Page tree
Summary
The Cloud Router Switch series are highly integrated switches with high-performance CPU and feature-rich packet processors. The CRS3xx series switches can be designed into various Ethernet applications including unmanaged switch, Layer 2 managed switch, carrier switch and wired unified packet processing.
This article applies to CRS3xx series switches and not to CRS1xx/CRS2xx series switches.
Features
FeaturesDescription
Forwarding
  • Configurable ports for switching or routing
  • Full non-blocking wire-speed switching
  • Large Unicast FDB for Layer 2 unicast forwarding
  • Forwarding Databases works based on IVL
  • Jumbo frame support
  • IGMP Snooping support
Mirroring
  • Various types of mirroring:
    • Port based mirroring
    • VLAN based mirroring
    • MAC based mirroring
VLAN
  • Fully compatible with IEEE802.1Q and IEEE802.1ad VLAN
  • 4k active VLANs
  • Flexible VLAN assignment:
    • Port based VLAN
    • Protocol based VLAN
    • MAC based VLAN
  • VLAN filtering
  • From any to any VLAN translation
Bonding
  • Supports 802.3ad (LACP) and balance-xor modes
  • Up to 8 member ports per bonding interface
  • Up to 30 bonding interfaces
  • Hardware automatic failover and load balancing
Traffic Shaping
  • Ingress traffic limiting
    • Port based
    • MAC based
    • IP based
    • VLAN based
    • Protocol based
    • DSCP based
  • Port based egress traffic limiting
Port isolation
  • Applicable for Private VLAN implementation
Access Control List
  • Ingress ACL tables
  • Classification based on ports, L2, L3, L4 protocol header fields
  • ACL actions include filtering, forwarding and modifying of the protocol header fields
Models
This table clarifies the main differences between Cloud Router Switch models.
ModelSwitch ChipCPUCoresWirelessSFP+ portACL rulesUnicast FDB entriesJumbo Frame (Bytes)
netPower 15FR (CRS318-1Fi-15Fr-2S)Marvell-98DX224S800MHz1--12816,00010218
netPower 16P (CRS318-16P-2S+)Marvell-98DX226S800MHz1-+12816,00010218
CRS326-24G-2S+ (RM/IN)Marvell-98DX3236800MHz1-+12816,00010218
CRS328-24P-4S+Marvell-98DX3236800MHz1-+12816,00010218
CRS328-4C-20S-4S+Marvell-98DX3236800MHz1-+12816,00010218
CRS305-1G-4S+Marvell-98DX3236800MHz1-+12816,00010218
CRS309-1G-8S+Marvell-98DX8208800MHz2-+68032 00010218
CRS317-1G-16S+Marvell-98DX8216800MHz2-+680128,00010218
CRS312-4C+8XGMarvell-98DX8212650MHz1-+34132,00010218
CRS326-24S+2Q+Marvell-98DX8332650MHz1-+17032,00010218
CRS354-48G-4S+2Q+Marvell-98DX3257650MHz1-+17032,00010218
CRS354-48P-4S+2Q+Marvell-98DX3257650MHz1-+17032,00010218
Abbreviations
  • FDB - Forwarding Database
  • MDB - Multicast Database
  • SVL - Shared VLAN Learning
  • IVL - Independent VLAN Learning
  • PVID - Port VLAN ID
  • ACL - Access Control List
  • CVID - Customer VLAN ID
  • SVID - Service VLAN ID
Port switching
In order to set up a port switching on CRS3xx series switches, check the Bridge Hardware Offloading page.
Currently it is possible to create only one bridge with hardware offloading on CRS3xx series devices. Use the hw=yes/no parameter to select which bridge will use hardware offloading.
On CRS3xx series switches, bridge STP/RSTP/MSTP, IGMP Snooping and VLAN filtering settings don't affect hardware offloading, since RouterOS v6.42 Bonding interfaces are also hardware offloaded.
VLAN
Since RouterOS version 6.41, a bridge provides VLAN aware Layer2 forwarding and VLAN tag modifications within the bridge. This set of features makes bridge operation more like a traditional Ethernet switch and allows to overcome Spanning Tree compatibility issues compared to the configuration when tunnel-like VLAN interfaces are bridged. Bridge VLAN Filtering configuration is highly recommended to comply with STP (802.1D), RSTP (802.1w) standards and it is mandatory to enable MSTP (802.1s) support in RouterOS.
