Added but does not work at the moment)OK
Packet SRC address
NOK (wrong src is picked for locally originated packets)
Does not work correctly with /32 addresses
Routing-table parameter for ping and telnetNOK
Show if route is hardware acceleratedN/A
Shows if route is candidate for HW acceleration
Custom route selection policy N/A
IPv4 with IPv6 nexthops and RFC5549N/A
OK
Routing InstanceOK
Renamed to Router-ID
VRFNeeds more testing
Some kind of mechanism to import/export routes from one vrf to another within same routerN/A
BFDN/A
OSPF
Convert OSPF config from v6 to v7 after upgradeN/A
OSPF neighbours in in NSSA AreaCannot establish adjacency
OSPF in broadcast networkDoes not work with more than 2 neighbours
OK
OSPF with routing filtersOK
OSPF Virtual LinkOK
BGP and OSPF SNMP monitoringN/A
BGP
Convert BGP config from v6 to v7 after upgradeN/A
OK
BGP Templates and dynamic peersOK
BGP connect listen on networkOK
BGP guess remote.asOK
Show from which peer route receivedOK ( /routing/route/print detail --> belongs-to)
BGP Address FamiliesCurrently only IPv4, IPv6
BGP input.accept-*Does not work right after peer established, need to resend routes
eBGP nexthop selfOK
Input FilterOK
Output FilterOK
BGP Local address auto selectionOK
BGP route reflectOK
BGP route serverOK
BGP Roles
https://datatracker.ietf.org/doc/draft-ietf-idr-bgp-open-policy/?include_text=1
OK
BGP peer-cache uptime in "established" stateN/A
BGP Flow SpecFlow spec attributes are forwarded
BGP SelectionOK
BGP Selection (Multipath)N/A
BGP ConfederationOK
BGP AggregationN/A
BGP ORFN/A
Discard prefix RTBH  RFC 6666N/A
AS-wide Unique BGP Identifier RFC 6286N/A
Exported PDU PCAP saver
Ok
Exported PDU PCAP loader
MPLS
Static label mappingN/A
Static mapping upgrade from v6
LDP IPv4 mappingN/A
Ok
LDP IPv6 mappingN/A
LDP signaled VPLSN/A
LDP config upgrade from v6N/A
TEN/A
TE Config upgrade from v6N/A
VPLS Encap to TEN/A
BGP signaled VPLSN/A
VPLS config upgrade from v6N/A
Fast rerouteN/A
MPLS ECMPN/A
One label per VRFN/A
RPKI sessionOK
RPKI possibility to view received info of specific prefixN/AOK
RPKI show connection statusN/A
Ok
Filters
Convert routing filters after upgrade from v6.xN/A
Routing filter chain drop by default without rulesOK
Routing filter prefix match
OK
Routing filter protocol matchMissing other protocols like modem DHCP etc (these routes are not matched by "static")
Routing filter append communitiesOK
Routing filter append large communityOK
Routing filter set weight"sub, add" does not work if attribute has default unset value, if attribute is not set then default value should be assumed.
Routing filter set local pref"sub, add" does not work if attribute has default unset value, default value should be 100 if not set.
Routing filter set MED"sub,add" should assume default value.
Routing filter set originOK
Routing filter set igp metric from OSPF cost Can be set with set-num-prop=bgp-igp-metric<add>ospf-ext-metric or ospf-metric, but what to do if it is not possible to guess which metric to use?
Routing filter match prefix with address listOK
Routing filter match community/large community listsOK
Routing filter add prefix to address listN/A
Routing filter validate prefix with RPKIOK
Performance Status
Used hardware:
  • CCR1036, 16GB RAM (tile)
  • CCR2004(arm64)
  • CCR1100AHx4(arm)
  • Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz 32GB RAM (as a host for CHRs)
Simulated upstream peer is CHR router running ROSv6 with copy of global IPv4 routing table (585K routes loaded from MRT dump).