VLAN Filtering
The main VLAN setting is vlan-filtering, which globally controls VLAN awareness and VLAN tag processing in the bridge. If vlan-filtering=no is used, the bridge ignores VLAN tags, works in a shared-VLAN-learning (SVL) mode and cannot modify VLAN tags of packets. Turning on vlan-filtering=yes, enables all bridge VLAN related functionality and independent-VLAN-learning (IVL) mode. Besides joining the ports for Layer2 forwarding, the bridge itself is also an interface therefore it has its own Port VLAN ID (pvid).
Since RouterOS version 6.41, all VLAN switching related parameters are moved to the bridge section. On CRS3xx series devices, VLAN switching must be configured under the bridge section as well, this will not limit the device's performance, CRS3xx is designed to use the built-in switch chip to work with bridge VLAN filtering, you are able to achieve full non-blocking wire-speed switching performance while using bridges and bridge VLAN filtering. Make sure that all bridge ports have the "H" flag, which indicates that the device is using the switch chip to forward packets.
Sub-menu: /interface bridge
PropertyDescription
vlan-filtering (yes | no; Default: no)Globally enables or disables VLAN functionality for the bridge.
pvid (1..4094; Default: 1)Port VLAN ID (pvid) specifies which VLAN the untagged ingress traffic is assigned to. It applies e.g. to frames sent from bridge IP and destined to a bridge port.
Sub-menu: /interface bridge port
PropertyDescription
frame-types (admit-all | admit-only-untagged-and-priority-tagged | admit-only-vlan-tagged; Default: admit-all)Specifies allowed ingress frame types on a bridge port. It only has an effect when vlan-filtering is enabled.
ingress-filtering (yes | no; Default: no)Enables or disables ingress filtering, which checks if an entry exists for the ingress port and the VLAN ID in the bridge VLAN table. Should be used with frame-types to specify if the ingress traffic should be tagged or untagged. This property only has an effect when vlan-filtering is set to yes.
VLAN Table
Bridge VLAN table represents per-VLAN port mapping with an egress VLAN tag action. tagged ports send out frames with a specified VLAN ID tag. untagged ports remove the VLAN tag before sending out frames.
Sub-menu: /interface bridge vlan
PropertyDescription
bridge (name)The bridge interface which the respective VLAN entry is intended for.
disabled (yes | no; Default: no)Enables or disables Bridge VLAN entry.
tagged (interfaces; Default: none)Interface list with a VLAN tag adding action in egress. This setting accepts comma-separated values. e.g. tagged=ether1,ether2.
untagged (interfaces; Default: none)Interface list with a VLAN tag removing action in egress. This setting accepts comma-separated values. e.g. untagged=ether3,ether4.
vlan-ids (1..4094)The list of VLAN IDs for certain port configuration. This setting accepts a VLAN ID range as well as comma-separated values. e.g. vlan-ids=100-115,120,122,128-130.
VLAN setup examples
Below are describes some of the most common ways on how to utilize VLAN forwarding on the CRS3xx series switches.
Port-Based VLAN
The configuration for CRS3xx switches is described in the Bridge VLAN FIltering section.
It is possible to use the built-in switch chip and the CPU at the same time to create a Switch-Router setup, where a device acts as a switch and as a router at the same time. You can find a configuration example in the CRS-Router guide.
MAC Based VLAN
  • The CRS3xx Switch Rule table is used for MAC Based VLAN functionality, see this table on how many rules each device supports.
  • MAC-based VLANs will only work properly between switch ports and not between switch ports and CPU. When a packet is being forwarded to the CPU, the pvid property for the bridge port will be always used instead of new-vlan-id from ACL rules.
  • MAC-based VLANs will not work for DHCP packets when DHCP snooping is enabled.
Enable switching on ports by creating a bridge with enabled hw-offloading:
add name=bridge1 vlan-filtering=yes
add bridge=bridge1 interface=ether2 hw=yes
add bridge=bridge1 interface=ether7 hw=yes
Add VLANs in the Bridge VLAN table and specify ports:
add bridge=bridge1 tagged=ether2 untagged=ether7 vlan-ids=200,300,400
Add Switch rules which assign VLAN id based on MAC address:
/interface ethernet switch rule
add switch=switch1 ports=ether7 src-mac-address=A4:12:6D:77:94:43/FF:FF:FF:FF:FF:FF new-vlan-id=200
add switch=switch1 ports=ether7 src-mac-address=84:37:62:DF:04:20/FF:FF:FF:FF:FF:FF new-vlan-id=300
add switch=switch1 ports=ether7 src-mac-address=E7:16:34:A1:CD:18/FF:FF:FF:FF:FF:FF new-vlan-id=400
Protocol Based VLAN
  • The CRS3xx Switch Rule table is used for Protocol Based VLAN functionality, see this table on how many rules each device supports.
  • Protocol-based VLANs will only work properly between switch ports and not between switch ports and CPU. When a packet is being forwarded to the CPU, the pvid property for the bridge port will be always used instead of new-vlan-id from ACL rules.
  • Protocol-based VLANs will not work for DHCP packets when DHCP snooping is enabled.
add bridge=bridge1 interface=ether6 hw=yes
add bridge=bridge1 interface=ether8 hw=yes
add bridge=bridge1 tagged=ether2 untagged=ether6 vlan-ids=200
add bridge=bridge1 tagged=ether2 untagged=ether7 vlan-ids=300
add bridge=bridge1 tagged=ether2 untagged=ether8 vlan-ids=400
Add Switch rules which assign VLAN id based on MAC protocol:
add mac-protocol=ip new-vlan-id=200 ports=ether6 switch=switch1
add mac-protocol=ipx new-vlan-id=300 ports=ether7 switch=switch1
add mac-protocol=0x80F3 new-vlan-id=400 ports=ether8 switch=switch1
VLAN Tunneling (Q-in-Q)
Since RouterOS v6.43 it is possible to use a provider bridge (IEEE 802.1ad) and Tag Stacking VLAN filtering, and hardware offloading at the same time on CRS3xx series switches. The configuration for CRS3xx switches is described in the Bridge VLAN Tunneling (Q-in-Q) section.
Ingress VLAN translation
It is possible to translate a certain VLAN ID to a different VLAN ID using ACL rules on an ingress port. In this example we create two ACL rules, allowing a bidirectional communication. This can be done by doing the following.
Create a new bridge and add ports to it with hardware offloading:
add name=bridge1 vlan-filtering=no
add interface=ether1 bridge=bridge1 hw=yes
add interface=ether2 bridge=bridge1 hw=yes
Add ACL rules to translate a VLAN ID in each direction:
add new-dst-ports=ether2 new-vlan-id=20 ports=ether1 switch=switch1 vlan-id=10
add new-dst-ports=ether1 new-vlan-id=10 ports=ether2 switch=switch1 vlan-id=20
Add both VLAN IDs to the bridge VLAN table:
add bridge=bridge1 tagged=ether1 vlan-ids=10
add bridge=bridge1 tagged=ether2 vlan-ids=20
Enable bridge VLAN filtering:
/interface bridge set bridge1 vlan-filtering=yes
Bidirectional communication is limited only between two switch ports. Translating VLAN ID between more ports can cause traffic flooding or incorrect forwarding between the same VLAN ports.
By enabling vlan-filtering you will be filtering out traffic destined to the CPU, before enabling VLAN filtering you should make sure that you set up a Management port
(R/M)STP
CRS3xx series switches are capable of running STP, RSTP and MSTP on a hardware level. For more detailed information you should check out the Spanning Tree Protocol manual page.
Bonding
Since RouterOS v6.42 all CRS3xx series switches support hardware offloading with bonding interfaces. Only 802.3ad and balance-xor bonding modes are hardware offloaded, other bonding modes will use the CPU's resources. You can find more information about the bonding interfaces in the Bonding Interface section. If 802.3ad mode is used, then LACP (Link Aggregation Control Protocol) is supported.
To create hardware offloaded bonding interface, you must create a bonding interface with a supported bonding mode:
/interface bonding
add mode=802.3ad name=bond1 slaves=ether1,ether2
This interface can be added to a bridge alongside other interfaces:
add name=bridge
add bridge=bridge interface=bond1 hw=yes
add bridge=bridge interface=ether3 hw=yes
add bridge=bridge interface=ether4 hw=yes
Do not add interfaces to a bridge that are already in a bond, RouterOS will not allow you to add an interface to bridge that is already a slave port for bonding.