One Peer Receive Only
DUT establishes connection to simulated upstream peer, receives routes and installs them in FIB.
v6.44v7.1beta3
CCR0:40 - 2:120:46
RB1100x4 1.4GHz0:32-0:380:23
CCR20040:320:18
x86 (CHR)0:20
RB450G (in/out affinity=alone)after trying for 9min - ran out of memory at 558K routes2:02 (121MB free)
RB450G (in/out affinity=main)-1:54
RB450G (affinity in=alone out=input)-2:12
Two Peers Receive Only
DUT establishes connection to two simulated upstream peers, receives routes, picks best route and installs in FIB. On ROSv7 affinity settings set to "alone".
v6.44FRRv7.1beta3
CCR1:01 - 2:45
1:11
RB1100x4 1.4GHz0:51
0:30
CCR20040:51
0:29
x86 (CHR)0:25
x86 (virtual)
0:26(4cores)
0:46(2cores)
0:30(2cores no LDP)
Multi-homing Sim
Two DUT devices establishes eBGP sessions to simulated x86 upstream router. Both DUTs are interconnected with iBGP session. Each DUT receives routes from upstream and readvertise routes over iBGP. On ROSv7 affinity settings set to "alone" and early-cut disabled.
  • Route Provider: CHR (ROSv6)
  • DUT_1: CCR1032
  • DUT_2: CCR1032
v7.1beta31:11
v7.1beta21:29
v6.xx1:02 - 8:30
  • DUT_1: CCR2004
  • DUT_2: RB1100AHx2
v7.1beta30:36
v6.xx0:59
Memory Usage:
Columns: TASKS, PRIVATE-MEM-BLOCKS, SHARED-MEM-BLOCKS, PSS, RSS, VMS, RETIRED, ID, PID, RPID, PROCESS-TIME, KERNEL-TIME, CUR-BUSY, MAX-BU>
   #  TASKS                         PRIVATE-M  SHARED-M  P  R  V  RE  ID       PID  R  PROCESS-  KERNEL-  CUR  MAX-BUS  CUR  MAX-CALC
   0  routing tables                12.0MiB    30.2MiB   0  0  0  12  main     111  0  8s980ms   2s60ms   0ms  1s320ms  0ms  10s700ms
      rib
      connected networks
   1  fib                           2816.0KiB  0         0  0  0      fib      130  1  3s        4s660ms       7s220ms       7s220ms
   2  ospf                          512.0KiB   256.0KiB  0  0  0      ospf     137  1  1s220ms   130ms         980ms         1s40ms
      connected networks
   3  fantasy                       256.0KiB   0         0  0  0      fantasy  138  1  60ms      80ms          40ms          40ms
   4  configuration and reporting   3840.0KiB  512.0KiB  0  0  0      static   139  1  1s270ms   110ms         260ms         260ms
   5  rip                           512.0KiB   0         0  0  0      rip      136  1  120ms     70ms          60ms          120ms
      connected networks
   6  routing policy configuration  768.0KiB   768.0KiB  0  0  0      policy   133  1  2s290ms   3s170ms       80ms          80ms
   7  BGP service                   768.0KiB   0         0  0  0      bgp      134  1  2s760ms   5s480ms       20ms          60ms
      connected networks
   8  BFD service                   512.0KiB   0         0  0  0      12       135  1  100ms     90ms          40ms          120ms
      connected networks
   9  BGP Input 10.155.101.186      3072.0KiB  6.2MiB    0  0  0      20       183  1  1s350ms   1s190ms       20ms          20ms
  10  BGP Output 10.155.101.186     5.5MiB     0         0  0  0      21       184  1  5s400ms   500ms         3s880ms       3s880ms
  11  BGP Input 10.155.101.232      3072.0KiB  6.2MiB    0  0  0      22       187  1  970ms     740ms         20ms          20ms
  12  BGP Output 10.155.101.232     8.2MiB     0         0  0  0      23       188  1  10s830ms  960ms         7s            7s
  13  Global memory                            256.0KiB               global     0  0
  • No labels