Make sure that the bonding interface is hardware offloaded by checking the "H" flag:
/interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE                                 BRIDGE                                 HW
 0   H bond1                                     bridge                                 yes
 1   H ether3                                    bridge                                 yes
 2   H ether4                                    bridge                                 yes
With HW-offloaded bonding interfaces, the built-in switch chip will always use Layer2+Layer3+Layer4 for a transmit hash policy, changing the transmit hash policy manually will have no effect.
L3 Hardware Offloading
Layer3 hardware offloading (otherwise known as IP switching or HW routing) will allow to offload some of the router features on to the switch chip. This allows reaching wire speeds when routing packets, which simply would not be possible with the CPU.
Starting with RouterOS v7.1beta4, both modes (l3hw=yes and l3hw=fw) merged, allowing to run full hardware routing on some ports and firewall-compatible mode on another. Also, l3hw renamed to l3-hw-offloading.
/interface/ethernet/switch set switch1 l3-hw-offloading=yes
/interface/ethernet/switch/port set [find] l3-hw-offloading=yes
Now Layer 3 Hardware Offloading can be configured for each physical switch port individually.
Note that l3hw settings for switch and ports are different. Setting l3-hw-offloading=no on the switch completely disables offloading - all packets will be routed by CPU. However, setting l3-hw-offloading=no for a switch port only disables hardware routing from/to this particular port. Moreover, the port can still participate in Fastrack connection offloading.
The existing connections are unaffected by the l3-hw-offloading setting change. Also, disabling l3-hw-offloading still may leave entries in the hardware memory. It is recommended to reboot the device after configuring Layer 3 Hardware Offloading.
Currently supported and unsupported feature list:
FeatureStatusDescription
IPv4 UnicastHW
Depending on the complexity of routes in the routing table, the max HW accelerated route count could change (see hardware-specific limits below). Whole-byte IP prefixes (/8, /16, /24, etc.) occupy less HW space than others (e.g., /22).
If the HW route limit is reached new routes will fall back to CPU, except cases when the newly added route overlaps with already existing routes processed by the hardware. In this case, destinations that were processed in hardware will continue to be processed in hardware. The user should choose the device with HW capability large-enough to store all the routes.
IPv6 UnicastCPU
IPv4 MulticastCPU
IPv6 MulticastCPU
ECMPHWSee hardware-specific limits below
"blackhole" routesHWThis feature enables the possibility to drop D/DOS attacks at wire speed
"prohibit" routesCPU
"unreachable" routesCPU
gateway=<interface_name>HW/CPUThis works only for directly connected networks. Since HW does not know how to send ARP requests, CPU sends ARP request and waits for a reply to find out a DST MAC address on the first received packet of the connection that matches a DST IP address. After DST MAC is determined, HW entry is added and all further packets will be processed by the switch chip.
BridgeHWRouting from/to bridge interface
VLANHWRouting between VLAN interfaces
LACP/BondingHW
FirewallFWOnly Fasttrack connections get processed by HW, which means that the CPU is processing packets until the connection gets fast-tracked.
NATFWNAT rules applied to the offloaded Fasttrack connections are processed by HW.
QoSN/A
Where:
  • CPU - feature is supported but processed by CPU
  • HW - feature is supported and offloaded in hardware
  • FW - feature is supported and offloaded in hardware (l3-hw-offloading=no for a specific switch port, l3-hw-offloading=yes must be enabled on switch level)
  • N/A - feature is not available, meaning that L3 Hardware offloading MUST be disabled for these features to work
To make all packets go through the CPU first, and offload only the Fasttrack connections, disable l3hw on all ports but keep it enabled on the switch chip itself (equivalent to old l3hw=fw):
/interface/ethernet/switch/port set [find] l3-hw-offloading=no
Packets get routed by the hardware only if both source and destination ports have l3-hw-offloading=yes. If at least one of them has, packets will go through the CPU/Firewall while offloading only the Fasttrack connections.
The next example enables hardware routing on all ports but the upstream port (sfp-sfpplus16). Packets going to/from sfp-sfpplus16 will enter the CPU and, therefore, subject to Firewall/NAT processing.
/interface/ethernet/switch/port set sfp-sfpplus16 l3-hw-offloading=no
List of supported devices and their limits
ReleaseRoutesNexthopsECMP GroupsFasttrack connections1,2NAT enties2
CRS317-1G-16S+7.1beta1150K - 240K8K4K
4500 / 3750 3
8K 4
CRS309-1G-8S+7.1beta250K - 80K8K4K4500 / 37508K
CRS312-4C+8XG7.1beta250K - 80K8K4K2250 / 15008K
CRS326-24S+2Q+7.1beta250K - 80K8K4K2250 / 15008K
CRS354-48G-4S+2Q+7.1beta450K - 80K8K4K2250 / 15008K
*1 When the HW limit of Fasttrack or NAT entries is reached, other connections will fall back to the CPU. MikroTik's smart connection offload algorithm ensures that the connections with the most traffic are offloaded to the hardware.
*2 Fasttrack connections share the same HW memory with ACL rules. Depending on the complexity, one ACL rule may occupy the memory of 3-6 Fasttrack connections.
*3 (Both MPLS and Bridge Port Extender are disabled) / (MPLS, Bridge Port Extender, or both are enabled). MPLS shares the HW memory with Fasttrack connections. Moreover, enabling MPLS requires the allocation of the entire memory region, which could store up to 750 Fasttrack connections otherwise. The same applies to Bridge Port Extender. However, MPLS and Bridge Port Extended may use the same memory region, so enabling them both doesn't double the limitation of Fasttrack connections.
*4 All NAT entries cannot be used due to the limited amount of Fasttrack connections.
Interface Lists
It is impossible to use interface lists directly to control l3-hw-offloading because an interface list may contain virtual interfaces (such as VLAN) while the l3-hw-offloading setting must be applied to physical switch ports only. For example, if there are two VLAN interfaces (vlan20 and vlan30) running on the same switch port (trunk port), it is impossible to enable hardware routing on vlan20 but keep it disabled on vlan30.
However, an interface list may be used as a port selector. The following example demonstrates how to enable hardware routing on LAN ports (ports that belong to the "LAN" interface list) and disable it on WAN ports:
:foreach i in=[/interface/list/member/find where list=LAN] do={
/interface/ethernet/switch/port set [/interface/list/member/get $i interface] l3-hw-offloading=yes
:foreach i in=[/interface/list/member/find where list=WAN] do={
/interface/ethernet/switch/port set [/interface/list/member/get $i interface] l3-hw-offloading=no
Please take into account that since interface lists are not used directly in the hardware routing control, modifying the interface list also does not automatically reflect into l3hw changes. For instance, adding a switch port to the "LAN" interface list does not automatically enable l3-hw-offloadingon that. The user has to rerun the above script to apply the changes.
Port isolation
Since RouterOS v6.43 is it possible to create a Private VLAN setup on CRS3xx series switches, an example can be found in the Switch chip port isolation manual page. Hardware offloaded bonding interfaces are not included in the switch port-isolation menu, but it is still possible to configure port-isolation individually on each secondary interface of the bonding.
IGMP Snooping
CRS3xx series switches are capable of using IGMP Snooping on a hardware level. To see more detailed information, you should check out the IGMP Snooping manual page.
DHCP Snooping and DHCP Option 82
CRS3xx series switches are capable of using DHCP Snooping with Option 82 on a hardware level. The switch will create a dynamic ACL rule to capture the DHCP packets and redirect them to the main CPU for further processing. To see more detailed information, please visit the DHCP Snooping and DHCP Option 82 manual page.
Mirroring
Mirroring lets the switch sniff all traffic that is going in a switch chip and send a copy of those packets out to another port (mirror-target). This feature can be used to easily set up a tap device that allows you to inspect the traffic on your network on a traffic analyzer device. It is possible to set up a simple port-based mirroring, but it is also possible to set up more complex mirroring based on various parameters. Note that mirror-target port has to belong to the same switch (see which port belongs to which switch in /interface ethernet menu). Also mirror-target can have a special 'cpu' value, which means that sniffed packets will be sent out of switch chips cpu port. There are many possibilities that can be used to mirror certain traffic, below you can find most common mirroring examples:
Port Based Mirroring:
set switch1 mirror-source=ether2 mirror-target=ether3
Property mirror-source will send an ingress and egress packet copies to the mirror-target port. Both mirror-source and mirror-target are limited to a single interface.
set switch1 mirror-source=none mirror-target=ether3
add mirror=yes ports=ether1,ether2 switch=switch1
Using ACL rules, it is possible to mirror packets from multiple ports interfaces. Only ingress packets are mirrored to mirror-target interface.
VLAN Based Mirroring:
set switch1 mirror-target=ether3 mirror-source=none
add mirror=yes ports=ether1 switch=switch1 vlan-id=11
By enabling vlan-filtering you will be filtering out traffic destined to the CPU, before enabling VLAN filtering you should make sure that you set up a Management port.
MAC Based Mirroring:
add mirror=yes ports=ether1 switch=switch1 dst-mac-address=64:D1:54:D9:27:E6/FF:FF:FF:FF:FF:FF
add mirror=yes ports=ether1 switch=switch1 src-mac-address=64:D1:54:D9:27:E6/FF:FF:FF:FF:FF:FF
Protocol Based Mirroring:
add mirror=yes ports=ether1 switch=switch1 mac-protocol=ipx
IP Based Mirroring:
add mirror=yes ports=ether1 switch=switch1 src-address=192.168.88.0/24
add mirror=yes ports=ether1 switch=switch1 dst-address=192.168.88.0/24
There are other options as well, check the ACL section to find out all possible parameters that can be used to match packets.
Traffic Shaping
It is possible to limit a certain type of traffic using ACL rules. For CRS3xx series switches it is possible to limit ingress traffic that matches certain parameters and it is possible to limit ingress/egress traffic per port basis. For ingress traffic QoS policer is used, for egress traffic QoS shaper is used.
Port Based Traffic Shaping:
set ether1 ingress-rate=10M egress-rate=5M
MAC Based Traffic Shaping:
add ports=ether1 switch=switch1 src-mac-address=64:D1:54:D9:27:E6/FF:FF:FF:FF:FF:FF rate=10M
VLAN Based Traffic Shaping:
add ports=ether1 switch=switch1 vlan-id=11 rate=10M
Protocol Based Traffic Shaping:
add ports=ether1 switch=switch1 mac-protocol=ipx rate=10M
The CRS3xx Switch Rule table is used for QoS functionality, see this table on how many rules each device supports.
Traffic Storm Control
Since RouterOS v6.42 it is possible to enable traffic storm control on CRS3xx series devices. A traffic storm can emerge when certain frames are continuously flooded on the network. For example, if a network loop has been created and no loop avoidance mechanisms are used (e.g. Spanning Tree Protocol), broadcast or multicast frames can quickly overwhelm the network, causing degraded network performance or even complete network breakdown. With CRS3xx series switches it is possible to limit broadcast, unknown multicast and unknown unicast traffic. Unknown unicast traffic is considered when a switch does not contain a host entry for the destined MAC address. Unknown multicast traffic is considered when a switch does not contain a multicast group entry in the /interface bridge mdb menu. Storm control settings should be applied to ingress ports, the egress traffic will be limited.
The storm control parameter is specified in percentage (%) of the link speed. If your link speed is 1Gbps, then specifying storm-rate as 10 will allow only 100Mbps of broadcast, unknown multicast and/or unknown unicast traffic to be forwarded.
Sub-menu: /interface ethernet switch port
PropertyDescription
limit-broadcasts (yes | no; Default: yes)Limit broadcast traffic on a switch port.
limit-unknown-multicasts (yes | no; Default: no)Limit unknown multicast traffic on a switch port.
limit-unknown-unicasts (yes | no; Default: no)Limit unknown unicast traffic on a switch port.
storm-rate (integer 0..100; Default: 100)Amount of broadcast, unknown multicast and/or unknown unicast traffic is limited to in percentage of the link speed.
Devices with Marvell-98DX3236 switch chip cannot distinguish unknown multicast traffic from all multicast traffic. For example, CRS326-24G-2S+ will limit all multicast traffic when limit-unknown-multicasts and storm-rate is used. For other devices, for example, CRS317-1G-16S+ the limit-unknown-multicasts parameter will limit only unknown multicast traffic (addresses that are not present in /interface bridge mdb).
For example, to limit 1% (10Mbps) of broadcast and unknown unicast traffic on ether1 (1Gbps), use the following commands:
set ether1 storm-rate=1 limit-broadcasts=yes limit-unknown-unicasts=yes
MPLS hardware offloading
Since RouterOS v6.41 it is possible to offload certain MPLS functions to the switch chip, the switch must be a (P)rovider router in a PE-P-PE setup in order to achieve hardware offloading. A setup example can be found in the Basic MPLS setup example manual page. The hardware offloading will only take place when LDP interfaces are configured as physical switch interfaces (e.g. Ethernet, SFP, SFP+).
Currently only CRS317-1G-16S+ and CRS309-1G-8S+ using RouterOS v6.41 and newer are capable of hardware offloading certain MPLS functions. CRS317-1G-16S+ and CRS309-1G-8S+ built-in switch chip is not capable of popping MPLS labels from packets, in a PE-P-PE setup you either have to use explicit null or disable TTL propagation in MPLS network to achieve hardware offloading.
Switch Rules (ACL)
Access Control List contains ingress policy and egress policy engines. See this table on how many rules each device supports (limited by RouterOS). It is an advanced tool for wire-speed packet filtering, forwarding and modifying based on Layer2, Layer3 and Layer4 protocol header field conditions.
ACL rules are checked for each received packet until a match has been found. If there are multiple rules that can match, then only the first rule will be triggered. A rule without any action parameters is a rule to accept the packet.
Sub-menu: /interface ethernet switch rule
PropertyDescription
copy-to-cpu (no | yes; Default: no)Clones the matching packet and sends it to the CPU.
disabled (yes | no; Default: no)Enables or disables ACL entry.
dscp (0..63)Matching DSCP field of the packet.
dst-address (IP address/Mask)Matching destination IP address and mask.
dst-address6 (IPv6 address/Mask)Matching destination IPv6 address and mask.
dst-mac-address (MAC address/Mask)Matching destination MAC address and mask.
dst-port (0..65535)Matching destination protocol port number.
flow-label (0..1048575)Matching IPv6 flow label.
mac-protocol (802.2 | arp | homeplug-av | ip | ipv6 | ipx | lldp | loop-protect | mpls-multicast | mpls-unicast | packing-compr | packing-simple | pppoe | pppoe-discovery | rarp | service-vlan | vlan | or 0..65535 | or 0x0000-0xffff)Matching particular MAC protocol specified by protocol name or number
mirror (no | yes)Clones the matching packet and sends it to the mirror-target port.
new-dst-ports (ports)Changes the destination port as specified. An empty setting will drop the packet. A specified port will redirect the packet to it. When the parameter is not used, the packet will be accepted. Multiple "new-dst-ports" are not supported on the CRS3xx series switches.
new-vlan-id (0..4095)Changes the VLAN ID to the specified value. Requires vlan-filtering=yes.
new-vlan-priority (0..7)Changes the VLAN priority (priority code point). Requires vlan-filtering=yes.
ports (ports)Matching ports on which will the rule apply on received traffic.
protocol (dccp | ddp | egp | encap | etherip | ggp | gre | hmp | icmp | icmpv6 | idpr-cmtp | igmp | ipencap | ipip | ipsec-ah | ipsec-esp | ipv6 | ipv6-frag | ipv6-nonxt | ipv6-opts | ipv6-route | iso-tp4 | l2tp | ospf | pim | pup | rdp | rspf | rsvp | sctp | st | tcp | udp | udp-lite | vmtp | vrrp | xns-idp | xtp | or 0..255)Matching particular IP protocol specified by protocol name or number.
rate (0..4294967295)Sets ingress traffic limitation (bits per second) for matched traffic.
redirect-to-cpu (no | yes)Changes the destination port of a matching packet to the CPU.
src-address (IP address/Mask)Matching source IP address and mask.
src-address6 (IPv6 address/Mask)Matching source IPv6 address and mask.
src-mac-address (MAC address/Mask)Matching source MAC address and mask.
src-port (0..65535)Matching source protocol port number.
switch (switch group)Matching switch group on which will the rule apply.
traffic-class (0..255)Matching IPv6 traffic class.
vlan-id (0..4095)Matching VLAN ID. Requires vlan-filtering=yes.
vlan-header (not-present | present)Matching VLAN header, whether the VLAN header is present or not. Requires vlan-filtering=yes.
vlan-priority (0..7)Matching VLAN priority (priority code point).
Action parameters:
  • copy-to-cpu
  • redirect-to-cpu
  • mirror
  • new-dst-ports (can be used to drop packets)
  • new-vlan-id
  • new-vlan-priority
  • rate
Layer2 condition parameters:
  • dst-mac-address
  • mac-protocol
  • src-mac-address
  • vlan-id
  • vlan-header
  • vlan-priority
Layer3 condition parameters:
  • dscp
  • protocol
  • IPv4 conditions:
    • dst-address
    • src-address
  • IPv6 conditions:
    • dst-address6
    • flow-label
    • src-address6
    • traffic-class
Layer4 condition parameters:
  • dst-port
  • src-port
For VLAN related matchers or VLAN related action parameters to work, you need to enable vlan-filtering on the bridge interface and make sure that hardware offloading is enabled on those ports, otherwise these parameters will not have any effect.
When vlan-protocol is set to 802.1Q, then VLAN related ACL rules are relevant to 0x8100 (CVID) packets, this includes vlan-id and new-vlan-id. When vlan-protocol is set to 802.1ad, then ACL rules are relevant to 0x88A8 (SVID) packets. For example, with 802.1Q the vlan-id matcher will match CVID packets, but with 802.1ad the vlan-id matcher will match SVID packets.
Port Security
It is possible to limit allowed MAC addresses on a single switch port on CRS3xx series switches. For example, to allow 64:D1:54:81:EF:8E MAC address on a switch port, start by switching multiple ports together, in this example 64:D1:54:81:EF:8E is going to be located behind ether1
Create an ACL rule to allow the given MAC address and drop all other traffic on ether1 (for ingress traffic):
add ports=ether1 src-mac-address=64:D1:54:81:EF:8E/FF:FF:FF:FF:FF:FF switch=switch1
add new-dst-ports="" ports=ether1 switch=switch1
Switch all required ports together, disable MAC learning and disable unknown unicast flooding on ether1:
add name=bridge1
add bridge=bridge1 interface=ether1 hw=yes learn=no unknown-unicast-flood=no
Add a static hosts entry for 64:D1:54:81:EF:8E (for egress traffic):
/interface bridge host
add bridge=bridge1 interface=ether1 mac-address=64:D1:54:81:EF:8E
Broadcast traffic will still be sent out from ether1. To limit broadcast traffic flood on a bridge port, you can use the broadcast-flood parameter to toggle it. Do note that some protocols depend on broadcast traffic, such as streaming protocols and DHCP.
Dual Boot
“Dual boot” feature allows you to choose which operating system you prefer to use, RouterOS or SwOS. Device operating system could be changed using:
  • Command line (/system routerboard settings set boot-os=swos)
  • Winbox
  • Webfig
  • Serial Console
More details about SwOS are described here: SwOS manual
Configuring SwOS using RouterOS
Since RouterOS 6.43 it is possible to load, save and reset SwOS configuration, as well as upgrade SwOS and set an IP address for the switch by using RouterOS.
  • Save configuration with /system swos save-config
The configuration will be saved on the same device with swos.config as filename, make sure you download the file from your device since the configuration file will be removed after a reboot.
  • Load configuration with /system swos load-config
  • Change password with /system swos password
  • Reset configuration with /system swos reset-config
  • Upgrade SwOS from RouterOS using /system swos upgrade
The upgrade command will automatically install the latest available SwOS version, make sure that your device has access to the Internet in order for the upgrade process to work properly.
PropertyDescription
address-acquisition-mode (dhcp-only | dhcp-with-fallback | static; Default: dhcp-with-fallback)Changes address acquisition method:
dhcp-only - uses only a DHCP client to acquire address
dhcp-with-fallback - for the first 10 seconds will try to acquire address using a DHCP client. If the request is unsuccessful, then address falls back to static as defined by static-ip-address property
static - address is set as defined by static-ip-address property
allow-from (IP/Mask; Default: 0.0.0.0/0)IP address or a network from which the switch is accessible. By default, the switch is accessible by any IP address.
allow-from-ports (name; Default: )List of switch ports from which the device is accessible. By default, all ports are allowed to access the switch
allow-from-vlan (integer: 0..4094; Default: 0)VLAN ID from which the device is accessible. By default, all VLANs are allowed
identity (name; Default: Mikrotik)Name of the switch (used for Mikrotik Neighbor Discovery protocol)
static-ip-address (IP; Default: 192.168.88.1)IP address of the switch in case address-acquisition-mode is either set to dhcp-with-fallback or static. By setting a static IP address, the address acquisition process does not change, which is DHCP with fallback by default. This means that the configured static IP address will become active only when there is going to be no DHCP servers in the same broadcast domain
See also
CRS Router
CRS3xx VLANs with Bonds
Basic VLAN switching
MTU on RouterBOARD
Layer2 misconfiguration
Bridge VLAN Table
  • No labels
